A very simple and easy programming exercise for cnc programmers / machinists who have just started learning cnc programming.
A drawing is given at the above and a cnc program is also given below with some missing blocks, you just have to fill the missing blocks correctly.
Note: this is an Adobe Flash tutorial.
How to Solve?
You just have to fill the missing program block (according to given drawing) with the one’s given in the blue box, simply drag them with your mouse and drop at the proper place, a green check mark will show up if you placed the right code at right blank space.
