Sinumerik Alarm 75060 Channel %1 tolerance window exceeded axis %2
%2 = Axis name
The actual value difference between the CC_Slave axis %2 and its CC_Master axis is outside the configured tolerance window.
Check configured tolerance window. Compare dynamic response settings of coupled axes. Check mechanical components of axes.
