G-Code | Description |
G0 | Positioning in rapid |
G1 | Linear interpolation at programmed feedrate |
G3 | Circular interpolation, clockwise |
G3 | Circular interpolation, counter-clockwise |
G4 | Dwell in seconds |
G5 | Circular interpolation with tangential entry |
G6 | Linear interpolation in rapid with extended IN POS range |
G17 | Plane selection X/Y |
G18 | Plane selection Z/X |
G19 | Plane selection Y/Z |
G20 | Setting pole for polar coordinates |
G21 | Subprogram call-up depending on I/F signal |
G22 | Subprogram call-up, unconditional |
G23 | Jump to program label depending on I/F signal |
G24 | Jump to program label, unconditional |
G25 | Field limitation, setting minimum values |
G26 | Field limitation, setting maximum values |
G27 | Cancelling field limitation |
G36 | Scale factor switching |
G38 | Switch on programmable mirroring |
G39 | Switch off programmable mirroring |
G40 | Cancelling tool radius compensation |
G41 | Tool radius compensation to the left of the path |
G42 | Tool radius compensation to the right of the path |
G53 | Cancel zero shift |
G54 to G59 | Switch on zero shift |
G61 | ‘In Position’ function on |
G62 | ‘In Position’ function off |
G63 | Feedrate and spindle speed set to 100% |
G64 | Feedrate applies to contour on circular contours |
G65 | Feedrate applies for tool centre path |
G66 | Feedrate/spindle speed can be modified via pot. |
G68 | Auxiliary arc on outside corners |
G69 | Intersection on outside corners |
G74 | Referencing |
G75 | Measuring probe |
G80 | Cancel fixed cycles G81 to G89 |
G81 | Drilling, centering |
G82 | Boring with dwell |
G83 | Deep hole drilling with positioning movements in rapid |
G84 | Tapping with dwell |
G85 | Boring with dwell/oriented spindle stop |
G86 | Reaming |
G87 | Thread milling |
G90 | Input in absolute dimensions |
G91 | Input in incremental dimensions |
G92 | Setting position stores / Setting top limit for spindle speed |
G93 | Time programming |
G94 | Feedrate direct in mm/min |
G95 | Feedrate in mm/rev |
G96 | Automatic calculation of cutting speed |
G97 | Direct spindle speed programming |
G99 | Subprogram end |
G800 to G869 | Customer cycles: call-up via G-functions with corresponding numbers |
G890 | Intersection circle/circle |
G891 | Intersectin line/circle |
G892 | Rounding corners (3 points) |
G893 | Rounding corners (2 angles) |
G894 | Chamfering |
G895 | Calculation of end point of arc |
G896 | Transition point arc/arc tangential |
G897 | End point of straight line |
G898 | Intersection line/line |
