Now a day CAD and CAM software make our lives just easier and easier, you just not have to calculate a single point in drawing, every thing is just ready. But it is a good practice to know actually how the calculations are being done, if not all but some which are necessary for a CNC programmer.
CNC Program Example G03 Circular Interpolation
The calculation of G02 G03 circular interpolation values is a good technique to learn. This CNC program tells not all but a little of course enough for the beginner CNC programmer and CNC students.
Contents
CNC Program With G03 Circular Interpolation
N1 G00 X0 Z0 N2 G01 X11 N3 G01 Z-15 N4 G03 X11 Z-27 I-8 K-6
Description
The I and K for the G03.
I Calculation for G03 Circular Interpolation
I is the distance from the arc start point to arc center point in x-axis. This value is not given in diameter but as a radius value, so
- Find the start diameter it is 11
- Now make it radius value by dividing it by 2 such as 11 / 2 = 5.5
- This is a easy example in way that the arc center point distance from the workpiece center point is given other wise we have to calculate it.
- So now just add 2.5 in 5.5 earlier calculated 2.5 + 5.5 = 8
- This is the value of I 8 this is the distance from the arc start point to the ace center point.
K Calculation for G03 Circular Interpolation
K is the distance from the arc start point to arc center point in z-axis.
- In this example it is just easy as you just have to subtract 21 from 15 such as 21 – 15 = 6.
- So the value from the arc start point to the arc center point in z-axis is 6
