M Code | Function |
M00 | Program stop |
M01 | Optional stop |
M02 | 1 cycle stop (Stop the machine when under the 1 cycle mode.) |
M03 | Spindle forward rotation |
M04 | Spindle reverse rotation |
M05 | Spindle stop |
M06 | Chuck close |
M07 | Chuck open |
M08 | Short cut program insertion ON (Starts the end cut program of bar material) |
M09 | Short cut program insertion OFF (Ends the end cut program of bar material) |
M10 | Knock out ON (Forward move of back side knock out bar) |
M11 | Knock out OFF (Reverse move of back side knock out bar) |
M13 | Close ling workpiece chuck |
M14 | Open long workpiece chuck |
M15 | Close back chuck |
M16 | Open back chuck |
M18 | Spindle zero point return and C axis gear ON (Preparation for C axis control) |
M20 | Reset C axis selection (End of C axis control) |
M23 | Back spindle forward rotation |
M24 | Back spindle reverse rotation |
M25 | Back spindle stop |
M31 | Turret speed selection (low-speed swing) |
M32 | Forward move of workpiece separator (back side) |
M33 | Reverse move of workpiece separator (back side) |
M46 | Y axis clutch OFF (Allows the axis move) |
M47 | Y axis clutch ON (It must not be used except when Y=0) |
M50 | Back pick-off inferiority detection (Rotate the spindle at low speed to set M50 after cut-off) |
M51 | Tool break detection (Detects the tool by the switch) |
M52 | Coolant ON |
M53 | Coolant OFF |
M54 | Bar feeder stop (Used when replacing the material.) |
M55 | Bar feeder material replacement start (Starts replacement of the bar feeder material.) |
M56 | Product count |
M61 | External M code 1 |
M62 | External M code 2 |
M63 | External M code 2 |
M64 | External M code 4 |
M65 | External M code 5 |
M72 | Back spindle air blow ON |
M73 | Back spindle air blow OFF |
M74 | C axis zero point deceleration dummy timer (to be used with M74G28H1;) |
M75 | Back spindle torque control (L) ON (25% the rated torque (same as M123)) |
M77 | Waiting for spindle synchronization to end |
M78 | Back spindle indexing |
M79 | Back spindle indexing OFF |
M80 | Tool #1 spindle forward rotation |
M81 | Tool #1 spindle reverse rotation |
M82 | Tool #1 spindle stop |
M83 | Tool #2 spindle forward rotation |
M84 | Tool #2 spindle reverse rotation |
M85 | Tool #2 spindle stop |
M88 | Interference check OFF (reset) |
M89 | Interference check ON |
M94 | Back spindle variation detection ON |
M95 | Back spindle variation detection OFF |
M96 | Spindle variation detection ON |
M97 | Spindle variation detection OFF |
M98 | Subprogram call |
M99 | Program return |
M123 | Back spindle torque limit (H) ON (When cut-off with the spindle and back spindle synchronization with each other. To stop the workpiece to slip in the chuck by the rotation error.) |
M124 | Back spindle torque limit OFF |
M125 | Citizen side used within the macro. |
M126 | Citizen side used within the macro. |
M127 | Citizen side used within the macro. |
