Sinumerik Alarm 6520 The value of the machine data %1%2 is too low
%1 = String: MD identifier
%2 = If required, field index
The machine data $MN_MM_PROTOC_NUM_FILES specifies the number of protocol files for the protocol users. However, more types are used than configured.
Increase machine data $MN_MM_PROTOC_NUM_FILES.
