CNC Machine Lock
CNC Machine Lock
CNC machine lock is very handy function for testing a cnc program before actually making a part.
In machine lock axis stay stationary on their positions, but the their positions change with program on the display, this way cnc machinists can figure out any problems before making the part.
There are two types of machine lock:
  • all-axis machine lock, which stops the movement along all axes.
  • specified-axis machine lock, which stops the movement along specified axes only.
To activate machine lock, press the machine lock switch on the operator’s panel. The tool does not move but the position along each axis changes on the display as if the tool were moving.
CNC Machine Lock Auxiliary Function Lock Functions
Some machines have a machine lock switch for each axis. On such machines, press the machine lock switches for the axes along which the tool is to be stopped.
CAUTION
The positional relationship between the workpiece coordinates and machine coordinates may differ before and after automatic operation using machine lock. In such a case, specify the workpiece coordinate system by using a coordinate setting command or by performing manual reference position return.
Auxiliary function lock disables M, S, and T commands, is available for checking a program together with machine lock.
