G Code | Functions |
G00 | Positioning in rapid traverse |
G01 | Positioning at the feed rate |
G02 | Circular interpolation – Clockwise |
G03 | Circular interpolation – Counterclockwise |
G04 | Dwell time |
G05 | Spatial arc interpolation |
G14 | Macro call |
G17 | Plane XY |
G18 | Plane ZX |
G19 | Plane YZ |
G22 | Sub program call |
G23 | Text – Functions |
G25 | RTCP H On/Off |
G26 | Free plane |
G29 | Axis transformation |
G30 | Spline interface (online spline) |
G305 | P5-Interpolation (Online Polynomial) |
G31 – G35 | Spline interface (offline spline) |
G40 | Deletion of the milling cutter radius correction |
G41 | Milling cutter radius correction left |
G42 | Milling cutter radius correction right |
G43 | Milling cutter radius correction up to |
G44 | Milling cutter radius correction via |
G50/G51/G52 | PRESET |
G50 | Deactivate PRESET |
G51 | activate PRESET |
G52 | program PRESET |
G53 | Deletion of the zero offset |
G54 – G59 | Zero offset and coordinate rotation |
G70 | Units of measurement inch |
G71 | Units of measurement mm |
G72 | Deletion of mirror image machining and scaling |
G73 | Mirror image machining |
G73 | Scaling |
G77 | Cycle execution on a circle |
G78 | Point definition |
G79 | Cycle execution |
G81 | Drilling cycle |
G83 | Deep-hole drilling cycle |
G84 | Tapping cycle |
G87 | Rectangular pocket milling cycle |
G88 | Slot milling cycle |
G89 | Circular / ring pocket milling cycle |
G90 | Absolute measure |
G91 | Relative measure |
G92 | Relative zero point offset coordinate rotation |
G93 | Absolute zero point offset coordinate rotation |
G94 | Speed programming |
G95 | Time programming |
G110 | PLC Output setting |
G111 | PLC Output deleting |
G181 | Probe calibration |
G182 | Distance measurement |
G183 | Straight line probing |
G184 | Shaft probing |
G185 | Bore probing |
G186 | Point measurement |
G187 | Measuring plate calibration |
G188 | Tool length measuring plate |
G189 | Tool breakage control measuring plate |
G190 | Absolute circle center |
G191 | Relative circle center |
G281 | Ramp participation |
G282 | Coordinates |
G282,0 | Switching workpiece coordinate system WCS / machine coordinates system MCS |
G282,1 | Resynchronising axis positions of active NC processes |
G282,2 | Modulo on / off |
G283 | Multi-axis probing |
G285 | Probe SETPOS |
G286 | Look Ahead Switch On/Off |
G288 | Set Look Ahead parameters |
G288,0 | LookAhead basic parameter |
G288,1 | time-based axes |
G288,2 | Rounding axis |
G288,3 | Contour accuracy of individual axes |
G288,4 | Time base factor is axis-specific |
G289 | Multi-function cycle |
G289 C | Disable execution of external cycles |
G289 E | Error Exit from G&M code |
G289 L | Tool length correction |
G289 N | Reload PRCON |
G289 R | Adopt tool radius |
G289 X | Adopt measurement values |
G289 Z | Enabling of G73 / G93 with cycles |
G481 | Bore setup |
G481 | SE01 setup 2 bores |
G481 | SE02 setup 4 bores |
G482 | Shaft setup |
G482 | SE03 Setup 2 shafts |
G482 | SE04 Setup 4 shafts |
G483 | Setup slot/rectangular pocket inside |
G484 | Setup slot/rectangle outside |
G485 | Setup 2 sides |
G487 | Determine space point |
G488 | Simple measurement block |
G581 | Continuous operation cycle rotation |
G582 | Continuous operation cycle oscillation |
G585 | Position log |
G586 | Activation of job list processing |
G586 | Job list processing |
G587 | I Variable -> PLC |
G587 | O Set feed/spindle potentiometer |
G589 | Approach reference point |
G688 | Setup command – Workpiece Machining |
G688,2 | Surface plane milling |
G688,3 | Frame milling |
G688,10 | Thread milling |
G781 | Calibration OFFSET |
G781,1 | Spindle offset |
G782 | Read/write data of the CNC |
G782,0 / ,1 | Data of the tool management |
G782,0 I/R | Read data of the CNC |
G782,0 E | Adjust error reaction cycles |
G782,1 | Write data of the CNC |
G782,2 | Read PLC variables |
G782,3 | Write PLC variables |
G782,4 | Read axis position |
G782,5 | Read definition of the external cycle interface |
G782,6 | Reading the execution definition of the external cycle interface |
G782,8 | Read sercos parameter |
G782,9 | Checking the assignment of communication variables |
G782,10 | Reading the active offsets |
G783,0 | Read/Write zero points |
G784,0 | Read in communication variable |
G784,1 | Emit communication variables |
G787 | Apaptive Control |
G788,1 | Probing the surface Z axis |
G788,2 | Corner and angle against the positive X axis |
G788,3 | Rectangle centre point and angle against X – individual measurement |
G788,5 | Rectangle centre point and angle against X – follow-up measurement |
G788,10 | Detecting the surface using 3 points (optional) |
G789 | Timer cycles |
