G Code | Description |
G0 | Rapid Traverse (linear) |
G1 | Linear Interpolation |
G2 | Circular/Helical CW |
G2.01 | Circular/Helical CW (absolute) |
G2.02 | Circular/Helical CW (incremental) |
G3 | Circular/Helical CCW |
G3.01 | Circular/Helical CCW (absolute) |
G3.02 | Circular/Helical CCW (incremental) |
G4 | Dwell |
G7.1 | Cylindrical Interpolation |
G8 | Suppress Interpolation |
G9 | Exact Stop |
G12 | Contouring Rotary Axis Unwind |
G13.1 | Cylindrical Interpolation Off |
G15.1 | Polar Coordinate Programming (bolt circle) |
G15.2 | Polar Coordinate Programming (part contour) |
G17 | XY Plane Select |
G18 | YZ Plane Select |
G19 | ZX Plane Select |
G22, 22.1 | Milling Cycle Rectangular Face |
G23, 23.1 | Milling Cycle Rectangular Pocket |
G24, 24.1 | Milling Cycle Rectangular Inside Frame |
G25, 25.1 | Milling Cycle Rectangular Outside Frame |
G26 | Milling Cycle Circular Face |
G26.1 | Milling Cycle Circular Pocket |
G27 | Milling Cycle Circular Inside Frame |
G27.1 | Milling Cycle Circular Outside Frame |
G28 | Auto Return to Reference Point |
G29 | Auto Return From Reference Point |
G36 | Move to Next Operation Location |
G36.1 | Test for End of Pattern |
G37 | Cancel Pattern |
G38 | Rectangular Pattern |
G39 | Circle Pattern |
G40 | Cutter Diameter Compensation OFF |
G41 | Cutter Diameter Compensation On LEFT |
G42 | Cutter Diameter Compensation On RIGHT |
G43 | PQR Cutter Diameter Compensation On |
G45 | Acceleration/Deceleration ON |
G45.01, 45.02, 45.03 | User Specific Acceleration |
G45.1 | Acceleration/Deceleration ON (Die Roughing) |
G45.2 | Acceleration/Deceleration ON (Die Finishing) |
G46 | Acceleration/Deceleration OFF |
G50 | Pallet Coordinates |
G51 | Probe Multiple Axes |
G51.1 | Vector Probe Surface and Set Offsets |
G51.2 | Rotary Axis measurement |
G51.3 | Angle Measurement in X or Y Plane |
G51.4 | Measure feature to feature XY Plane |
G51.5 | Measure feature to Feature Z Plane |
G52 | Local Coordinate System |
G60 | Positioning Mode |
G61 | Contouring Mode |
G61.1 | Automatic Corner Speed Override (Left) |
G61.2 | Automatic Corner Speed Override (Right) |
G68 | Tool Probe Cycle Set Tool Length |
G69 | Tool Probe Cycle Check Tool Length |
G70 | Inch Programming |
G71 | Metric Programming |
G72 | Set Stylus and Tip Dimension |
G73 | Set Probe Stylus Tip Dimension |
G74 | Set Probe Length |
G75 | Locate Internal Corner |
G76 | Locate External Corner |
G77 | Locate Surface |
G77.1 | Stock Allowance |
G78 | Locate and Measure Bore or Boss |
G79 | Measure Pocket or Web |
G80 | Reset Fixed Cycle |
G81 | Drill Cycle |
G82 | Counterbore/Spot Drill with Dwell Cycle |
G83 | Deep Hole Drill (Peck Drill) Cycle |
G84 | Tap Cycle (Conventional) |
G84.1 | Rigid Tap Cycle |
G85 | Bore/Ream Cycle |
G86 | Bore Cycle |
G87 | Back Bore Cycle |
G88 | Web Drill/Bore Cycle |
G89 | Bore/Ream with Dwell Cycle |
G90 | Absolute Dimension Input |
G91 | Incremental Dimension Input |
G92 | Position Set |
G92.1 | Position Sets Setup Offset |
G92.2 | Position Sets Pallet Offset |
G93 | Inverse Time Feedrate (1/T) |
G94 | Feed Per Minute Feedrate Mode |
G95 | Feed Per Revolution Feedrate Mode |
G96 | Constant Surface Speed |
G97 | Constant Spindle Speed (S = RPM) |
G97.1 | Constant Spindle Speed (S = Surface Speed) |
G98 | Machine Coordinates (tool tip) |
G98.1 | Machine Coordinates |
G99 | Position Set Cancel |
G150 | Scaling OFF |
G151 | Scaling ON |
