C.B.Ferrari Elexa E560 G Codes complete list for cnc machinists who work on C.B.Ferrari cnc machining centers.
C.B.Ferrari E560 G Codes
G Code | Description |
G0 | Rapid positioning of the axes in linear interpolation on the plane and in the space in the programmed point. |
G1 | Work in linear interpolation in the plane and in the space in the programmed point. |
G2 | Circular interpolation clockwise on the chosen plane or helix |
G3 | Work in circular interpolation anticlockwise on the chosen plane or helix. |
G4 | Dwell Time programmed with spindle revolutions (G4/n) or in tenths of a second (G4/s time in sec./10) |
G5-G7-G9 | G functions recognized only for reasons of compatibility with CNC 132 160. They are executed like G0. |
G10-G11 | Given to the geometrical programming. |
G13-G16 | Given to the geometrical programming. |
G17 | Specifies X Y as the machining plane (where Z is the perpendicular axis) active at the start. |
G18 | Specifies X Z as the machining plane (where Y is the perpendicular axis). |
G19 | Specifies Y Z as the machining plane (where X is the perpendicular axis). |
G20-G25 | For the geometrical programming. |
G26 | Feedrate on the tool tip also for rotary axes. |
G27 | Real feedrate of the axes (for rotary DEGREES/MIN). |
G30 | Cancel G31 function |
G31 | Active working way (active at the start) Feed on the tip of tool. |
G38 | Defines ways of copy alternately at parameters given in VCP table (OPTION) |
G39 | Spindle positioning with angle M from 0° to 360°. |
G40 | Positioning with Cancel Cutter Radius compensation |
G41 | Tool Approaching during the work with introduction of radius tool correction on the left of the programmed path. |
G42 | Tool approaching during the work with introduction of radius tool correction on the right on the programmed path. |
G43 | Grinding cycle, like G41 and introduction of an oscillatory movement on the axis orthogonal at the work plane. |
G44 | Grinding cycle like G42 with introduction of an oscillatory movement on the orthogonal at the work plane axe. |
G45 | Pick up automatic tool cycle (subroutine). |
G47 | Release automatic tool cycle (subroutine). |
G49 | Function of connection programs in memory. |
G50 | Cancel G51. |
G51 | Rotation-translation according to programmed point (X,Y,E) |
G55 | Rotation cycle rotary head without adjustment of the plane with the rotation angle. |
G56 | Rotation cycle rotary head with adjustment of the plane with the rotation angle |
G58 | Rounding off 360° on rotary axes with absolute measuring system |
G59 | Return from subroutine |
G60 | Cancel G 61. |
G61 | Scale factor for X Y Z axes. |
G62 | Cancel G63 |
G63 | High speed milling with smooth trajectory |
G65-G69 | Given to digitizing cycles |
G70-G71 | Inch-Metric Modes |
G75-G77 | Given to digitizing cycles |
G79 | Given to the digitizing cycles |
G80 | Cancel canned cycles from G81 to G 89. |
G81 | Drilling cycle |
G82 | Drilling cycle (the same as G81) |
G83 | Deep hole drilling cycle |
G84 | Tapping cycle |
G85 | Deep hole drilling cycle with high return |
G86 | Boring cycle with spindle stop. |
G87 | Boring cycle (the same as G86) |
G88 | Drilling cycle for more walls |
G89 | Reverse boring cycle |
G90-G93 | G function not recognized |
G94 | Feedrate in mm/min. (Active at the start) |
G95 | Feedrate in micron/spindle revolution. |
G96 | Boring cycle with detachment from wall |
G97 | Macro instruction for milling circle or a thread |
G99 | Input M functions or messages with Stopped axes |
G300 | Measuring tool length cycle (option). |
G301 | Verifying tool length cycle with stop (option). |
G302 | Verifying tool length cycle with automatic research of substitutive tool (option). |
G303 | Measuring tool radius cycle (option). |
G304 | Verifying tool radius cycle with stop (option). |
G305 | Verifying tool radius cycle with automatic research of substitutive tool (option). |
G306 | Measuring tool length and radius cycle (option). |
G311 | Feeler adjustment of the coefficients (option). |
G312 | Zero recovery on a pin (option). |
G313 | Zero recovery on a hole (option). |
G314 | Zero recovery on Z (option). |
G316 | Redefinition axes CNC IND function |
G317 | Redistribution axes function |
G318 | Definition tern axes feeler function |
G319 | Assignation synonyme axes function |
G320 | Disable the G321. |
G321 | Q increase sum abilitation. |
G322 | Disable the grinding cycle. |
G323 | Enable the grinding cycle. |
G324 | Exclusion of the axes repositioning with LNS. |
G325 | Zero recovery on a square (option). |
G326 | Zero recovery on a edge (option). |
G327 | Origins and tools lengths management. |
G328 | Delta length correction on the tools table. |
G329 | Delta radius correction on the tools table. |
G330 | GPF repositioning. |
G331 | Recovery G31 function with GPF. |
G332 | Recovery G32 function with GPF. |
G335 | Enable the registration of the machine quotas on disk. |
G336 | Disable the registration of the machine quotas on disk. |
G340 | Radius correction in profile from part-program. |
G341 | Radius correction in profile from table. |
G342 | Activation of the Delta L on the tool length. |
G343 | Cancels G342. |
G344 | Activation of the Delta R on the radius tool. |
G345 | Cancels G344. |
G346 | Automatic substitution of the tool with time expires. |
G349 | Subroutine. |
G350 | Dividing table axis initials modification. |
G351 | Roto-translation. |
G352 | Save the axes locking and lock all the axes. |
G353 | Restore the axes locking saved with G352. |
G354 | Activation of the matrix rotation on the programmed points. |
G355 | Rotation cycle rotary head without adjustment of the head length (option). |
G356 | Rotation cycle rotary head with adjustment of the plane with the rotation angle (Option). |
G359 | Return to the calling program for files activated with G349. |
G360 | Work by N.U.R.B.S. with 3 to 5 axes movement. |
G362 | Introduction of the polygonal vertex in digitizing (option). |
G363 | Introduction of the depth in digitizing (option). |
G364 | Introduction of the second polygonal (option). |
G370-G376 | Digitizing cycles (option). |
G377 | Length tools pre-setting qualification (option). |
G378 | Radius tools pre-setting qualification (option). |
G384 | Rigid tapping cycle (option). |
G390 | Predisposition for the programming in absolutes quotas. |
G391 | Cancels the G390. |
G392 | ON/OFF feeler zero recovery on a pin (option). |
G393 | ON/OFF feeler zero recovery on a hole (option). |
G394 | ON/OFF feeler zero recovery in Z (option). |
G395 | ON/OFF feeler zero recovery on a square (option). |
G396 | ON/OFF feeler zero recovery on an edge (option). |
G398 | Piece research with ON/OFF feeler and quotas determination (option). |
G399 | Rapid to 5 mm from the positive Z axes limit. |
G428/ | Pick-up piece function (option). |
G429/ | Pick-up piece function (option). |
G500 | Measuring tool length cycle with manual tool change (option). |
G503 | Measuring tool radius cycle with manual tool change (option). |
G506 | Measuring tool length and radius cycle with manual tool change (option). |
G550 | Configuration automatic re-establishment. |
G551 | Configuration automatic change. |
G571-G578 | Digitizing cycles (option). |
G731 | Tool radius compensation in space with zero on the tool point. |
G703 | Tail-stock forward with reduced air pressure (optional) |
G704 | Tail-stock forward with normal air pressure (optional) |
G705 | Tailstock backward (optional) |
G740 | Cancels G748. |
G746 | Origins translation and rotation associated to the table rotation. |
G748 | Origins translation associated to the table rotation. |
G751 | 3D Translation. |
G752 | 3D Rotation. |
G755 | Head rotation in centre of spherical tools . |
