Sinumerik Alarm 75010 Channel %1 block %2 CLC_LIM value exceeds MD limit
%2 = Block number
One of the limits for the position offset of the clearance control programmed with CLC_LIM( …,…) is greater than the permissible limitation set in the associated MD. $MC_CLC_SENSOR_LOWER_LIMIT[ 1 ] or $MC_CLC_SENSOR_UPPER_LIMIT[ 1 ].
Modify part program. Raise limitation in appropriate machine data if necessary.
