Complete list of G codes for Tormach Duality Lathe.
Tormach PCNC Duality Lathe
The Duality Lathe mounts on the Tormach PCNC 1100 bed, turning your CNC milling machine into a light duty CNC lathe for prototyping and small turning projects.
Tormach Duality Lathe G Codes
G00 | Rapid positioning |
G01 | Linear interpolation |
G02 | Clockwise circular/helical interpolation |
G03 | Counterclockwise circular/Helical interpolation |
G04 | Dwell |
G10 | Coordinate system origin setting |
G17 | XY Plane select |
G18 | XZ plane select |
G19 | YZ plane select |
G20/G21 | Inch/Millimetre units |
G28 | Return home (use with great care) |
G28.1 | Reference axes |
G30 | Return home (use with great care) |
G32 | Threading |
G40 | Cancel nose radius compensation |
G41/G42 | Start nose radius compensation left/right |
G50 | Reset all scale factors to 1.0 |
G51 | Set axis data input scale factors |
G52 | Temporary coordinate system offsets |
G53 | Move in absolute machine coordinate system |
G54 | Use fixture offset 1 |
G55 | Use fixture offset 2 |
G56 | Use fixture offset 3 |
G57 | Use fixture offset 4 |
G58 | Use fixture offset 5 |
G59 | Use fixture offset 6 / use general fixture number |
G61/G64 | Exact stop/Constant Velocity mode |
G76 | Canned cycle – screw cutting |
G77 | Canned cycle |
G78 | |
G80 | Cancel motion mode (including canned cycles) |
G81 | Canned cycle – drilling |
G82 | Canned cycle – drilling with dwell |
G83 | Canned cycle – peck drilling |
G90 | Absolute distance mode |
G91 | Incremental distance mode |
G92 | Offset coordinates and set parameters |
G92.x | Cancel G92 etc. |
G94 | Feed per minute mode |
G95 | Feed per rev mode |
G96 | Constant surface speed cutting |
G97 | Constant RPM cutting |
G98 | Initial level return after canned cycles |
G99 | R-point level return after canned cycles |
