Sinumerik Alarm 7202 Missing option bit for %1: %2
%1 = (string) name of the specific .elf file
%2 = (int) required option bit (hex)
Alarm for SIEMENS compile cycles. This alarm appears when the option bit required for a SIEMENS compile cycle is not set.
– Alarm reaction delay is cancelled.
Set the required option bit or delete the .elf file from the Flash File System.
