Here is another cnc programming example, this time I am programming for an arc with I K values.
The cnc G code G02 Circular Interpolation Clockwise is used in this programming example. Actually the arc is clockwise, therefore I am using G02 the cnc G code for programming the Clockwise arc.
Related Articles:
- CNC G02 Circular Interpolation Clockwise CNC Milling Sample Program
- CNC Circular Interpolation Tutorial G02 G03
- CNC Program Example G03 Circular Interpolation
CNC Programming Example G Code G02
CNC Programming Example G Code G02 Circular Interpolation Clockwise
N10 T0101 N20 G92 S1000 M42 N30 G96 S200 M03 N40 G00 X0 Z5 N50 G01 Z0 F0.5 N60 G01 X80 F0.2 N70 G02 X100 Z-30 I50 K0 N80 G01 Z-120 N90 G00 X200 Z200 M30
Explanation of CNC Code
- G92 : Spindle speed limitation.
- G96 : Constant surface speed.
- G02 : Circular Interpolation Clockwise.
G02 Explanation
G02 has some values with it in cnc programming block like x, z, I, K.
- X : End point of arc in x-axis.
- Z : End point of arc in z-axis.
- I : Distance from arc start point to arc center point in x-axis.
- K : Distance from arc start point to arc center point in z-axis.
