CNC machining with 5000 RPMs and with high coolant pressure, what else a cnc machinist want, CLEAR VIEW of what is happening inside machine. Yes of course due to high coolant pressure and due to high RPMs you are unable to see through the cnc machine window.
As modern machines prevent the door being opened during operation for safety reasons, which makes it difficult for cnc machinists/operators to view operations and cutting conditions.
Observing the actual machining process in the CNC machine without being impacted by coolant or chips can optimise manufacturers’ processes and improve working ergonomics and productivity.
Especially during intensive coolant use, clear visibility can increase workers’ productivity by reducing the time taken for setup and prove-out.
Dimac Tooling offers the integration of one of the most modern intelligent spin window solutions, the Pioneer rotary wiper spin window.
The spin window is designed to provide visibility into machines with coolant system pressures of up to 80 bar, such as those found on through-tool coolant delivery systems.
The systems help address safety concerns because users have no need to bypass machine interlocks. Operators can view the process while remaining behind the safety window of the machine.
Source dimac
