Fanuc 0i / 0i Mate Alarm Codes for CNC machinists.
Contents
Fanuc 0i Alarms
Program errors (P/S alarm)
Program errors /Alarms on program and operation (P/S alarm)
- 0 PLEASE TURN OFF POWER
- 1 TH PARITY ALARM
- 2 TV PARITY ALARM
- 3 TOO MANY DIGITS
- 4 ADDRESS NOT FOUND
- 5 NO DATA AFTER ADDRESS
- 6 ILLEGAL USE OF NEGATIVE SIGN
- 7 ILLEGAL USE OF DECIMAL POINT
- 9 ILLEGAL ADDRESS INPUT
- 10 IMPROPER G–CODE
- 11 NO FEEDRATE COMMANDED
- 14 CAN NOT COMMAND G95 (M series)
- 14 ILLEGAL LEAD COMMAND (T series)
- 15 TOO MANY AXES COMMANDED (M series)
- 15 TOO MANY AXES COMMANDED (T series)
- 20 OVER TOLERANCE OF RADIUS
- 21 ILLEGAL PLANE AXIS COMMANDED
- 22 NO CIRCLE RADIUS
- 23 ILLEGAL RADIUS COMMAND (T series)
- 25 CANNOT COMMAND F0 IN G02/G03 (M series)
- 27 NO AXES COMMANDED IN G43/G44 (M series)
- 28 ILLEGAL PLANE SELECT
- 29 ILLEGAL OFFSET VALUE (M series)
- 29 ILLEGAL OFFSET VALUE (T series)
- 30 ILLEGAL OFFSET NUMBER (M series)
- 30 ILLEGAL OFFSET NUMBER (T series)
- 31 ILLEGAL P COMMAND IN G10
- 32 ILLEGAL OFFSET VALUE IN G10
- 33 NO SOLUTION AT CRC (M series)
- 33 NO SOLUTION AT CRC (T series)
- 34 NO CIRC ALLOWED IN ST–UP /EXT BLK (M series)
- 34 NO CIRC ALLOWED IN ST–UP /EXT BLK (T series)
- 35 CAN NOT COMMANDED G39 (M series)
- 35 CAN NOT COMMANDED G31 (T series)
- 36 CAN NOT COMMANDED G31 (M series)
- 37 CAN NOT CHANGE PLANE IN CRC (M seires)
- 37 CAN NOT CHANGE PLANE IN NRC (T seires)
- 38 INTERFERENCE IN CIRCULAR BLOCK (M seires)
- 38 INTERFERENCE IN CIRCULAR BLOCK (T series)
- 39 CHF/CNR NOT ALLOWED IN NRC (T series)
- 40 INTERFERENCE IN G90/G94 BLOCK (T series)
- 41 INTERFERENCE IN CRC (M seires)
- 41 INTERFERENCE IN NRC (T seires)
- 42 G45/G48 NOT ALLOWED IN CRC (M series)
- 44 G27–G30 NOT ALLOWED IN FIXED CYC (M series)
- 45 ADDRESS Q NOT FOUND (G73/G83) (M series)
- 46 ILLEGAL REFERENCE RETURN COMMAND
- 47 ILLEGAL AXIS SELECT
- 48 BASIC 3 AXIS NOT FOUND
- 049 ILLEGAL OPERATION (G68/G69) (M series)
- 50 CHF/CNR NOT ALLOWED IN THRD BLK (M series)
- 50 CHF/CNR NOT ALLOWED IN THRD BLK(T series)
- 51 MISSING MOVE AFTER CHF/CNR (M series)
- 51 MISSING MOVE AFTER CHF/CNR (T series)
- 52 CODE IS NOT G01 AFTER CHF/CNR (M series)
- 52 CODE IS NOT G01 AFTER CHF/CNR (T series)
- 53 TOO MANY ADDRESS COMMANDS (M series)
- 53 TOO MANY ADDRESS COMMANDS (T seires)
- 54 NO TAPER ALLOWED AFTER CHF/CNR (T series)
- 55 MISSING MOVE VALUE IN CHF/CNR (M series)
- 55 MISSING MOVE VALUE IN CHF/CNR (T series)
- 56 NO END POINT & ANGLE IN CHF/CNR (T series)
- 57 NO SOLUTION OF BLOCK END (T series)
- 58 END POINT NOT FOUND (M series)
- 58 END POINT NOT FOUND (T series)
- 59 PROGRAM NUMBER NOT FOUND
- 60 SEQUENCE NUMBER NOT FOUND
- 61 ADDRESS P/Q NOT FOUND IN G70–G73 (T series)
- 62 ILLEGAL COMMAND IN G71–G76 (T series)
- 63 SEQUENCE NUMBER NOT FOUND (T series)
- 64 SHAPE PROGRAM NOT MONOTONOUSLY (T series)
- 65 ILLEGAL COMMAND IN G71–G73 (T series)
- 66 IMPROPER G–CODE IN G71–G73 (T series)
- 67 CAN NOT ERROR IN MDI MODE (T series)
- 69 FORMAT ERROR IN G70–G73 (T series)
- 70 NO PROGRAM SPACE IN MEMORY
- 71 DATA NOT FOUND
- 72 TOO MANY PROGRAMS
- 73 PROGRAM NUMBER ALREADY IN
- 74 ILLEGAL PROGRAM NUMBER
- 75 PROTECT
- 76 ADDRESS P NOT DEFINED
- 77 SUB PROGRAM NESTING ERROR
- 78 NUMBER NOT FOUND
- 79 PROGRAM VERIFY ERROR
- 80 G37 ARRIVAL SIGNAL NOT ASSERTED (M series)
- 80 G37 ARRIVAL SIGNAL NOT ASSERTED (T series)
- 81 OFFSET NUMBER NOT FOUND IN G37 (M series)
- 81 OFFSET NUMBER NOT FOUND IN G37 (T series)
- 82 H–CODE NOT ALLOWED IN G37 (M series)
- 82 T–CODE NOT ALLOWED IN G37 (T series)
- 83 ILLEGAL AXIS COMMAND IN G37 (M series)
- 83 ILLEGAL AXIS COMMAND IN G37 (T series)
- 85 COMMUNICATION ERROR
- 86 DR SIGNAL OFF
- 87 BUFFER OVERFLOW
- 88 LAN FILE TRANS ERROR (CHANNEL–1)
- 89 LAN FILE TRANS ERROR (CHANNEL–2)
- 90 REFERENCE RETURN INCOMPLETE
- 91 REFERENCE RETURN INCOMPLETE
- 92 AXES NOT ON THE REFERENCE POINT
- 94 P TYPE NOT ALLOWED (COORD CHG)
- 95 P TYPE NOT ALLOWED (EXT OFS CHG)
- 96 P TYPE NOT ALLOWED (WRK OFS CHG)
- 97 P TYPE NOT ALLOWED (AUTO EXEC)
- 98 G28 FOUND IN SEQUENCE RETURN
- 99 MDI EXEC NOT ALLOWED AFT. SEARCH
- 100 PARAMETER WRITE ENABLE
- 101 PLEASE CLEAR MEMORY
- 109 FORMAT ERROR IN G08 (M series)
- 110 DATA OVERFLOW
- 111 CALCULATED DATA OVERFLOW
- 112 DIVIDED BY ZERO
- 113 IMPROPER COMMAND
- 114 FORMAT ERROR IN MACRO
- 115 ILLEGAL VARIABLE NUMBER
- 116 WRITE PROTECTED VARIABLE
- 118 PARENTHESIS NESTING ERROR
- 119 ILLEGAL ARGUMENT
- 122 FOUR FOLD MACRO MODAL–CALL
- 123 CAN NOT USE MACRO COMMAND IN DNC
- 124 MISSING END STATEMENT
- 125 FORMAT ERROR IN MACRO
- 126 ILLEGAL LOOP NUMBER
- 127 NC, MACRO STATEMENT IN SAME BLOCK
- 128 ILLEGAL MACRO SEQUENCE NUMBER
- 129 ILLEGAL ARGUMENT ADDRESS
- 130 ILLEGAL AXIS OPERATION
- 131 TOO MANY EXTERNAL ALARM MESSAGES
- 132 ALARM NUMBER NOT FOUND
- 133 ILLEGAL DATA IN EXT. ALARM MSG
- 135 ILLEGAL ANGLE COMMAND (M series)
- 135 SPINDLE ORIENTATION PLEASE (T series)
- 136 ILLEGAL AXIS COMMAND (M series)
- 136 C/H–CODE & MOVE CMD IN SAME BLK. (T series)
- 137 M–CODE & MOVE CMD IN SAME BLK.
- 138 SUPERIMPOSED DATA OVERFLOW
- 139 CAN NOT CHANGE PMC CONTROL AXIS
- 140 PROGRAM NUMBER ALREADY IN USE
- 141 CAN NOT COMMAND G51 IN CRC (M series)
- 142 ILLEGAL SCALE RATE (M series)
- 143 SCALED MOTION DATA OVERFLOW (M series)
- 144 ILLEGAL PLANE SELECTED (M series)
- 145 ILLEGAL CONDITIONS IN POLAR COORDINATE INTERPOLATION
- 146 IMPROPER G CODE
- 148 ILLEGAL SETTING DATA (M series)
- 149 FORMAT ERROR IN G10L3 (M series)
- 150 ILLEGAL TOOL GROUP NUMBER
- 151 TOOL GROUP NUMBER NOT FOUND
- 152 NO SPACE FOR TOOL ENTRY
- 153 T–CODE NOT FOUND
- 154 NOT USING TOOL IN LIFE GROUP (M series)
- 155 ILLEGAL T–CODE IN M06 (M series)
- 155 ILLEGAL T–CODE IN M06 (T series)
- 156 P/L COMMAND NOT FOUND
- 157 TOO MANY TOOL GROUPS
- 158 ILLEGAL TOOL LIFE DATA
- 159 TOOL DATA SETTING INCOMPLETE
- 160 MISMATCH WAITING M–CODE (T series (At two–path))
- 160 MISMATCH WAITING M–CODE (T series (At three–path))
- 160 G72.1 NESTING ERROR (M series))
- 161 ILLEGAL P OF WAITING M–CODE (T series (three–path control)
- 161 G72.1 NESTING ERROR (M series)
- 163 COMMAND G68/G69 INDEPENDENTLY T series (At two–path)
- 169 ILLEGAL TOOL GEOMETRY DATA (At two–path)
- 175 ILLEGAL G107 COMMAND
- 176 IMPROPER G–CODE IN G107 (M series)
- 176 IMPROPER G–CODE IN G107 (T series)
- 177 CHECK SUM ERROR (G05 MODE)
- 178 G05 COMMANDED IN G41/G42 MODE
- 179 PARAM. (NO. 7510) SETTING ERROR
- 180 COMMUNICATION ERROR (REMOTE BUF)
- 181 FORMAT ERROR IN G81 BLOCK (Hobbing machine, EGB) (M series)
- 182 G81 NOT COMMANDED (Hobbing machine) (M series)
- 183 DUPLICATE G83 (COMMANDS) (Hobbing machine) (M series)
- 184 ILLEGAL COMMAND IN G81 (Hobbing machine, EGB) (M series)
- 185 RETURN TO REFERENCE POINT (Hobbing machine) (M series)
- 186 PARAMETER SETTING ERROR (Hobbing machine, EGB) (M series)
- 187 HOB COMMAND IS NOT ALLOWED
- 190 ILLEGAL AXIS SELECT (M series)
- 194 SPINDLE COMMAND IN SYNCHRO–MODE
- 195 MODE CHANGE ERROR
- 197 C–AXIS COMMANDED IN SPINDLE MODE
- 199 MACRO WORD UNDEFINED
- 200 ILLEGAL S CODE COMMAND
- 201 FEEDRATE NOT FOUND IN RIGID TAP
- 202 POSITION LSI OVERFLOW
- 203 PROGRAM MISS AT RIGID TAPPING
- 204 ILLEGAL AXIS OPERATION
- 205 RIGID MODE DI SIGNAL OFF
- 206 CAN NOT CHANGE PLANE (RIGID TAP) (M series)
- 207 RIGID DATA MISMATCH
- 210 CAN NOT COMAND M198/M199
- 211 G31 (HIGH) NOT ALLOWED IN G99
- 212 ILLEGAL PLANE SELECT (M series)
- 212 ILLEGAL PLANE SELECT (T series)
- 213 ILLEGAL COMMAND IN SYNCHRO–MODE
- 213 ILLEGAL COMMAND IN SYNCHRO–MODE (T series)
- 214 ILLEGAL COMMAND IN SYNCHRO–MODE
- 217 DUPLICATE G51.2 (COMMANDS) (T series)
- 218 NOT FOUND P/Q COMMAND IN G251 (T series)
- 219 COMMAND G250/G251 INDEPENDENTLY (T series)
- 220 ILLEGAL COMMAND IN SYNCHR–MODE (T series)
- 221 ILLEGAL COMMAND IN SYNCHR–MODE (T series)
- 222 DNC OP. NOT ALLOWED IN BG.–EDIT (M series)
- 224 RETURN TO REFERENCE POINT (M series)
- 224 RETURN TO REFERENCE POINT (T series)
- 225 SYNCHRONOUS/MIXED CONTROL ERROR (T series (At two–path))
- 226 ILLEGAL COMMAND IN SYNCHRO– MODE (T series (At two–path))
- 229 CAN NOT KEEP SYNCHRO–STATE (T series)
- 230 R CODE NOT FOUND (Grinding machine) (M series)
- 231 ILLEGAL FORMAT IN G10 OR L50
- 232 TOO MANY HELICAL AXIS COMMANDS (M series)
- 233 DEVICE BUSY
- 239 BP/S ALARM
- 240 BP/S ALARM
- 241 ILLEGAL FORMAT IN G02.2/G03.2 (M series)
- 242 ILLEGAL COMMAND IN G02.2/G03.2 (M series)
- 243 OVER TOLERANCE OF END POINT (M series)
- 244 P/S ALARM (T series)
- 245 T–CODE NOT ALOWEE IN THIS BLOCK (T series)
- 246 ENCODE PROGRAM NUMBER ERROR
- 247 ILLEGAL CODE USED FOR OUTPUT
- 250 Z AXIS WRONG COMMAND (ATC) (M series)
- 251 ATC ERROR (M series)
- 252 ATC SPINDLE ALARM (M series)
- 253 G05 IS NOT AVAILABLE (M series)
- 300 ILLEGAL COMMAND IN SCALING
- 301 RESETTING OF REFERENCE RETURN IS INHIBITED
- 302 SETTING THE REFERENCE POSITION WITHOUT DOG IS NOT PERFORMED
- 304 G28 IS COMMANDED WITHOUT ZERO RETURN
- 305 INTERMEDIATE POSITION IS NOT ASSIGNED (M Series)
- 306 MISMATCH AXIS WITH CNR/CHF (T Series)
- 307 CAN NOT START REFERENCE RETURN WITH MECHANICAL STOPPER SETTING
- 310 FILE NOT FOUND
- 311 CALLED BY FILE NAME FORMAT ERROR
- 312 ILLEGAL COMMAND IN DIRECT DRAWING DIMENSIONS PROGRAMMING (T Series)
- 313 ILLEGAL LEAD COMMAND (T Series)
- 314 ILLEGAL SETTING OF POLYGONAL AXIS (T Series)
- 315 ILLEGAL NOSE ANGLE COMMAND IS IN THE THREAD CUTTING CYCLE (T Series)
- 316 ILLEGAL CUTTING AMOUNT IS IN THE THREAD CUTTING CYCLE (T Series)
- 317 ILLEGAL THREAD COMMAND IS IN THE THREAD CUTTING CYCLE (T Series)
- 318 ILLEGAL RELIEF AMOUNT IS IN THE DRILLING CYCLE (T Series)
- 319 THE END POINT COMMAND IS ILLEGAL IN THE DRILLING CYCLE (T Series)
- 320 ILLEGAL MOVEMENT AMOUNT/CUTTING AMOUNT IS IN THE DRILLING CYCLE (T Series)
- 321 ILLEGAL REPEATED TIME IS IN THE PATTERN REPEATING CYCLE (T Series)
- 322 FINISHING SHAPE WHICH OVER OF STARTING POINT (T Series)
- 323 THE FIRST BLOCK OF SHAPE PROGRAM IS A COMMAND OF TYPE II (T Series)
- 324 THE INTERRUPTION TYPE MACRO WAS DONE IN THE MULTIPLE REPETIVE CYCLES (T Series)
- 325 UNAVAILABLE COMMAND IS IN SHAPE PROGRAM (T Series)
- 326 LAST BLOCK OF SHAPE PROGRAM IS A DIRECT DRAWING DIMENSIONS (T Series)
- 327 MODAL THAT MULTIPLE REPETIVE CYCLES CANNOT BE DONE (T Series)
- 328 ILLEGAL WORK POSITION IS IN THE TOOL NOSE RADIUS COMPENSATION (T Series)
- 329 THE FINISHING SHAPE IS NOT A MONOTONOUS CHANGE(SECOND AXES) (T Series)
- 330 ILLEGAL AXIS COMMAND IS IN THE TURNING CANNED CYCLE (T Series)
- 334 OFFSET IS OUT OF EFFECTIVE RANGE
- 336 TOOL COMPENSATION COMMANDED MORE TWO AXES (M Series)
- 337 EXCESS MAXIMUM INCREMENTAL VALUE
- 338 CHECK SUM ERROR
- 345 TOOL CHANGE ILLEGAL Z AXIS POS
- 346 TOOL CHANGE ILLEGAL TOOL NUM
- 347 TOOL CHANGE ILLEGAL COMMAND IN SAME BLK.
- 348 TOOL CHANGE Z AXIS POS NOT ESTABLISHED
- 349 TOOL CHANGE SPINDLE NOT STOP
- 350 PARAMETER OF THE INDEX OF THE SYNCHRONOUS CONTROL AXIS SET ERROR. (T Series)
- 351 BECAUSE THE AXIS IS MOVING, THE SYNC CONTROL IS CAN’T BE USED. (T Series)
- 352 SYNCHRONOUS CONTROL AXIS COMPOSITION ERROR. (T Series)
- 353 THE INSTRUCTION WAS DONE FOR THE AXIS WHICH WAS NOT ABLE TO MOVE. (T Series)
- 354 THE G28 WAS INSTRUCTED IN WITH THE REF POS NOT FIXED IN SYNC MODE (T Series)
- 355 PARAMETER OF THE INDEX OF THE COMPOSITE CONTROL AXIS SET ERROR. (T Series)
- 356 BECAUSE THE AXIS IS MOVING, THE COMP CONTROL IS CAN’T BE USED. (T Series)
- 357 COMPOSITE CONTROL AXIS COMPOSITION ERROR. (T Series)
- 359 THE G28 WAS INSTRUCTED IN WITH THE REF POS NOT FIXED IN COMP MODE (T Series)
- 360 PARAMETER OF THE INDEX OF THE SUPERPOS CONTROL AXIS SET ERROR. (T Series)
- 361 BECAUSE THE AXIS IS MOVING, THE SUPERPOS CONTROL IS CAN’T BE USED. (T Series)
- 362 SUPERPOSITION CONTROL AXIS COMPOSITION ERROR. (T Series)
- 363 THE G28 WAS INSTRUCTED IN TO THE SUPERPOS CONTROL SLAVE AXIS. (T Series)
- 364 THE G53 WAS INSTRUCTED IN TO THE SUPERPOS CONTROL SLAVE AXIS. (T Series)
- 365 TOO MANY MAXIMUM SV/SP AXIS NUMBER PER PATH
- 369 G31 FORMAT ERROR
- 370 G31P/G04Q ERROR
- 372 REFERENCE RETURN INCOMPLETE
- 373 ILLEGAL HIGH-SPEED SKIP SIGNAL
- 375 CAN NOT ANGULAR CONTROL(SYNC:MIX:OVL)
- 376 SERIAL DCL: ILLEGAL PARAMETER
- 412 ILLEGAL G CODE
- 445 ILLEGAL AXIS OPERATION (T Series)
- 446 ILLEGAL COMMAND IN G96.1/G96.2/G96.3/G96.4 (T Series)
- 447 ILLEGAL SETTING DATA
- 455 ILLEGAL COMMAND IN GRINDING
- 456 ILLEGAL PARAMETER IN GRINDING
- 601 ILLEGAL AXIS OPERATION FOR SERVO MOTOR SPINDLE
- 602 SPINDLE SELECT COMMAND ERROR (SERVO MOTOR SPINDLE)
- 1001 AXIS CONTROL MODE ILLEGAL
- 1013 ILLEGAL POS. OF PROGRAM NO.
- 1014 ILLEGAL FORMAT OF PROGRAM NO.
- 1016 EOB NOT FOUND
- 1077 PROGRAM IN USE
- 1079 PROGRAM FILE NOT FOUND
- 1080 DUPLICATE DEVICE SUB PROGRAM CALL
- 1081 EXT DEVICE SUB PROGRAM CALL MODE ERROR
- 1091 DUPLICATE SUB-CALL WORD
- 1092 DUPLICATE MACRO-CALL WORD
- 1093 DUPLICATE NC-WORD & M99
- 1095 TOO MANY TYPE-2 ARGUMENT
- 1096 ILLEGAL VARIABLE NAME
- 1097 TOO LONG VARIABLE NAME
- 1098 NO VARIABLE NAME
- 1099 ILLLEGAL SUFFIX [ ]
- 1100 CANCEL WITHOUT MODAL CALL
- 1101 ILLEGAL CNC STATEMENT IRT.
- 1115 READ PROTECTED VARIABLE
- 1120 ILLEGAL ARGUMENT FORMAT
- 1124 MISSING DO STATEMENT
- 1125 ILLEGAL EXPRESSION FORMAT
- 1128 SEQUENCE NUMBER OUT OF RANGE
- 1131 MISSING OPEN BRACKET
- 1132 MISSING CLOSE BRACKET
- 1133 MISSING ‘=’
- 1134 MISSING ‘,’
- 1137 IF STATEMENT FORMAT ERROR
- 1138 WHILE STATEMENT FORMAT ERROR
- 1139 SETVN STATEMENT FORMAT ERROR
- 1141 ILLEGAL CHARACTER IN VAR. NAME
- 1142 TOO LONG V-NAME (SETVN)
- 1143 BPRNT/DPRNT STATEMENT FORMAT ERROR
- 1144 G10 FORMAT ERROR
- 1160 COMMAND DATA OVERFLOW
- 1180 ALL PARALLEL AXES IN PARKING T
- 1196 ILLEGAL DRILLING AXIS SELECTED
- 1200 PULSCODER INVALID ZERO RETURN
- 1202 NO F COMMAND AT G93 (M Series)
- 1223 ILLEGAL SPINDLE SELECT
- 1298 ILLEGAL INCH/METRIC CONVERSION
- 1300 ILLEGAL ADDRESS
- 1301 MISSING ADDRESS
- 1302 ILLEGAL DATA NUMBER
- 1303 ILLEGAL AXIS NUMBER
- 1304 TOO MANY DIGIT
- 1305 DATA OUT OF RANGE
- 1306 MISSING AXIS NUMBER
- 1307 ILLEGAL USE OF MINUS SIGN
- 1308 MISSING DATA
- 1329 ILLEGAL MACHINE GROUP NUMBER
- 1330 ILLEGAL SPINDLE NUMBER
- 1331 ILLEGAL PATH NUMBER
- 1332 DATA WRITE LOCK ERROR
- 1333 DATA WRITE ERROR
- 1470 G40.1 –G42.1 PARAMETER MISS (M Series)
- 1508 DUPLICATE M-CODE (INDEX TABLE REVERSING) (M Series)
- 1509 DUPLICATE M-CODE (SPOS AXIS ORIENTATION) (T Series)
- 1510 DUPLICATE M-CODE (SPOS AXIS POSITIONING) (T Series)
- 1511 DUPLICATE M-CODE (SPOS AXIS RELEASE) (T Series)
- 1533 ADDRESS F UNDERFLOW (G95)
- 1534 ADDRESS F OVERFLOW (G95)
- 1537 ADDRESS F UNDERFLOW (OVERRIDE)
- 1538 ADDRESS F OVERFLOW (OVERRIDE)
- 1541 S-CODE ZERO
- 1543 ILLEGAL GEAR SETTING (T Series)
- 1544 S-CODE OVER MAX
- 1548 ILLGAL AXIS MODE
- 1561 ILLEGAL INDEXING ANGLE (M Series)
- 1564 INDEX TABLE AXIS – OTHER AXIS SAME TIME (M Series)
- 1567 INDEX TABLE AXIS DUPLICATE AXIS COMMAND (M Series)
- 1590 TH ERROR
- 1591 TV ERROR
- 1592 END OF RECORD
- 1593 EGB PARAMETER SETTING ERROR (M Series)
- 1594 EGB FORMAT ERROR (M Series)
- 1595 ILL-COMMAND IN EGB MODE (M Series)
- 1596 EGB OVERFLOW (M Series)
- 1805 ILLEGAL COMMAND
- 1806 DEVICE TYPE MISS MATCH
- 1807 PARAMETER SETTING ERROR
- 1808 DEVICE DOUBLE OPENED
- 1820 ILLEGAL DI SIGNAL STATE
- 1823 FRAMING ERROR(1)
- 1830 DR OFF(2)
- 1832 OVERRUN ERROR(2)
- 1833 FRAMING ERROR(2)
- 1834 BUFFER OVERFLOW(2)
- 1912 V-DEVICE DRIVER ERROR (OPEN)
- 1960 ACCESS ERROR (MEMORY CARD)
- 1961 NOT READY (MEMORY CARD)
- 1962 CARD FULL (MEMORY CARD)
- 1963 CARD PROTECTED (MEMORY CARD)
- 1964 NOT MOUNTED (MEMORY CARD)
- 1965 DIRECTORY FULL (MEMORY CARD)
- 1966 FILE NOT FOUND (MEMORY CARD)
- 1967 FILE PROTECTED (MEMORY CARD)
- 1968 ILLEGAL FILE NAME (MEMORY CARD)
- 1969 ILLEGAL FORMAT (MEMORY CARD)
- 1970 ILLEGAL CARD (MEMORY CARD)
- 1971 ERASE ERROR (MEMORY CARD)
- 1972 BATTERY LOW (MEMORY CARD)
- 1973 FILE ALREADY EXIST
- 2032 EMBEDDED ETHERNET/DATA SERVER ERROR
- 2051 #200-#499ILLEGAL P-CODE MACRO COMMON INPUT(NO OPTION)
- 2052 #500-#549P-CODE MACRO COMMON SELECT(CANNOT USE SETVN)
- 2053 THE NUMBER OF #30000 IS UNMATCH
- 2054 THE NUMBER OF #40000 IS UNMATCH
- 4010 ILLEGAL REAL VALUE OF OBUF :
- 5006 TOO MANY WORD IN ONE BLOCK
- 5007 TOO LARGE DISTANCE
- 5009 PARAMETER ZERO (DRY RUN)
- 5010 END OF RECORD
- 5011 PARAMETER ZERO(CUT MAX) (M series)
- 5014 TRACE DATA NOT FOUND (M series)
- 5015 NO ROTATION AXIS (M series) (M series)
- 5016 ILLEGAL COMBINATION OF M CODE
- 5018 POLYGON SPINDLE SPEED ERROR (T series)
- 5020 PARAMETER OF RESTART ERROR
- 5043 TOO MANY G68 NESTING (M series)
- 5043 TOO MANY G68 NESTING (T series)
- 5044 G68 FORMAT ERROR (M series)
- 5044 G68 FORMAT ERROR (T series)
- 5046 ILLEGAL PARAMETER (ST.COMP)
- 5050 ILL–COMMAND IN CHOPPING MODE (M series)
- 5051 M–NET CODE ERROR
- 5052 M–NET ETX ERROR
- 5053 M–NET CONNECT ERROR
- 5054 M–NET RECEIVE ERROR
- 5055 M–NET PRT/FRT ERROR
- 5057 M–NET BOARD SYSTEM DOWN
- 5058 G35/G36 FORMAT ERROR (T series)
- 5059 RADIUS IS OUT OF RANGE (T series)
- 5060 ILLEGAL PARAMETER IN G02.3/G03.3 (M series)
- 5061 ILLEGAL FORMAT IN G02.3/G03.3 (M series)
- 5062 ILLEGAL COMMAND IN G02.3/G03.3
- 5063 IS NOT PRESET AFTER REF. (M series)
- 5064 DIFFERRENT AXIS UNIT (IS–B, IS–C)
- 5065 DIFFERENT AXIS UNIT (PMC AXIS) (M series)
- 5067 (HPCC) (M series)
- 5068 G31 FORMAT ERROR (M series)
- 5069 WHL–C:ILLEGA P–DATA (M series)
- 5073 NO DECIMAL POINT
- 5074 ADDRESS DUPLICATION ERROR
- 5082 DATA SERVER ERROR
- 5085 SMOOTH IPL ERROR 1
- 5096 MISMATCH WAITING M–CODE
- 5110 NOT STOP POSITION
- 5110 IMPROPER G–CODE (G05.1 G1 MODE) (M series)
- 5111 IMPROPER MODAL G–CODE (G05.1 G1) (M series)
- 5111 IMPROPER MODEL G–CODE (G05.1 G1)
- 5112 G08 CAN NOT BE COMMANDED (G05.1 G1) (M series)
- 5113 CAN NOT ERROR IN MDI MODE
- 5114 NOT STOP POSITION (G05.1 Q1) (M series)
- 5114 CAN NOT ERROR IN MDI MODE (G05.1)
- 5115 SPL : ERROR (M series)
- 5116 SPL : ERROR (M series)
- 5117 SPL : ERROR (M series)
- 5118 SPL : ERROR (M series)
- 5122 ILLEGAL COMMAND IN SPIRAL (M series)
- 5123 OVER TOLERANCE OF END POINT (M series)
- 5124 CAN NOT COMMAND SPIRAL (M series)
- 5131 NC COMMAND IS NOT COMPATIBLE (T Series)
- 5134 FSSB : OPEN READY TIME OUT
- 5135 FSSB : ERROR MODE
- 5136 FSSB : NUMBER OF AMPS IS SMALL
- 5137 FSSB : CONFIGURATION ERROR
- 5138 FSSB : AXIS SETTING NOT COMPLETE
- 5139 FSSB : ERROR
- 5155 NOT RESTART PROGRAM BY G05
- 5156 ILLEGAL AXIS OPERATION (M series)
- 5157 PARAMETER ZERO (M series)
- 5195 DIRECTION CAN NOT BE JUDGED (T series)
- 5196 ILLEGAL OPERATION (HPCC) (M series)
- 5197 FSSB : OPEN TIME OUT
- 5198 FSSB : ID DATA NOT READ
- 5199 FINE TORQUE SENSING PARAMETER
- 5218 ILLEGAL PARAMETER (INCL. COMP)
- 5219 CAN NOT RETURN
- 5220 REFERENCE POINT ADJUSTMENT MODE
- 5222 SRAM CORRECTABLE ERROR
- 5227 FILE NOT FOUND
- 5228 SAME NAME USED
- 5229 WRITE PROTECTED
- 5231 TOO MANY FILES
- 5232 DATA OVER–FLOW
- 5235 COMMUNICATION ERROR
- 5237 READ ERROR
- 5238 WRITE ERROR
- 5242 ILLEGAL AXIS NUMBER (M series)
- 5243 DATA OUT OF RANGE (M series)
- 5244 TOO MANY DI ON (M series)
- 5245 OTHER AXIS ARE COMMANDED (M series)
- 5251 ILLEGAL PARAMETER IN G54.2 (M series)
- 5252 ILLEGAL P COMMAND IN G54.2 (M series)
- 5257 G41/G42 NOT ALLOWED IN MDI MODE (M series)
- 5300 SET ALL OFFSET DATAS AGAIN
- 5302 ILLEGAL COMMAND IN G68 MODE
- 5303 TOUCH PANEL ERROR
- 5305 ILLEGAL SPINDLE NUMBER
- 5306 MODE CHANGE ERROR
- 5307 INTERNAL DATA OVER FLOW (M series)
- 5311 FSSB:ILLEGAL CONNECTION
- 5321 S–COMP. VALUE OVERFLOW
- 5329 M98 AND NC COMMAND IN SAME BLOCK
- 5346 RETURN TO REFERENCE POINT
- 5362 CONVERT INCH/MM AT REF-POS
- 5391 CAN NOT USE G92 (M Series)
- 5395 CS AXIS NUMBER OVER
- 5400 SPL:ILLEGAL AXIS COMMAND (M series)
- 5401 SPL:ILLEGAL COMMAND (M series)
- 5402 SPL:ILLEGAL AXIS MOVING (M series)
- 5403 SPL:CAN NOT MAKE VECTOR (M series)
- 5405 ILLEGAL PARAMETER IN G41.2/ G42.2 (M series)
- 5406 G41.3/G40 FORMAT ERROR (M series)
- 5407 ILLEGAL COMMAND IN G41.3 (M series)
- 5408 G41.3 ILLEGAL START_UP (M series)
- 5409 ILLEGAL PARAMETER IN G41.3 (M series)
- 5411 NURBS:ILLEGAL ORDER (M series)
- 5412 NURBS:NO KNOT COMMAND (M series)
- 5413 NURBS:ILLEGAL AXIS COMMAND (M series)
- 5414 NURBS:ILLEGAL KNOT (M series)
- 5415 NURBS:ILLEGAL CANCEL (M series)
- 5416 NURBS:ILLEGAL MODE (M series)
- 5417 NURBS:ILLEGAL MULTI–KNOT (M series)
- 5418 NURBS:ILLEGAL KNOT VALUE (M series)
- 5420 ILLEGAL PARAMETER IN G43.4/ G43.5 (M series)
- 5421 ILLEGAL COMMAND IN G43.4/ G43.5 (M series)
- 5422 EXCESS VELOCITY IN G43.4/ G43.5 (M series)
- 5425 ILLEGAL OFFSET VALUE (M series)
- 5430 ILLEGAL COMMAND IN 3–D CIR (M series)
- 5432 G02.4/G03.4 FORMAT ERROR (M series)
- 5433 MANUAL INTERVENTION IN 3–D CIR (M series)
- 5435 PARAMETER OUT OF RANGE (TLAC) (M series)
- 5436 PARAMETER SETTING ERROR 1 (TLAC) (M series)
- 5437 PARAMETER SETTING ERROR 2 (TLAC) (M series)
- 5440 ILLEGAL DRILLING AXIS SELECTED (M series)
- 5445 CRC:MOTION IN G39 (M series)
- 5446 CRC:NO AVOIDANCE (M series)
- 5447 CRC:DANGEROUS AVOIDANCE (M series)
- 5448 CRC:INTERFERENCE TO AVD. (M series)
- 5452 IMPROPER G–CODE (5AXIS MODE) (M series)
- 5453 NOTE: G68 IS CANCELED (HPCC) (M series)
- 5455 ILLEGAL ACC. PARAMETER (M series)
Background edit alarm
BP/S alarm – BP/S alarm occurs in the same number as the P/S alarm that occurs in ordinary program edit. (070, 071, 072, 073, 074 085,086,087 etc.)
Absolute pulse coder (APC) alarms
- 300 n AXIS NEED ZRN
- 301 APC ALARM:n AXIS COMMUNICATION
- 302 APC ALARM:n AXIS OVER TIME
- 303 APC ALARM:n AXIS FRAMING
- 304 APC ALARM:n AXIS PARITY
- 305 APC ALARM:n AXIS PULSE MISS
- 306 APC ALARM:n AXIS BATTERY ZERO
- 307 APC ALARM:n AXIS BATTERY DOWN 1
- 308 APC ALARM:n AXIS BATTERY DOWN 2
- 309 APC ALARM:n AXIS ZRN IMPOSSIBLE
Inductsyn alarms
Serial pulse coder (SPC) alarms
- 350 SPC ALARM: n AXIS PULSE CODER
- 351 SPC ALARM: n AXIS COMMUNICATION
- 360 n AXIS : ABNORMAL CHECKSUM (INT)
- 361 n AXIS : ABNORMAL PHASE DATA (INT)
- 362 n AXIS : ABNORMAL REV.DATA (INT)
- 363 n AXIS : ABNORMAL CLOCK (INT)
- 364 n AXIS : SOFT PHASE ALARM (INT)
- 365 n AXIS : BROKEN LED (INT)
- 366 n AXIS : PULSE MISS (INT)
- 367 n AXIS : COUNT MISS (INT)
- 368 n AXIS : SERIAL DATA ERROR (INT)
- 369 n AXIS : DATA TRANS. ERROR (INT)
- 380 n AXIS : BROKEN LED (EXT)
- 381 n AXIS : ABNORMAL PHASE (EXT LIN)
- 382 n AXIS : COUNT MISS (EXT)
- 383 n AXIS : PULSE MISS (EXT)
- 384 n AXIS : SOFT PHASE ALARM (EXT)
- 385 n AXIS : SERIAL DATA ERROR (EXT)
- 386 n AXIS : DATA TRANS. ERROR (EXT)
- 387 n AXIS : ABNORMAL ENCODER (EXT)
Servo Alarms
- 400 SERVO ALARM: n–TH AXIS OVERLOAD
- 401 SERVO ALARM: n–TH AXIS VRDY OFF
- 402 SERVO ALARM: SV CARD NOT EXIST
- 403 SERVO ALARM: CARD/SOFT MISMATCH
- 404 SERVO ALARM: n–TH AXIS VRDY ON
- 405 SERVO ALARM: (ZERO POINT RETURN FAULT)
- 407 SERVO ALARM: EXCESS ERROR
- 409 SERVO ALARM: n AXIS TORQUE ALM
- 410 SERVO ALARM: n–TH AXIS – EXCESS ERROR
- 411 SERVO ALARM: n–TH AXIS – EXCESS ERROR
- 413 SERVO ALARM: n–th AXIS – LSI OVERFLOW
- 414 SERVO ALARM: n–TH AXIS – DETECTION RELATED ERROR
- 415 SERVO ALARM: n–TH AXIS – EXCESS SHIFT
- 416 SERVO ALARM: n–TH AXIS – DISCONNECTION
- 417 SERVO ALARM: n–TH AXIS – PARAMETER INCORRECT
- 420 SERVO ALARM: n AXIS SYNC TORQUE (M series)
- 421 SERVO ALARM: n AXIS EXCESS ER (D)
- 422 SERVO ALARM: n AXIS
- 423 SERVO ALARM: n AXIS
- 430 n AXIS : SV. MOTOR OVERHEAT
- 431 n AXIS : CNV. OVERLOAD
- 432 n AXIS : CNV. LOW VOLT CONTROL
- 433 n AXIS : CNV. LOW VOLT DC LINK
- 434 n AXIS : INV. LOW VOLT CONTROL
- 435 n AXIS : INV. LOW VOLT DC LINK
- 436 n AXIS : SOFTTHERMAL (OVC)
- 437 n AXIS : CNV. OVERCURRENT POWER
- 438 n AXIS : INV. ABNORMAL CURRENT
- 439 n AXIS : CNV. OVER VOLT DC LINK
- 440 n AXIS : CNV. EX DECELERATION POW.
- 441 n AXIS : ABNORMAL CURRENT OFFSET
- 442 n AXIS : CNV. CHARGE FAILURE
- 443 n AXIS : CNV. COOLING FAN FAILURE
- 444 n AXIS : INV. COOLING FAN FAILURE
- 445 n AXIS : SOFT DISCONNECT ALARM
- 446 n AXIS : HARD DISCONNECT ALARM
- 447 n AXIS : HARD DISCONNECT (EXT)
- 448 n AXIS : UNMATCHED FEEDBACK ALARM
- 449 n AXIS : INV. IPM ALARM
- 453 n AXIS : SPC SOFT DISCONNECT ALARM
- 456 ILLEGAL CURRENT LOOP
- 457 ILLEGAL HI HRV (250US)
- 458 CURRENT LOOP ERROR
- 459 HI HRV SETTING ERROR
- 460 n AXIS : FSSB DISCONNECT
- 461 n AXIS : ILLEGAL AMP INTERFACE
- 462 n AXIS : SEND CNC DATA FAILED
- 463 n AXIS : SEND SLAVE DATA FAILED
- 464 n AXIS : WRITE ID DATA FAILED
- 465 n AXIS : READ ID DATA FAILED
- 466 n AXIS : MOTOR/AMP COMBINATION
- 467 n AXIS : ILLEGAL SETTING OF AXIS
- 468 HI HRV SETTING ERROR(AMP)
Over travel alarms
- 500 OVER TRAVEL : +n
- 501 OVER TRAVEL : –n
- 502 OVER TRAVEL : +n
- 503 OVER TRAVEL : –n
- 504 OVER TRAVEL : +n
- 505 OVER TRAVEL : –n
- 506 OVER TRAVEL : +n
- 507 OVER TRAVEL : –n
- 508 INTERFERENCE: +n (T series (two–path control))
- 509 INTERFERENCE: –n (T series (two–path control))
- 510 OVER TRAVEL: +n
- 511 OVER TRAVEL: –n
- 514 INTERFERENCE : +n
- 515 INTERFERENCE : –n
Servo alarms
- 600 n AXIS: INV. DC LINK OVER CURRENT
- 601 n AXIS: INV. RADIATOR FAN FAILURE
- 602 n AXIS: INV. OVERHEAT
- 603 n AXIS: INV. IPM ALARM(OH)
- 604 n AXIS: AMP. COMMUNICATION ERROR
- 605 n AXIS: CNV. EX. DISCHARGE POW.
- 606 n AXIS: CNV. RADIATOR FAN FAILURE
- 607 n AXIS: CNV. SINGLE PHASE FAILURE
- 608 n AXIS: INV. COOLING FAN FAILURE
- 609 n AXIS: INV. RADIATOR FAN FAILURE
- 610 n AXIS: CNV. COOLING FAN FAILURE
- 611 n AXIS: CNV. RADIATOR FAN FAILURE
- 612 n AXIS: CNV. OVERLOAD PSM: Overheat occurred.
- 613 n AXIS: CNV. SINGLE PHASE FAILURE
- 641 n AXIS: SPEED DIFFERENCE ALARM
- 646 n AXIS: ABNORMAL ANALOG SIG.(EXT)
Overheat alarms
Rigid tapping alarms
- 740 RIGID TAP ALARM : EXCESS ERROR
- 741 RIGID TAP ALARM : EXCESS ERROR
- 742 RIGID TAP ALARM : LSI OVER FLOW
Serial Spindle Alarms
- 749 S–SPINDLE LSI ERROR
- 750 SPINDLE SERIAL LINK START FAULT
- 751 FIRST SPINDLE ALARM DETECTION (AL–XX)
- 752 FIRST SPINDLE MODE CHANGE FAULT
- 754 SPINDLE–1 ABNORMAL TORQUE ALM
- 762 SECOND SPINDLE MODE CHANGE FAULT
- 764 SPINDLE–2 ABNORMAL TORQUE ALM
- 772 SPINDLE–3 MODE CHANGE ERROR
- 774 SPINDLE–3 ABNORMAL TORQUE ALM
- 782 SPINDLE–4 MODE CHANGE ERROR
- 784 SPINDLE–4 ABNORMAL TORQUE ALM
System Alarms
- 900 ROM PARITY
- 910 SRAM PARITY : (BYTE 0)
- 911 SRAM PARITY : (BYTE 1)
- 912 DRAM PARITY : (BYTE 0)
- 913 DRAM PARITY : (BYTE 1)
- 914 DRAM PARITY : (BYTE 2)
- 915 DRAM PARITY : (BYTE 3)
- 916 DRAM PARITY : (BYTE 4)
- 917 DRAM PARITY : (BYTE 5)
- 918 DRAM PARITY : (BYTE 6)
- 919 DRAM PARITY : (BYTE 7)
- 920 SERVO ALARM (1–4 AXIS)
- 921 SERVO ALARM (5–8 AXIS)
- 924 SERVO MODULE SETTING ERROR
- 926 FSSB ALARM
- 930 CPU INTERRUPUT
- 935 SRAM ECC ERROR
- 940 PCB ERROR
- 950 PMC SYSTEM ALARM
- 951 PMC WATCH DOG ALARM
- 960 DC24V POWER OFF
- 970 NMI OCCURRED IN PMCLSI
- 971 NMI OCCURRED IN SLC
- 972 NMI OCCURRED IN OTHER MODULE
- 973 NON MASK INTERRUPT
- 974 F–BUS ERROR
- 975 BUS ERROR
- 976 L–BUS ERROR
Safety zone alarms
- 4500 REPOSITIONING INHIBITED
- 4502 ILLEGAL COMMAND IN BOLT HOLE
- 4503 ILLEGAL COMMAND IN LINE AT ANGLE
- 4504 ILLEGAL COMMAND IN ARC
- 4505 ILLEGAL COMMAND IN GRID
- 4506 ILLEGAL COMMAND IN SHARE PROOFS
- 4507 ILLEGAL COMMAND IN SQUARE
- 4508 ILLEGAL COMMAND IN RADIUS
- 4509 ILLEGAL COMMAND IN CUT AT ANGLE
- 4520 T, M INHIBITED IN NIBBLING-MODE
- 4521 EXCESS NIBBLING MOVEMENT (X, Y)
- 4522 EXCESS NIBBLING MOVEMENT (C)
- 4523 ILLEGAL COMMAND IN CIRCLE-NIBBL
- 4524 ILLEGAL COMMAND IN LINE-NIBBL
- 4530 A/B MACRO NUMBER ERROR
- 4531 U/V MACRO FORMAT ERROR
- 4532 IMPROPER U/V MACRO NUMBER
- 4533 U/V MACRO MEMORY OVERFLOW
- 4534 W MACRO NUMBER NOT FOUND
- 4535 U/V MACRO NESTING ERROR
- 4536 NO W, Q COMMAND IN MULTI-PIECE
- 4537 ILLEGAL Q VALUE IN MULTI-PIECE
- 4538 W NO. NOT FOUND IN MULTI-PIECE
- 4539 MULTI-PIECE SETTING IS ZERO
- 4540 MULTI-PIECE COMMAND WITHIN MACRO
- 4542 MULTI-PIECE COMMAND ERROR
- 4543 MULTI-PIECE Q COMMAND ERROR
- 4544 MULTI-PIECE RESTART ERROR
- 4600 T, C COMMAND IN INTERPOLATION
- 4601 INHIBITED T, M COMMAND
- 4602 ILLEGAL T-CODE
- 4606 A T COMMAND WAS ISSUED
- 4650 IMPROPER G-CODE IN OFFSET MODE
- 4700 PROGRAM ERROR (OT +)
- 4701 PROGRAM ERROR (OT –)
- 4702 PROGRAM ERROR (OT +)
- 4703 PROGRAM ERROR (OT –)
- 4800 ZONE : PUNCHING INHIBITED 1
- 4801 ZONE : PUNCHING INHIBITED 2
- 4802 ZONE : PUNCHING INHIBITED 3
- 4803 ZONE : PUNCHING INHIBITED 4
- 4810 ZONE : ENTERING INHIBITED 1 +X
- 4811 ZONE : ENTERING INHIBITED 1 –X
- 4812 ZONE : ENTERING INHIBITED 2 +X
- 4813 ZONE : ENTERING INHIBITED 2 –X
- 4814 ZONE : ENTERING INHIBITED 3 +X
- 4815 ZONE : ENTERING INHIBITED 3 –X
- 4816 ZONE : ENTERING INHIBITED 4 +X
- 4817 ZONE : ENTERING INHIBITED 4 –X
- 4830 ZONE : ENTERING INHIBITED 1 +Y
- 4831 ZONE : ENTERING INHIBITED 1 –Y
- 4832 ZONE : ENTERING INHIBITED 2 +Y
- 4833 ZONE : ENTERING INHIBITED 2 –Y
- 4834 ZONE : ENTERING INHIBITED 3 +Y
- 4835 ZONE : ENTERING INHIBITED 3 –Y
- 4836 ZONE : ENTERING INHIBITED 4 +Y
- 4837 ZONE : ENTERING INHIBITED 4 –Y
- 4870 AUTO SETTING FEED ERROR
- 4871 AUTO SETTING PIECES ERROR
- 4872 AUTO SETTING COMMAND ERROR
