Sinumerik Alarm 8030 Channel %1 block %2 option ‘interpolation of more than 4 axes’ not set
The option for the number of interpolating axes does not correspond to the number of axes programmed in the interpolation group.
Option: “Interpolation of more than 4 axes” (the number of axes that is then allowed can
be set in this option) or specify in the part program as many (or fewer, as required) axes
corresponding to the configuration of the control.
