Fagor 800M 800T programming G codes / M codes complete lists.
Fagor 800M G Codes M Codes
Fagor 800M programming G codes / M codes complete lists.
G Codes
G Codes | Description |
G00 | Rapid positioning |
G01 | Linear interpolation |
G02 | Clockwise circular interpolation |
G03 | Counter-clockwise circular interpolation |
G04 | Dwell |
G05 | Round corner |
G06 | Circular interpolation with absolute center coordinates |
G07 | Square corner |
G08 | Arc tangent to previous path |
G09 | Arc defined by three points |
G10 | Cancellation of mirror image |
G11 | Mirror image on X |
G12 | Mirror image on Y |
G13 | Mirror image on Z |
G17 | XY plane selection |
G18 | XZ plane selection |
G19 | YZ plane selection |
G20 | Call to a standard subroutine |
G21 | Call to a parametric subroutine |
G22 | Identification of a standard subroutine |
G23 | Identification of a parametric subroutine |
G24 | End of subroutine |
G25 | Unconditional jump/call |
G26 | Jump/Call if equal to 0 |
G27 | Jump/Call if not equal to 0 |
G28 | Jump/Call if smaller than |
G29 | Jump/Call if equal to or greater than |
G30 | Display error code |
G31 | Store coordinate origin |
G32 | Recover coordinate origin previously stored with G31 |
G36 | Automatic radius blend |
G37 | Tangential entry |
G38 | Tangential exit |
G39 | Chamfer |
G40 | Cancelation of tool radius compensation |
G41 | Left-hand tool radius compensation |
G42 | Right-hand tool radius compensation |
G43 | Tool length compensation |
G44 | Cancellation of tool length compensation |
G47 | Single-Block treatment: ON |
G48 | Single-Block treatment: OFF |
G49 | Programmable feedrate override % |
G50 | Load tool dimensions into tool offset table |
G53/G59 | Zero offsets |
G67 N0 P202=K0 | Point to point positioning canned cycle |
G67 N0 P202=K1 | Linear positioning canned cycle |
G67 N0 P202=K2 | Rectangular positioning canned cycle |
G67 N0 P202=K3 | Grid pattern positioning canned cycle |
G67 N0 P202=K4 | Arc positioning canned cycle |
G67 N1 P202=K0 | Inside rectangular pocket milling canned cycle |
G67 N1 P202=K1 | Inside circular pocket milling canned cycle |
G67 N2 P202=K0 | Outside rectangular pocket milling canned cycle |
G67 N2 P202=K1 | Outside circular pocket milling canned cycle |
G67 N3 | Surface milling canned cycle |
G67 N4 | Corner roughing canned cycle |
G67 N6 | Drilling canned cycle |
G67 N7 | Tapping canned cycle |
G67 N8 | Boring and reaming canned cycle |
G67 N9 | Center punching canned cycle |
G70 | Inch programming |
G71 | Metric programming (in mm) |
G72 | Scaling factor |
G73 | Pattern rotation |
G74 | Machine Reference (Home) search |
G90 | Programming in absolute coordinates |
G91 | Programming in incremental coordinates |
G92 | Coordinate preset |
G93 | Polar origin preset |
M Codes
M Codes | Description |
M00 | Program stop |
M01 | Conditional stop of program |
M02 | End of program |
M30 | End of program with return to beginning |
M03 | Clockwise start of the spindle |
M04 | Counter-clodwise start of the spindle |
M05 | Spindle stop |
M06 | Tool change code |
M19 | Analog S output (creep) for tool change and spindle orientation |
M10, M11 | Associated to external device O1 |
M12, M13 | Associated to external device O2 |
M14, M15 | Associated to external device O3 |
Fagor 800T G Codes M Codes
Fagor 800T programming G codes / M codes complete lists.
G Codes
G04 | Dwell |
G33 | Threadcutting |
G39 | Chamfer |
G51 | Correct tool dimensions |
G66 | Pattern repeat (roughing canned cycle following part’s shape) |
G67 N0 | Turning canned cycle |
G67 N1 | Facing canned cycle |
G67 N2 | Taper turning canned cycle |
G67 N3 | Threading canned cycle |
G67 N4 | Rounding canned cycle |
G67 N5 | Grooving canned cycle |
G67 N6 | Simple drilling canned cycle |
G67 N7 | Multiple drilling canned cycle |
G67 N8 | Slot milling canned cycle |
G68 | Roughing canned cycle along the X axis |
G69 | Roughing canned cycle along the Z axis |
G75 | Probing |
G81 | Turning canned cycle for straight sections |
G82 | Facing canned cycle for straight sections |
G84 | Turning canned cycle for circular sections |
G85 | Facing canned cycle for circular sections |
G86 | Longitudinal threadcutting canned cycle |
G92 | Coordinate preset / Maximum S value limit setting |
G94 | Axis feedrate F in mm/min. (0.1 inch/min.) |
G95 | Axis feedrate F in mm/rev. (0.1 inch/rev.) |
G96 | S speed in m/min. (ft/min.) (Constant Surface Speed) |
G97 | S speed in rev./min. |
M Codes
M19 | Spindle orientation |
M20 | End of part-program execution |
M41,M42,M43,M44 | Spindle range selection |
M45 | Selection of rotation speed of the live tool |
