Doosan TT Series Alarms
Alarm list for Doosan TT Series cnc machining centers/cnc lathe.
Doosan TT Series CNC
Alarms work for the following cnc machines,
Doosan PUMA series
  • TT1500MS/SY
  • TT1800MS/SY
  • TT2000SY
  • TT2500MS/SY
Doosan Puma TT2000SY Twin Spindle CNC Lathe
Doosan TT Series Alarm List
AlarmMessage
2001WHETHER EMERGENCY BUTTON IS PRESSED OR OVERTRAVEL OF AXES IS DETECTED, RELEASE EMERGENCY BUTTON AND LIMIT SWITCH FOR OVERTRAVEL CHECK.
2002THE ALARMS OF THE LEFT SPINDLE MOTOR AND SERVO UNIT DETECTED, CHECK ALARM DISPLAY ON THE SERVO UNIT THEN RETRY AFTER POWER OFF-ON.
2003OVERCURRENT IN THE CONTROL POWER CIRCUIT, ABNORMALLY LARGE CURRENT FLOW IS DETECTED IN THE CONTROL POWER CIRCUIT, CHECK FOR CONTROL POWER SHORT CIRCUIT.
2004HYD. PUMP MOTOR OVERLOAD IS DETECTED, CHECK OVERLOAD VALUE ON THE THERMAL RELAY AND MOTOR.
2005HYD. PRESSURE IS DOWN, CHECK HYD. PRESSURE SWITCH, PRESSURE VALUE AND LEAKAGE OF HYDRAULIC.
2006HYD.PUMP MOTOR IS NOT RUN, CHECK DGN.(Y) AND MOTOR STARTER (-KM31).
2007SPINDLE ROTATION IS ABNORMAL.
2008GEAR SHIFT LIMIT SWITCH IS ABNORMALLY OPERATING AS SWITCHS OPERATE SIMULTANEOUSLY.
2009THE ALARMS OF THE RIGHT SPINDLE MOTOR AND SERVO UNIT DETECTED, CHECK ALARM DISPLAY ON THE SERVO UNIT THEN RETRY AFTER POWER OFF-ON.
2010OIL LEVEL OF GEAR BOX IS LOW, CHECK THE OIL LEVEL OF GEAR BOX.
2011KEEP RELAY ALARM OF MACHINE SELECTION. PLEASE CHECK THE KEEP RELAY(K9,K9 & K9)
2016PSM POWER RUNNING ALARM. PLEASE CHECK AUXILLARY CONTACT ON THE MAGNETIC CONTACTOR (KM10, KM110).
2017SPINDLE OIL OVERFLOW, CHECK LEVEL S/W OR OIL DRAIN MOTOR.
2019MACHINE MODEL SELECTION DATA IS SETTED ABNORMALLY, CHECK.DGN(K9,K9,K9).
2020COOLANT & LUB. PUMP MOTOR OVERLOAD OR Q11 FOR SERVO TURRET, CHIP CONVEYOR AND BAR FEEDER OVERLOAD IS DETECTED.
2021TORQUE LIMIT SKIP COMMAND(M86,M87) IS INDICATED INCORRECTLY.
2022SPINDLE ORIENTATION CONFIRM IS NOT DETECTED WITHIN 15SEC, CHECK ORIENTATION PARAMETER AND READJUST. ORIENTATION INDEX COMMAND ALARM.
2023EACH TOOL INDEXING IS NOT FINISHED WITHIN 7SEC AFTER TOOLINDEX COMMAND.(MANUAL OR AUTO).
2024TOOL CHANGE COMMAND ALARM. PLEASE CHECK TOOL COMMAND NUMBER OR PROGRAM STATE. IN ADDITION, TOOL COMMAND IS NOT AVAILABLE ON POLYGON MODE.
2025TOOL NUMBER SELECTION DATA IS SETTED ABNORNALLY, CHECK DGN(K6-B1,K6-B2).
2026GEAR SHIFT IS NOT FINISHED WITHIN 15SEC, REMOVE CAUSE AND PUSH ALARM RESET BUTTON.
2027SPINDLE SPEED ARRIVAL IS NOT DETECTED WITHIN 7SEC, CHECK SPINDLE SERVO UNIT.
2028SPINDLE ROTATION CONDITION IS NOT READY, CHECK SPINDLE ROTATION CONDITION.
2029SPLASH GUARD DOOR IS OPEN, CHECK SPLASH GUARD DOOR OPEN ANDLIMIT SWITCHES.
2030M17 OR M18 IS COMMANDED IN ILLEGAL MODE, PLEASE CONFIRM MDI MODE.
2031PLEASE MANUAL REF.POINT RETURN, OTHERWISE AUTO.OPERATION IS IMPOSSIBLE.
2032FEEDHOLD PUSH BUTTON IS PRESSED.
2033AIR OR COOLANT PRESSURE SWITCH IS DOWN.
2034PROXIMITY SWITCH FOR CHUCK CLAMP CONFIRM POSITION ERROR, RESET SWITCH POSITION (PX1.M) (PX2.M)
2035AXIS CHANGE OVERTIME.
2036M68/M168 OR M69/M169 IS NOT FINISHED WITHIN 15SEC AFTER COMMAND, CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2037M78 OR M79 IS NOT FINISHED, WITHIN 15SEC AFTER COMMAND, CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2038M10 OR M11 COMMAND ALARM, CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2039PARTS UNLOADER OVERTIME ALARM, CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2040M50 OR M51 IS NOT FINISHED, WITHIN 15SEC AFTER COMMAND, CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2041THE ALARMS OF THE BARFEEDER IS DETECTED, CHECK BAR-FEEDER.
2042M52, M53, M152 OR M153 IS NOT FINISHED, WITHIN 15SEC AFTER COMMAND, CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2044THE PARTS CATCHER IS ADVANCED, EVEN THOUGH M10 IS NOT COMMANDED.
2045M80 OR M81 COMMAND ALARM.
2046CHUCK IS OPENED DURING THE SPINDLE ROTATION, CHECK HYD.PRESSURE.
2047TURRET CLAMP SWITCH ALARM. IN THE MACHINE, CHECK KEEP RELAY 5.4 IS SET TO 0 OR CHECK TURRET CLAMP SWITCH.
2048THE RESET COMMAND IS USED WHILE PROGRAM IS RUNNING.
2049M88/M188,M89/M189,M90/M190 COMMAND ALARM. CHECK SOLENOID VALVE, POSITION SWITCH AND OPERATION CONDITION.
2050LUB.PRESSURE IS DOWN OR LUBRICATION OIL LEVEL IS LOW,CHECK LUB.UNIT AND REPLENISH THE OIL.
2051COOLANT LEVEL LOW IS CHECK, REPLENISH THE COOLANT.
2052M61 OR M62 IS NOT FINISHED WITHIN 15SEC AFTER COMMAND. PLEASE CHECK INITIAL CONDITION.
2053M116,M120 COMMAND ALARM. PLEASE CHECK THE SWITCHS, THE WORKPIECE AND OPERATION CONDITION. OR CUTTING POSITION BY M202 IS ERROR. PLEASE CKECK THE CUTTING STATE.
2054REV.-TOOL IS NOT ENGAGED WITHIN 3SEC, CHECK REV.-TOOL STATE.
2055ILLEGAL SYNCHRO INITIAL STATE IS DETECTING . PLEASE CHECK CHUCK STATE.
2056M206 IS NOT USED. PLEASE COMMAND M206.
2057TOOL LIFE COUNT END ALARM.
2058PARTS COUNT END ALARM.
2059M,T-CODE COMMAND ALARM IN B-AXIS CONTROL. CHECK WHICH PROPER M-CODE OR T-CODE IS USED IN B-AXIS MACHINING PROGRAM AND THEN CHECK SOLENOID VALVE OR SWITCH FOR M-CODE EXECUTION. CHECK THE SAME M-CODE IS EXECUTING I
2060CHUCK UNCLAMP STATUS.
2061SAFETY LOCKING SWITCH ALARM. PLEASE CHECK CONDITION OF THE LOCKING KEY SWITCH OR WIRE CONDITION THAT IS CONNECTING BETWEEN NO.11 AND NO.12 IN SAFET LOCKING SWITCH.
2062LIMIT SWITCH FOR PROGRAMABLE TAILSTOCK IS NOT OPERATED WITHN 5SEC AFTER COMMAND, CHECK SOLENOID VALVES AND LIMIT SWITCHES.
2063PROXIMITY SWITCH FOR Q-SETTER IS NOT OPERATED WITHIN 5SEC AFTER COMMAND, CHECK SOLENOID VALVES AND PROXIMITY SWITCHES.
2064M66 OR M67 COMMAND ON THE M/C, THE NEXT M03 OR M04 COMMAND.
2065TURRET TOOL NO.DETECTION ENCODER SIGNAL DISCONNECT.
2066CHECK POSITION DETECTING SWITCHES ARE OPERATED SIMULTANEOUSLY, CHECK SWITCH.
2067THE TOOL AND REV.SPINDLE INDEXING CONDITION ALARM. CHECK CONFIRMATION SWITCH IN TOOL POST UNIT.
2068RETURN B-AXIS TO THE REFERENCE POINT FOR MOVING Z2-AXIS OR COMMAND M217 TO RELEASE Z2 AXIS INTERLOCK.
2069COOLANT FILTER CHANGE ALARM
2070SPINDLE CAMMAND IS ABNORMAL. CHANGE SPINDLE COMMAND AFTER SPINDLE STOP(M05/M35/M135/M65/M105/M165).
2071CHIP CONVEYOR ALARM CHIP CONVEYOR ALARM
2072TORQUE CONTROL ALARM.
2073THIS COMMAND CANNOT BE PERFORMED. PLEASE PERFORM THE REF. POSITION RETURN OF X & Y-AXIS BEFORE THIS COMMAND.
2074IN HANDLE MODE, CAN’T CHANGE TOOL OFFSET WITH Q-SETTER. PLEASE, CHANGE MODE TO JOG MODE AND TRY AGAIN.
2075TRANSFERRING WITH FEED FROM THE TURRET UNCLAMP CONDITION WHICH IS IMPOSSIBLE.
2076TOOL SPINDLE OVERLOAD ALARM, PLEASE CHECK CUTTING CONDITION IN PROGRAM.
2077RETURN THE REFERENCE POINT OF X1 AND X2-AXIS AND RETURN THE ARM OF PART UNLOADER TO RETURN POSITION FOR MOVING B-AXIS.
2078OIL COOLER ALARM.
2079C-AXIS BRAKE NOT RELEASED, PLEASE CHECK C-AXIS UNCLAMP SOLENOIDE VALVE AND PRESSURE SWITCH.
2081GANTRY LOADER SERVO IS NOT READY
2082THERE ARE LOADER AXES INSIDE OF MACHINE. M80, M10, M03, M04, M63, M64, M78, M103, M104, M203, M204 AND T-CODE IS INVALID. MOVE Y-AXIS OF LOADER TO PLUS DIRECTION. THIS ALARM CAN BE RESET BY ONLY PRESSING NC RESET
2083THERE ARE LOADER AXES INSIDE OF MACHINE. Q-SETTER DOWN, PARTS CATCHER ADVANCE, TAIL STOCK QUILL ADVANCE, TOOL INDEX, SPINDLE ROTATION, AND AXIS MOVING BESIDE OF HANDLE IS INVALID. MOVE Y-AXIS OF LOADER TO PLUS DI
2084B-AXIS OR Z1 AXIS MOVING ALARM. WHEN THE DISTANCE BETWEEN B-AXIS AND Z1 AXIS IS SHORTER THAN D1112,B-AXIS OR Z1 AXIS MOVING IS IMPOSSIBLE.
2088LUBRICATION OIL LEVEL IS LOW.
2089SERVO TURRET BATTERY LOW ALARM, PLEASE CHANGE BATTERY IN AMP. MODULE WITHIN 2 WEEKS.
2090PROGRAM RESTART PUSH BUTTON SWITCH ON STATE.
2091THE SPINDLE SWITCHING IS INVALID IN RIGID TAPPING MODE. CANCEL RIGID TAPPING MODE TO SWITCH OTHER SPINDLE.
2093REFERENCE COMMAND FROM REFERENCE POSITION KEEP STATE.
2094HIGH LOW CHUCK SWITCHING STATE. OPERATE CHUCK AS UNCLAMPING AND CLAMPING BY FOOT SWTCH.
2095RIGID TAPPING OR ORIENTATION COMMAND ALARM. M19 OR M119, M29 IS INVALID ON G96 MODE. PLEASE MODIFY PROGRAM.
2096FEEDRATE OVERRIDE 0%.
2097MACHINE LOCK ON STATUS.
2100MACHINE IS IN SERVICE MODE. 1)MACHINE WILL OPERATE WITH DOOR OPEN. 2)SPINDLE WILL NOT START UNLESS THE DOOR IS CLOSED.3)TAPPING OR THREADING MAY NOT WORK UNLESS THE DOOR IS CLOSED.
2101PLEASE, CLOSE THE DOOR
2102M310/M311 COMMAND CONDITION :B-AXIS AND X1,X2-AXIS ARE IN REFT. POINT, THE MACHINE COORDINATE OF Z1-AXIS MUST BE LESS THAN THE SETTING VALUE OF PARAMETER 6932(ONLY UPPER UNIT).
2104CHECK HOME POSITION OF EACH UNIT FOR PARTS CATCHER(STOPPER ADV:X9.7, BODY RET:X11.2, BUCKET RET:X11.7, ARM RET:X22.7)
2106RIGHT SPINDLE ROTATION STATE. PLEASE SPINDLE STOP.
2107PROGRAM START M FUNCTION ALARM. PLEASE CHECK M-CODE (M23).
2108SPINDLE WARM UP IS REQUESTED.
2109SPINDLE WARM UP IS COMPLETED.
2110CONSTANT SURFACE CONTROL COMMAND ALARM.IN COMPOSITION CONTROL MODE, THE CONSTANT SURFACE CONTROL COMMAND FROM LOWER(UPPER) MUST BE COMMANDED AFTER MILLING ROTATING COMMAND FROM UPPER(LOWER).
2111SPINDLE COMMAND ALARM. AFTER SPINDLE SELECTION, SPINDLE ROTATION COMMAND IS VALID(M05/M35/M105/M135).IF SPINDLE TO SELECT IS ROTATING, MUST BE STOP SPINDLE TO SELECT BEFORE SPINDLE SELECTION COMMAND.
2112C-AXIS HIGH/LOW CLAMP OR UNCLAMP M-COMMAND CONDITION ALARM. THE M88 OR M89,M90(M188 OR M189,M190) COMMAND OF THE OTHER PATH IS VALID IN COMPOSITION CONTROL STATE.
2113RETURN THE REFERENCE POINT OF X AND Z-AXIS BEFORE TOOL CHANGE COMMAND.TOOL CHANGE INTERLOCK CAN BE OVERRIDDEN BY M-COMMAND(M252=INTERLOCK DISABLE & M253=INTERLOCK ENABLE).
2114ATFER MAIN POWER OFF/ON, C1 AND C2 AXES MUST BE RETURN REF.POINT BY MANUAL, OTHERWISE AUTO.OPERATION IS IMPOSSIBLE.
2115WHEN PARTS UNLOADER IS OPERATIING BY M310 COMMAND,THE Z1-AXIS CAN MOVE ONLY IF THE MACHINE COORDINATE OF Z1-AXIS IS LESS THAN THE SETTING VALUE OF PARAMETER 6932(ONLY UPPER UNIT)
2116LEFT SPINDLE RIGID TAPPING IS VALID ONLY FOR THE UPPER TURRET AND RIGHT SPINDLE RIGID TAPPING IS VALID ONLY FOR THE LOWER TURRET.
2117PROGRAM RESTART ERROR BY OPTIONAL STOP. MUST BE IN STATE OF UPPER/LOWER UNIT AND MEM MODE TO RESTART PROGRAM STOPPED BY OPSIONAL STOP ON MEM MODE.
2118PLEASE, CHECK Q-SETTER CAP.
2119NOT USE REV.(ROTARY) SPINDLE OPERATION AT THE HALF STATION(13-24).
2120WHEN PARTS CATCHER IS OPERATIING BY M10 COMMAND, THE MACHINE COORDINATE OF Z2-AXIS MUST BE MORE THAN THE SETTING VALUE OF PARAMETER 6951(ONLY LOWER UNIT).
2121THE PART UNLOADER IS NOT IN HOME POSITION. SET THE PART UNLOADER TO HOME POSITION.
2122TURRET CONTROL UNIT ALARM. CHECK SERVO CONTORL UNIT IN CONTROL CABINET.
2123COOLANT LEVEL IS LOW, REPLENISH COOLANT.
2124Z,B,Y-AXIS INTERLOCK FUNCTION OFF. FOR Z,B,Y-AXIS INTERLOCK FUNCTION ON, SET K55.3 TO 0.
2125MOVE X=30000 ON MACHINE COORDINATE.AND SET Y-AXIS REF.POINT.
2126THIS COMMAND CANNOT BE PERFORMED. PLEASE PERFORM THE REF. POSITION RETURN OF YAXIS BEFORE THIS COMMAND.
2149COMPOSITION CONTROL COMMAND ALARM. AFTER SELECT C2-AXIS(M135)FROM UPPER OR C1-AXIS(M35) FROM LOWER, M211 COMMAND IS POSSIBLE.
2150B-AXIS MOVEMONT IS PROHIBITED IN CHUCKING CLOSED CONDITION.
