Doosan MX series M-code list for cnc machinists/programmers. M-Codes for both Upper unit and lower unit are given.
Doosan MX Series CNC
This list of M-codes works for the following cnc machines,
Doosan PUMA series
- MX2000, MX2000L/T/LT/S/LS/LST
- MX2500, MX2500L/T/LT/S/LS/LST
- MX3000, MX3000S
Doosan MX Series M-Code List
M-Code | UPPER UNIT | LOWER UNIT |
M00 | PROGRAM STOP | PROGRAM STOP |
M01 | OPTIONAL PROGRAM STOP | OPTIONAL PROGRAM STOP |
M02 | PROGRAM END | PROGRAM END |
M03 | LEFT SPINDLE FORWARD ROTATION | LEFT SPINDLE FORWARD ROTATION |
M04 | LEFT SPINDLE REVERSE ROTATION | LEFT SPINDLE REVERSE ROTATION |
M05 | LEFT SPINDLE STOP & SELECTION | LEFT SPINDLE STOP & SELECTION |
M06 | ATC TOOL CHANGE COMMAND | |
M07 | BED SHOER COOLANT ON | BED SHOER COOLANT ON |
M08 | COOLANT ON (UPPER SIDE) | COOLANT ON (UPPER SIDE) |
M09 | COOLANT OFF (UPPER SIDE) | COOLANT OFF (UPPER SIDE) |
M10 | PARTS UNLOADER DOWN TO CHUCK | PARTS UNLOADER DOWN TO CHUCK |
M11 | PARTS UNLOADER RETURN TO HOME | PARTS UNLOADER RETURN TO HOME |
M12 | COOLJECT ON (UPPER SIDE) | COOLJECT ON (UPPER SIDE) |
M13 | LEFT SPINDLE COOLANT BLOWER OFF | LEFT SPINDLE COOLANT BLOWER OFF |
M14 | LEFT SPINDLE AIR BLOW ON | LEFT SPINDLE AIR BLOW ON |
M15 | LEFT SPINDLE AIR BLOW OFF | LEFT SPINDLE AIR BLOW OFF |
M16 | BED SHOER COOLANT OFF | BED SHOER COOLANT OFF |
M17 | MACHINE LOCK ACT | MACHINE LOCK ACT |
M18 | MACHINE LOCK CANCEL | MACHINE LOCK CANCEL |
M19 | LEFT SPINDLE ORIENTATION | LEFT SPINDLE ORIENTATION |
M20 | GANTRY LOADER CALL | GANTRY LOADER CALL |
M21 | OPTIONAL BLOCK SKIP ACT | |
M22 | OPTIONAL BLOCK SKIP CANCEL | |
M23 | PROGRAM START CHECK | PROGRAM START CHECK |
M24 | CHIP CONVEYOR RUN | CHIP CONVEYOR RUN |
M25 | CHIP CONVEYOR STOP | CHIP CONVEYOR STOP |
M26 | T.S.C COOLANT ON (MILLING SPINDLE) | |
M27 | T.S.C COOLANT OFF (MILLING SPINDLE) | |
M28 | POLYGON MODE SELECT | POLYGON MODE SELECT |
M29 | RIGID TAPPING MODE SELECT | RIGID TAPPING MODE SELECT |
M30 | PROGRAM END & REWIND | PROGRAM END & REWIND |
M31 | LEFT CHUCKING INTERLOCK BY-PASS | LEFT CHUCKING INTERLOCK BY-PASS |
M33 | MILLING SPINDLE FORWARD ROTATION | REVOLVING SPINDLE FORWARD ROTATION |
M34 | MILLING SPINDLE REVERSE ROTATION | REVOLVING SPINDLE REVERSE ROTATION |
M35 | MILLING SPINDLE STOP & C1-AXIS SELECT | REVOLVING SPINDLE STOP & C1-AXIS SELECT |
M45 | MILLING SPINDLE HEAD TOOL NO, EXTERNAL SET | |
M46 | P.T.S.BODY CLAMP & BAR ADVANCE | |
M47 | P.T.S.BODY UNCLAMP & BAR RETRACT | |
M48 | ||
M49 | MILLING SPINDLE ORIENTATION | |
M50 | BAR-FEEDER COMMAND 1 | BAR-FEEDER COMMAND 1 |
M51 | BAR-FEEDER COMMAND 2 | BAR-FEEDER COMMAND 2 |
M52 | FRONT SPLASH GUARD DOOR OPEN | FRONT SPLASH GUARD DOOR OPEN |
M53 | FRONT SPLASH GUARD DOOR CLOSE | FRONT SPLASH GUARD DOOR CLOSE |
M54 | PARTS COUNT | PARTS COUNT |
M55 | REPEAT PROGRAM AFTER M02 / M30 | REPEAT PROGRAM AFTER M02 / M30 |
M56 | TAPPING MODE SELECT | TAPPING MODE SELECT |
M57 | TAPPING MODE CANCEL | TAPPING MODE CANCEL |
M58 | STEADY REST CLAMP | |
M59 | STEADY REST UNCLAMP | |
M60 | TOOL CHANGE WITH MOVING AXES | |
M61 | LEFT SPINDLE WINDING CHANGE LOW SPEED | LEFT SPINDLE WINDING CHANGE LOW SPEED |
M62 | LEFT SPINDLE WINDING CHANGE HIGH SPEED | LEFT SPINDLE WINDING CHANGE HIGH SPEED |
M63 | LEFT SPINDLE FORWARD & UPPER COOLANT ON | LEFT SPINDLE FORWARD & UPPER COOLANT ON |
M64 | LEFT SPINDLE REVERSE & UPPER COOLANT ON | LEFT SPINDLE REVERSE & UPPER COOLANT ON |
M65 | LEFT SPINDLE STOP & UPPER COOLANT OFF | LEFT SPINDLE STOP & UPPER COOLANT OFF |
M66 | LEFT CHUCKING LOW PRESSURE | RIGHT CHUCKING LOW PRESSURE |
M67 | LEFT CHUCKING HIGH PRESSURE | RIGHT CHUCKING HIGH PRESSURE |
M68 | LEFT CHUCK CLAMP | LEFT CHUCK CLAMP |
M69 | LEFT CHUCK UNCLAMP | LEFT CHUCK UNCLAMP |
M70 | TAIL STOCK QUILL LOW PRESSURE ADVANCE | TAIL STOCK QUILL LOW PRESSURE ADVANCE |
M72 | SPINDLE CONVERT ROTATION DIRECTION | SPINDLE CONVERT ROTATION DIRECTION |
M73 | SPINDLE NORMAL ROTATION DIRECTION | SPINDLE NORMAL ROTATION DIRECTION |
M74 | ERROR DETECT ON | ERROR DETECT ON |
M75 | ERROR DETECT OFF | ERROR DETECT OFF |
M76 | CHAMFERING ON | CHAMFERING ON |
M77 | CHAMFERING OFF | CHAMFERING OFF |
M78 | TAIL STOCK QUILL ADVANCE | TAIL STOCK QUILL ADVANCE |
M79 | TAIL STOCK QUILL RETRACT | TAIL STOCK QUILL RETRACT |
M80 | Q-SETTER SWING ARM DOWN | Q-SETTER SWING ARM DOWN |
M81 | Q-SETTER SWING ARM UP | Q-SETTER SWING ARM UP |
M82 | TOUCH PROBE ON | TOUCH PROBE ON |
M83 | TOUCH PROBE OFF | TOUCH PROBE OFF |
M84 | TURRET C.W. ROTATION | |
M85 | TURRET C.C.W. ROTATION | |
M86 | LOWER A-AXIS TORQUE SKIP | |
M87 | LOWER A-AXIS TORQUE SKIP CANCEL | |
M88 | C1-AXIS LOW PRESSURE CLAMP | C1-AXIS LOW PRESSURE CLAMP |
M89 | C1-AXIS HIGH PRESSURE CLAMP | C1-AXIS HIGH PRESSURE CLAMP |
M90 | C1-AXIS UNCLAMP | C1-AXIS UNCLAMP |
M91 | EXTERNAL M-CODE M91 | EXTERNAL M-CODE M91 |
M92 | EXTERNAL M-CODE M92 | EXTERNAL M-CODE M92 |
M93 | EXTERNAL M-CODE M93 | EXTERNAL M-CODE M93 |
M94 | EXTERNAL M-CODE M94 | EXTERNAL M-CODE M94 |
M98 | SUB PROGRAM CALL | SUB PROGRAM CALL |
M99 | END OF SUB PROGRAM | END OF SUB PROGRAM |
M100 | MILLING SPINDLE CLAMP | |
M101 | MILLING SPINDLE UNCLAMP | |
M103 | RIGHT SPINDLE FORWARD ROTATION | RIGHT SPINDLE FORWARD ROTATION |
M104 | RIGHT SPINDLE REVERSE ROTATION | RIGHT SPINDLE REVERSE ROTATION |
M105 | RIGHT SPINDLE STOP & SELECTION | RIGHT SPINDLE STOP & SELECTION |
M106 | B-AXIS CURVIC COUPLING CLAMP | |
M107 | B-AXIS CURVIC COUPLING UNCLAMP | |
M108 | T.S.C COOLANT ON (LEFT SPINDLE) | T.S.C COOLANT ON (LEFT SPINDLE) |
M109 | T.S.C COOLANT OFF(LEFT SPINDLE) | T.S.C COOLANT OFF(LEFT SPINDLE) |
M110 | B-AXIS DISC CLAMP | |
M111 | B-AXIS DISC UNCLAMP | |
M112 | B-AXIS CURVIC & DISC CLAMP | |
M113 | B-AXIS CURVIC & DISC UNCLAMP | |
M114 | RIGHT SPINDLE AIR BLOW ON | RIGHT SPINDLE AIR BLOW ON |
M115 | RIGHT SPINDLE AIR BLOW OFF | RIGHT SPINDLE AIR BLOW OFF |
M116 | WORK EJECTOR OPERATION COMMAND | WORK EJECTOR OPERATION COMMAND |
M117 | LOWER A-AXIS TORQUE CONTROL ON | |
M118 | LOWER A-AXIS TORQUE CONTROL RESET | |
M119 | RIGHT SPINDLE ORIENTATION | RIGHT SPINDLE ORIENTATION |
M121 | LOWER Z2-AXIS TORQUE CONTROL ON | |
M124 | LOWER Z2-AXIS TORQUE CONTROL RESET | |
M125 | SYNCHRO CONTROL WITH Z2-AXIS | |
M126 | SYNCHRO CONTROL CANCEL | |
M131 | RIGHT CHUCKING INTERLOCK BY-PASS | RIGHT CHUCKING INTERLOCK BY-PASS |
M135 | MILLING SPINDLE STOP & C2 AXIS SELECTION | REVOLVING SPINDLE STOP & C2 AXIS SELECTION |
M138 | ROOF SHOWER COOLANT ON | |
M139 | ROOF SHOWER COOLANT OFF | |
M144 | ATC WAITING POT RETRACT | |
M145 | ATC WAITING POT ADVANCE | |
M146 | ATC WAITING POT CHANGE POSITION | |
M147 | ATC WAITING POT HOME POSITION | |
M148 | ATC WAITING POT HOME POSITION CHECK | |
M149 | ATC MAINTENANCE MODE ON | |
M150 | ATC MAINTENANCE MODE OFF | |
M151 | ATC CHANGER START FLAG | |
M152 | ATC 1 CYCLE | |
M153 | ATC DOOR OPEN | |
M154 | ATC DOOR CLOSE | |
M155 | AUTO MILLING SPINDLE ORIENTATION | |
M156 | V-GROOVE AIR ON | |
M157 | ATC CHANGER MOTOR BRAKE RELEASE | |
M158 | ATC CHANGER MOTOR BRAKE ENGAGE | |
M159 | ||
M160 | ||
M161 | RIGHT SPINDLE WINDING CHANGE LOW SPEED | RIGHT SPINDLE WINDING CHANGE LOW SPEED |
M162 | RIGHT SPINDLE WINDING CHANGE HIGH SPEED | RIGHT SPINDLE WINDING CHANGE HIGH SPEED |
M163 | RIGHT SPINDLE FORWARD & UPPER COOLANT ON | RIGHT SPINDLE FORWARD & LOWER COOLANT ON |
M164 | RIGHT SPINDLE REVERSE & UPPER COOLANT ON | RIGHT SPINDLE REVERSE & LOWER COOLANT ON |
M165 | RIGHT SPINDLE STOP & UPPER COOLANT OFF | RIGHT SPINDLE STOP & LOWER COOLANT OFF |
M168 | RIGHT CHUCK CLAMP | RIGHT CHUCK CLAMP |
M169 | RIGHT CHUCK UNCLAMP | RIGHT CHUCK UNCLAMP |
M170 | INTERFERENCE CHECK RELEASE | INTERFERENCE CHECK RELEASE |
M171 | INTERFERENCE CHECK RELEASE CANCEL | INTERFERENCE CHECK RELEASE CANCEL |
M172 | Y-AXIS REFERENCE INTERLOCK RELEASE | |
M173 | Y-AXIS REFERENCE INTERLOCK RELEASE CANCEL | |
M174 | AUTO B-AXIS UN/CLAMP OFF & B-AXIS UNCLAMP | |
M175 | AUTO B-AXIS UN/CLAMP ON & B-AXIS CLAMP | |
M188 | C2-AXIS LOW PRESSURE CLAMP | C2-AXIS LOW PRESSURE CLAMP |
M189 | C2-AXIS HIGH PRESSURE CLAMP | C2-AXIS HIGH PRESSURE CLAMP |
M190 | C2-AXIS UNCLAMP | C2-AXIS UNCLAMP |
M192 | SIMUL.FEEDRATE ON(BALANCE CUTTING) | SIMUL.FEEDRATE ON(BALANCE CUTTING) |
M193 | SIMUL.FEEDRATE OFF(BALANCE CUTTING) | SIMUL.FEEDRATE OFF(BALANCE CUTTING) |
M194 | ||
M200 | TOOL LOAD MONITOR OFF | TOOL LOAD MONITOR OFF |
M201 | TOOL LOAD MONITOR ON | TOOL LOAD MONITOR ON |
M203 | SPINDLE FORWARD SPEED SYNCHRO COMMAND | SPINDLE FORWARD SPEED SYNCHRO COMMAND |
M204 | SPINDLE REVERSE SPEED SYNCHRO COMMAND | SPINDLE REVERSE SPEED SYNCHRO COMMAND |
M205 | SPINDLE SYNCHRO STOP COMMAND | SPINDLE SYNCHRO STOP COMMAND |
M206 | SPINDLE SYNCHRO RELEASE COMMAND | SPINDLE SYNCHRO RELEASE COMMAND |
M208 | SPINDLE SPEED & PHASE CONFRIM COMMAND | SPINDLE SPEED & PHASE CONFRIM COMMAND |
M209 | SPINDLE SPEED CONFIRM COMMAND | SPINDLE SPEED CONFIRM COMMAND |
M210 | PARTS UNLOADER WAITING IN LEFT CHUCK | PARTS UNLOADER WAITING IN LEFT CHUCK |
M211 | COMPOSITE CONTROL ACT | COMPOSITE CONTROL ACT |
M212 | COMPOSITE CONTROL CANCEL | COMPOSITE CONTROL CANCEL |
M213 | SPINDLE FORWARD PHASE SYNCHRO COMMAND | SPINDLE FORWARD PHASE SYNCHRO COMMAND |
M214 | SPINDLE REVERSE PHASE SYNCHRO COMMAND | SPINDLE REVERSE PHASE SYNCHRO COMMAND |
M215 | TURRET UNCLAMP BEFORE T-CODE COMMAND | |
M217 | Z2-AXIS INTERLOCK(A-AXIS REF) RELEASE | |
M218 | Z2-AXIS INTERLOCK(A-AXIS REF) RELEASE CANCEL | |
M220 | UPPER X-AXIS INTERLOCK RELEASE | |
M221 | UPPER X-AXIS INTERLOCK RELEASE CANCEL | |
M226 | WORK EJECTER ADVANCE | WORK EJECTER ADVANCE |
M227 | WORK EJECTER RETRACT | WORK EJECTER RETRACT |
M230 | PARTS UNLOADER STOPPER RETURN | PARTS UNLOADER STOPPER RETURN |
M231 | PARTS UNLOADER STOPPER ADVANCE | PARTS UNLOADER STOPPER ADVANCE |
M232 | PARTS UNLOADER BODY ADVANCE | PARTS UNLOADER BODY ADVANCE |
M233 | PARTS UNLOADER BODY RETURN | PARTS UNLOADER BODY RETURN |
M234 | PARTS UNLOADER BUCKET DOWN | PARTS UNLOADER BUCKET DOWN |
M235 | PARTS UNLOADER BUCKET RETURN | PARTS UNLOADER BUCKET RETURN |
M236 | PARTS UNLOADER ARM DOWN | PARTS UNLOADER ARM DOWN |
M237 | PARTS CATCHER ARM RETURN | PARTS CATCHER ARM RETURN |
M250 | MACHINE MAINTENANCE MODE ON | MACHINE MAINTENANCE MODE ON |
M251 | MACHINE MAINTENANCE MODE OFF | MACHINE MAINTENANCE MODE OFF |
M252 | TOOL CHANGE AREA INTERLOCK OFF | |
M253 | TOOL CHANGE AREA INTERLOCK OFF CANCEL | |
M254 | A-AXIS INTERLOCK IGNORE | |
M255 | A-AXIS INTERLOCK IGNORE CANCEL | |
M256 | PARTS UNLOADER CONTINUOS ACT W/RIGHT CHUCK | PARTS UNLOADER CONTINUOS ACT W/RIGHT CHUCK |
M289 | CANNED CYCLE ON WITH M89,M90 OF LEFT C1-AXIS | CANNED CYCLE ON WITH M89,M90 OF LEFT C1-AXIS |
M296 | DYNAMIC RADIUS/DIAMETER CONVERT ON | DYNAMIC RADIUS/DIAMETER CONVERT ON |
M297 | DYNAMIC RADIUS/DIAMETER CONVERT CANCEL | DYNAMIC RADIUS/DIAMETER CONVERT CANCEL |
M300 | Z-AXIS MIRROR IMAGE ON | Z-AXIS MIRROR IMAGE ON |
M301 | Z-AXIS MIRROR IMAGE OFF | Z-AXIS MIRROR IMAGE OFF |
M308 | T.S.C COOLANT ON (RIGHT SPINDLE) | T.S.C COOLANT ON (RIGHT SPINDLE) |
M309 | T.S.C COOLANT OFF(RIGHT SPINDLE) | T.S.C COOLANT OFF(RIGHT SPINDLE) |
M310 | PARTS UNLOADER WAITING IN RIGHT CHUCK | PARTS UNLOADER WAITING IN RIGHT CHUCK |
M311 | PARTS UNLOADER RETRACT FROM RIGHT CHUCK | PARTS UNLOADER RETRACT FROM RIGHT CHUCK |
M312 | LEFT SPINDLE COOLANT BLOWER ON | LEFT SPINDLE COOLANT BLOWER ON |
M313 | RIGHT SPINDLE COOLANT BLOWER OFF | RIGHT SPINDLE COOLANT BLOWER OFF |
M314 | RIGHT SPINDLE COOLANT BLOWER ON | RIGHT SPINDLE COOLANT BLOWER ON |
M315 | LEFT SPINDLE STOP (NOT CONFIRM) | LEFT SPINDLE STOP (NOT CONFIRM) |
M316 | Z2-AXIS CURRENT LOAD READ (MINUS) | |
M317 | Z2-AXIS CURRENT LOAD READ (PLUS) | |
M320 | GANTRY LOADER CALL | GANTRY LOADER CALL |
M325 | RIGHT SPINDLE STOP (NOT CONFIRM) | RIGHT SPINDLE STOP (NOT CONFIRM) |
M326 | A-AXIS CURRENT LOAD READ | |
M389 | CANNED CYCLE ON WITH M189,M190 OF RIGHT C2-AXIS | CANNED CYCLE ON WITH M189,M190 OF RIGHT C2-AXIS |
M900 | WAITING M-CODE | WAITING M-CODE |
