Yasnac Alarm 615 TOOL RADIUS COMPENSATION C ERROR
Yasnac Alarm Description
Changing command of the plane for compensation. (G17 to G19) is made in G41 or G42 mode. G41 or G42 is programmed in G02 or G03 mode. G40 is programmed in G02 or G03 mode. Point of intersection does not exist on the offset locus. Reversing move command or command close to reversing is programmed in M97 mode. Circular arc out of the plane specified for compensation is programmed.
Applies to
Yasnac CNC Controls 3000G
