Doosan TT series M-code list for cnc machinists/programmers. M-Codes for both Upper unit and lower unit are given.
Doosan TT Series CNC
This list of M-codes works for the following cnc machines,
Doosan PUMA series
- TT1500MS/SY
- TT1800MS/SY
- TT2000SY
- TT2500MS/SY
Doosan TT Series M-Code List
M-Code | UPPER UNIT | LOWER UNIT |
M00 | U-PROGRAM STOP | L-PROGRAM STOP |
M01 | U-OPTIONAL STOP | L-OPTIONAL STOP |
M02 | U-PROGRAM END | L-PROGRAM END |
M03 | U-LEFT SPINDLE FORWARD | L-LEFT SPINDLE FORWARD |
M04 | U-LEFT SPINDLE REVERSE | L-LEFT SPINDLE REVERSE |
M05 | U-LEFT SPINDLE STOP | L-LEFT SPINDLE STOP |
M06 | U-COOL JET ON | L-COOL JET ON |
M07 | U-COOLANT FLUSING ON | L-COOLANT FLUSING ON |
M08 | U-COOLANT ON | L-COOLANT ON |
M09 | U-COOLANT OFF | L-COOLANT OFF |
M10 | U-LEFT PARTS CATCHER RECEIVE ADV. | L-LEFT PARTS CATCHER RECEIVE ADV. |
M11 | U-LEFT PARTS CATCHER RECEIVE RET. | L-LEFT PARTS CATCHER RECEIVE RET. |
M12 | U-LEFT COOLANT BLOWER ON | L-LEFT COOLANT BLOWER ON |
M13 | U-LEFT COOLANT BLOWER OFF | L-LEFT COOLANT BLOWER OFF |
M14 | U-LEFT SPINDLE AIR BLOW ON | L-LEFT SPINDLE AIR BLOW ON |
M15 | U-LEFT SPINDLE AIR BLOW OFF | L-LEFT SPINDLE AIR BLOW OFF |
M16 | U-COOLANT FLUSING OFF | L-COOLANT FLUSING OFF |
M17 | U-M/C LOCK ACT | L-M/C LOCK ACT |
M18 | U-M/C LOCK CANCEL | L-M/C LOCK CANCEL |
M19 | U-LT SPINDLE ORIENTATION | L-LT SPINDLE ORIENTATION |
M21 | U-OPTIONAL BLOCK SKIP ON | L-OPTIONAL BLOCK SKIP ON |
M22 | U-OPTIONAL BLOCK SKIP CANCEL | L-OPTIONAL BLOCK SKIP CANCEL |
M24 | U-CHIP CONVEYOR START | L-CHIP CONVEYOR START |
M25 | U-CHIP CONVEYOR STOP | L-CHIP CONVEYOR STOP |
M28 | U-POLYGON MODE ON | L-POLYGON MODE ON |
M29 | U-RIGID TAPPING ON | L-RIGID TAPPING ON |
M30 | U-PROGRAM END & REWIND | L-PROGRAM END & REWIND |
M31 | U-LT SPINTERLOCK BY PASS(SPDL.T/S) | L-LT SPINTERLOCK BY PASS(SPDL.T/S) |
M33 | U-REV.SPINDLE FORWARD | L-REV.SPINDLE FORWARD |
M34 | U-REV.SPINDLE REVERSE | L-REV.SPINDLE REVERSE |
M35 | U-REV.SPINDLE STOP OR REV. SPINDLE(C1-AXIS) SELECTION | L-REV.SPINDLE STOP OR REV. SPINDLE(C1-AXIS) SELECTION |
M46 | ||
M47 | ||
M50 | U-BAR FEEDER COMMAND 1 | L-BAR FEEDER COMMAND 1 |
M51 | U-BAR FEEDER COMMAND 2 | L-BAR FEEDER COMMAND 2 |
M52 | U-SPLASH GUARD DOOR OPEN | L-SPLASH GUARD DOOR OPEN |
M53 | U-SPLASH GUARD DOOR CLOSE | L-SPLASH GUARD DOOR CLOSE |
M54 | U-PARTS COUNT | L-PARTS COUNT |
M55 | U-PROGRAM RESTART ON | L-PROGRAM RESTART ON |
M56 | U-TAPPING MODE SELECT | L-TAPPING MODE SELECT |
M57 | U-TAPPING MODE CANCEL | L-TAPPING MODE CANCEL |
M60 | U-TOOL INDEX & AXIS MOVE | L-TOOL INDEX & AXIS MOVE |
M61 | U-LEFT WINDING CHANGE M-CODE(LOW) | L-LEFT WINDING CHANGE M-CODE(LOW) |
M62 | U-LEFT WINDING CHANGE M-CODE(HIGH) | L-LEFT WINDING CHANGE M-CODE(HIGH) |
M63 | U-LT SP. FORWARD & COOLANT ON | L-LT SP. FORWARD & COOLANT ON |
M64 | U-LT SP. REVERSE & COOLANT ON | L-LT SP. REVERSE & COOLANT ON |
M65 | U-LT SP.STOP & COOLANT OFF | L-LT SP.STOP & COOLANT OFF |
M68 | U-LEFT CHUCK CLAMP | L-LEFT CHUCK CLAMP |
M69 | U-LEFT CHUCK UNCLAMP | L-LEFT CHUCK UNCLAMP |
M72 | U-REV.SPINDLE DIR. CONVERT | L-REV.SPINDLE DIR. CONVERT |
M73 | U-REV.SPDL DIR. CONVERT CANCEL | L-REV.SPDL DIR. CONVERT CANCEL |
M74 | U-ERROR DETECT ON | L-ERROR DETECT ON |
M75 | U-ERROR DETECT OFF | L-ERROR DETECT OFF |
M76 | U-CHAMFERING ON | L-CHAMFERING ON |
M77 | U-CHAMFERING OFF | L-CHAMFERING OFF |
M78 | ||
M79 | ||
M80 | U-Q SETTER DOWN COMMAND | L-Q SETTER DOWN COMMAND |
M81 | U-Q SETTER UP COMMAND | L-Q SETTER UP COMMAND |
M84 | U-TURRET CW ROTATION | L-TURRET CW ROTATION |
M85 | U-TURRET CCW ROTATION | L-TURRET CCW ROTATION |
M86 | U-TORQUE LIMIT SKIP ON | |
M87 | U-TORQUE LIMIT SKIP CANCEL 1 | |
M88 | U-LEFT SPINDLE LOW CLAMP | L-LEFT SPINDLE LOW CLAMP |
M89 | U-LEFT SPINDLE HIGH CLAMP | L-LEFT SPINDLE HIGH CLAMP |
M90 | U-LEFT SPINDLE UNCLAMP | L-LEFT SPINDLE UNCLAMP |
M91 | U-EXTERNAL M91 | L-EXTERNAL M91 |
M92 | U-EXTERNAL M92 | L-EXTERNAL M92 |
M93 | U-EXTERNAL M93 | L-EXTERNAL M93 |
M94 | U-EXTERNAL M94 | L-EXTERNAL M94 |
M98 | U-SUB PROGRAM CALL | L-SUB PROGRAM CALL |
M99 | U-PROGRAM END or RE-START | L-PROGRAM END or RE-START |
M103 | U-RIGHT SPINDLE FORWARD | L-RIGHT SPINDLE FORWARD |
M104 | U-RIGHT SPINDLE REVERSE | L-RIGHT SPINDLE REVERSE |
M105 | U-RIGHT SPINDLE STOP | L-RIGHT SPINDLE STOP |
M108 | U-THROUGH THE SPINDLE COOALNT ON | L-THROUGH THE SPINDLE COOALNT ON |
M109 | U-THROUGH THE SPINDLE COOALNT OFF | L-THROUGH THE SPINDLE COOALNT OFF |
M112 | U-RIGHT COOLANT BLOWER ON | L-RIGHT COOLANT BLOWER ON |
M113 | U-RIGHT COOLANT BLOWER OFF | L-RIGHT COOLANT BLOWER OFF |
M114 | U-RIGHT SPINDLE AIR BLOW ON | L-RIGHT SPINDLE AIR BLOW ON |
M115 | U-RIGHT SPINDLE AIR BLOW OFF | L-RIGHT SPINDLE AIR BLOW OFF |
M116 | U-WORK EJECTOR ADVANCE | L-WORK EJECTOR ADVANCE |
M117 | B-AXIS TROQUE CONROL ON | L-Z2 AXIS TROQUE CONROL ON |
M118 | B-AXIS TROQUE CONROL CANCEL | L-Z2 AXIS TROQUE CONROL CANCEL |
M119 | U-RT SPINDLE ORIENTATION | L-RT SPINDLE ORIENTATION |
M131 | U-RT SPINTERLOCK BY PASS(SPDL.T/S) | L-RT SPINTERLOCK BY PASS(SPDL.T/S) |
M135 | U-REV.SPINDLE STOP OR REV. SPINDLE(C2-AXIS) SELECTION | L-REV.SPINDLE STOP OR REV. SPINDLE(C2-AXIS) SELECTION |
M161 | U-RIGHT WINDING CHANGE M-CODE(LOW) | L-RIGHT WINDING CHANGE M-CODE(LOW) |
M162 | U-RIGHT WINDING CHANGE M-CODE(HIGH) | L-RIGHT WINDING CHANGE M-CODE(HIGH) |
M163 | U-RIGHT SP. FORWARD & COOLANT ON | L-RIGHT SP. FORWARD & COOLANT ON |
M164 | U-RIGHT SP. REVERSE & COOLANT ON | L-RIGHT SP. REVERSE & COOLANT ON |
M165 | U-RT SP.STOP & COOLANT OFF | L-RT SP.STOP & COOLANT OFF |
M168 | U-RIGHT CHUCK CLAMP | L-RIGHT CHUCK CLAMP |
M169 | U-RIGHT CHUCK UNCLAMP | L-RIGHT CHUCK UNCLAMP |
M170 | U-UPPER TURRET INTERFEARNCE CHECK OFF | |
M171 | U-UPPER TURRET INTERFEARNCE CHECK ON | |
M186 | PART UNLOADER INTERLOCK CANCEL (ONLY TT15/18) | |
M187 | PART UNLOADER INTERLOCK CANCEL OFF (ONLY TT15/18) | |
M188 | U-RIGHT SPINDLE LOW CLAMP | L-RIGHT SPINDLE LOW CLAMP |
M189 | U-RIGHT SPINDLE HIGH CLAMP | L-RIGHT SPINDLE HIGH CLAMP |
M190 | U-RIGHT SPINDLE UNCLAMP | L-RIGHT SPINDLE UNCLAMP |
M192 | U-SYN. FEEDRATE CONTROL ON | L-SYN. FEEDRATE CONTROL ON |
M193 | U-SYN. FEEDRATE CONTROL OFF | L-SYN. FEEDRATE CONTROL OFF |
M195 | U-RIGHT SPINDLE P.C USE | L-LEFT SPINDLE P.C USE |
M196 | U-RIGHT SPINDLE P.C RETURN | L-LEFT SPINDLE P.C RETURN |
M200 | U-TOOL MONITOR OFF | L-TOOL MONITOR OFF |
M201 | U-TOOL MONITOR ON | L-TOOL MONITOR ON |
M203 | U-SPEED SYN. CONTROL FORWARD | L-SPEED SYN. CONTROL FORWARD |
M204 | U-SPEED SYN. CONTROL REVERSE | L-SPEED SYN. CONTROL REVERSE |
M205 | U-SYN. CONTROL STOP | L-SYN. CONTROL STOP |
M206 | U-SYN. CONTROL RELEASE | L-SYN. CONTROL RELEASE |
M208 | U-SYN. PHASE OK | L-SYN. PHASE OK |
M209 | U-SYN. SPEED & ARRIVAL OK | L-SYN. SPEED & ARRIVAL OK |
M211 | U-C AXIS COMPOSITION ON | L-C AXIS COMPOSTION ON |
M212 | U-C AXIS COMPOSITION OFF | L-C AXIS COMPOSTION OFF |
M213 | U-SPEED&PHASE SYN. CONTROL FWD. | L-SPEED&PHASE SYN. CONTROL FWD. |
M214 | U-SPEED&PHASE SYN. CONTROL RVS. | L-SPEED&PHASE SYN. CONTROL RVS. |
M215 | U-UPPER TURRET UNCLAMP | L-LOWER TURRET UNCLAMP |
M226 | U-WORK EJECTER ADVANCE | U-WORK EJECTER ADVANCE |
M227 | U-WORK EJECTER RETRACT | U-WORK EJECTER RETRACT |
M230 | U-PTC STOPPER RET. | L-PTC STOPPER RET. |
M231 | U-PTC STOPPER ADV. | L-PTC STOPPER ADV. |
M232 | U-PTC BODY ADV. | L-PTC BODY ADV. |
M233 | U-PTC BODY RET. | L-PTC BODY RET. |
M234 | U-PTC BUCKET ADV. | L-PTC BLCKET ADV. |
M235 | U-PTC BUCKET RET. | L-PTC BLCKET RET. |
M236 | U-PTC ARM ADV. | L-PTC ARM ADV. |
M237 | U-PTC ARM RET. | L-PTC ARM RET. |
M252 | U-TOOL CHANGE INTERLOCK OFF | L-TOOL CHANGE INTERLOCK OFF |
M253 | U-TOOL CHANGE INTERLOCK ON | L-TOOL CHANGE INTERLOCK ON |
M254 | U- CHUK CLAMP MOVE INTERLOCK RELEASE | L- CHUK CLAMP MOVE INTERLOCK RELEASE |
M255 | U- CHUK CLAMP MOVE INTERLOCK ON | L- CHUK CLAMP MOVE INTERLOCK ON |
M256 | U- PARTS UNLOADER CONTINUOUS OPERATION | L- PARTS UNLOADER CONTINUOUS OPERATION |
M289 | U- LEFT SPINDLE HIGH CLAMP CONTROL | L- LEFT SPINDLE HIGH CLAMP CONTROL |
M389 | U-RIGHT SPINDLE HIGH CLAMP CONTROL | L-RIGHT SPINDLE HIGH CLAMP CONTROL |
M310 | U-RIGHT PARTS CATCHER RECEIVE ADV. | L-RIGHT PARTS CATCHER RECEIVE ADV. |
M311 | U-RIGHT PARTS CATCHER RECEIVE RET. | L-RIGHT PARTS CATCHER RECEIVE RET. |
M315 | U-LEFT SPINDLE STOP(NOT CONFIRM) | L-LEFT SPINDLE STOP(NOT CONFIRM) |
M318 | U-CHUCK UNCLAMP & WORK EJECTOR ON (ONLY TT15/18) | L-CHUCK UNCLAMP & WORK EJECTOR ON (ONLY TT15/18) |
M325 | U-RIGHT SPINDLE STOP(NOT CONFIRM) | L-RIGHT SPINDLE STOP(NOT CONFIRM) |
M900 | U-WAITING M-CODE (M900~M999) | L-WAITING M-CODE (M900~M999) |
