Fanuc 15i Alarms /Errors for CNC machinists.
Contents
Fanuc 15i Alarms
Program Errors/Alarms (P/S alarm)
Program Errors /Alarms on program and operation (P/S alarm)
- PS001 AXIS CONTROL MODE ILLEGAL
- PS003 TOO MANY DIGIT
- PS006 ILLEGAL USE OF MINUS SIGN
- PS007 ILLEGAL USE OF DECIMAL POINT
- PS010 IMPROPER G–CODE
- PS011 IMPROPER NC–ADDRESS
- PS012 INVALID BREAK POINT OF WORDS
- PS013 ILLEGAL POS. OF PROGRAM NO.
- PS014 ILLEGAL FORMAT OF PROGRAM NO.
- PS015 TOO MANY WORD IN ONE BLOCK
- PS016 EOB NOT FOUND
- PS017 ILLEGAL MODE FOR GOTO/WHILE/DO
- PS059 COMMAND IN BUFFERING MODE
- PS060 SEQUENCE NUMBER NOT FOUND
- PS076 PROGRAM NOT FOUND
- PS077 PROGRAM IN USE
- PS079 PROGRAM FILE NOT FOUND
- PS080 DUPLICATE DEVICE SUB PROGRAM CALL
- PS081 EXT DEVICE SUB PROGRAM CALL MODE ERROR
- PS090 DUPLICATE NC, MACRO STATEMENT
- PS091 DUPLICATE SUB–CALL WORD
- PS092 DUPLICATE MACRO–CALL WORD
- PS093 DUPLICATE NC–WORD & M99
- PS094 USE ’G’ AS ARGUMENT
- PS095 TOO MANY TYPE–2 ARGUMENT
- PS096 ILLEGAL VARIABLE NAME
- PS097 TOO LONG VARIABLE NAME
- PS098 NO VARIABLE NAME
- PS099 ILLLEGAL SUFFIX [ ]
- PS100 CANCEL WITHOUT MODAL CALL
- PS101 ILLEGAL CNC STATEMENT IRT.
- PS110 OVERFLOW: INTEGER
- PS111 OVERFLOW: FLOATING
- PS112 ZERO DIVIDE
- PS114 VARIABLE NO. OUT OF RANGE
- PS115 READ PROTECTED VARIABLE
- PS116 WRITE PROTECTED VARIABLE
- PS118 TOO MANY BRACKET NESTING
- PS119 ARGUMENT VALUE OUT OF RANGE
- PS120 ILLEGAL ARGUMENT FORMAT
- PS121 TOO MANY SUB,MACRO NESTING
- PS122 TOO MANY MACRO NESTING
- PS123 MISSING END STATEMENT
- PS124 MISSING DO STATEMENT
- PS125 ILLEGAL EXPRESSION FORMAT
- PS126 ILLEGAL LOOP NUMBER
- PS128 SEQUENCE NUMBER OUT OF RANGE
- PS131 MISSING OPEN BRACKET
- PS132 MISSING CLOSE BRACKET
- PS133 MISSING ‘=’
- PS134 MISSING ‘,’
- PS135 MACRO STATEMENT FORMAT ERROR
- PS137 IF STATEMENT FORMAT ERROR
- PS138 WHILE STATEMENT FORMAT ERROR
- PS139 SETVN STATEMENT FORMAT ERROR
- PS141 ILLEGAL CHARACTER IN VAR. NAME
- PS142 TOO LONG V–NAME (SETVN)
- PS143 BPRNT/DPRNT STATEMENT FORMAT ERROR
- PS144 G10 FORMAT ERROR
- PS145 G10.1 TIME OUT
- PS146 G10.1 FORMAT ERROR
- PS150 G31 FORMAT ERROR
- PS151 CANNOT USE G31
- PS152 G31.9/G31.8 FORMAT ERROR
- PS153 CANNOT USE G31.9
- PS160 COMMAND DATA OVERFLOW
- PS180 ALL PARALLEL AXES IN PARKING
- PS181 ZERO RETURN NOT FINISHED
- PS182 CIRCLE CUT IN RAPID (F0)
- PS183 TOO MANY SIMULTANEOUS AXES
- PS184 TOO LARGE DISTANCE
- PS185 ZERO RETURN CHECK (G27) ERROR
- PS186 ILLEGAL PLANE SELECT
- PS187 FEED ZERO (COMMAND)
- PS188 PARAMETER ZERO (DRY RUN)
- PS190 PARAMETER ZERO (CUT MAX)
- PS191 OVER TOLERANCE OF RADIUS
- PS193 ILLEGAL OFFSET NUMBER
- PS194 ZERO RETURN END NOT ON REF
- PS195 ILLEGAL AXIS SELECTED (G96)
- PS196 ILLEGAL DRILLING AXIS SELECTED
- PS200 PULSCODER INVALID ZERO RETURN
- PS202 NO F COMMAND AT G93
- PS213 ILLEGAL USE OF G12.1/G13.1
- PS214 ILLEGAL USE OF G–CODE
- PS215 ILLEGAL COMMAND IN G10.6
- PS217 ILLEGAL OFFSET VALUE
- PS223 ILLEGAL SPINDLE SELECT
- PS270 CRC: START_UP /CANCEL BY CIRCLE
- PS271 CRC: PLANE CHANGE
- PS272 CRC: INTERFERENCE
- PS273 CRC: MOTION IN G39
- PS275 CRC: MDI MODE
- PS276 CRC: NO INTERSECTION
- PS277 CRC: NO AVOIDANCE
- PS278 CRC: DANGEROUS AVOIDANCE
- PS279 CRC: INTERFERENCE TO AVD.
- PS280 ILLEGAL COMMAND IN SPIRAL
- PS281 OVER TOLERANCE OF END POINT IN SPIRAL
- PS282 ILLEGAL COMMAND IN 3–D OFFSET
- PS283 ILLEGAL IJK IN 3–D OFFSET
- PS298 ILLEGAL INCH/METRIC CONVERSION
- PS299 ILLEGAL ZERO RETURN COMMAND
- PS300 ILLEGAL ADDRESS
- PS301 MISSING ADDRESS
- PS302 ILLEGAL DATA NUMBER
- PS303 ILLEGAL AXIS NUMBER
- PS304 TOO MANY DIGIT
- PS305 DATA OUT OF RANGE
- PS306 MISSING AXIS NUMBER
- PS307 ILLEGAL USE OF MINUS SIGN
- PS308 MISSING DATA
- PS330 ILLEGAL SPINDLE NUMBER
- PS332 DATA WRITE LOCK ERROR
- PS333 DATA WRITE ERROR
- PS360 PARAMETER OUT OF RANGE (TLAC)
- PS361 PARAMTER SETTING ERROR 1 (TLAC)
- PS362 PARAMETER SETTING ERROR 2 (TLAC)
- PS370 PARAMETER SETTING ERROR (DM3H–1)
- PS371 PARAMETER SETTING ERROR (DM3H–2)
- PS372 PARAMETAR SETTING ERROR (DM3H–3)
- PS373 PARAMETER SETTING ERROR (DM3H–4)
- PS400 PROGRAM NOT MATCH
- PS410 G37 IMPROPER AXIS COMMAND
- PS411 G37 SPECIFIED WITH H CODE
- PS412 G37 OFFSET NO. UNASSIGNED
- PS415 G37 MEASURING POSITION REACHED SIGNAL IS NOT PROPERLY INPUT
- PS421 SETTING COMMAND ERROR
- PS422 NOT FOUND TOOL DATA
- PS423 TOOL DATA WRITE ERROR
- PS424 OVER MAXIMUM TOOL DATA
- PS425 NOT DELETE TOOL DATA IN OPERATION
- PS429 MISSING VALUE AT CNR, CHF
- PS431 MISSING MOVE AFTER CNR, CHF
- PS437 ILLEGAL LIFE GROUP NUMBER
- PS438 GROUP NOT FOUND AT LIFE DATA
- PS439 OVER MAXIMUM TOOL NUMBER
- PS440 T COMMAND NOT FOUND
- PS441 NOT USING TOOL IN LIFE GROUP
- PS442 ILLEGAL T COMMAND AT M06
- PS443 P, L COMMAND NOT FOUND
- PS444 OVER MAXIMUM LIFE GROUP
- PS445 ILLEGAL L COMMAND
- PS446 ILLEGAL H, D, T COMMAND
- PS448 ILLEGAL FORMAT AT LIFE DATA
- PS449 ILLEGAL TOOL LIFE DATA
- PS450 IN PMC AXIS MODE
- PS470 G40.1 to G42.1 PARAMETER MISS
- PS472 ILL–COMMAND IN G81.1 MODE
- PS508 DUPLICATE M–CODE (INDEX TABLE REVERSING)
- PS509 DUPLICATE M–CODE (SPOS AXIS ORIENTATION)
- PS510 DUPLICATE M–CODE (SPOS AXIS POSITIONING)
- PS511 DUPLICATE M–CODE (SPOS AXIS RELEASE)
- PS531 ILLEGAL USE OF DECIMAL POINT (F–CODE)
- PS532 ILLEGAL USE OF DECIMAL POINT (E–CODE)
- PS533 ADDRESS F UNDERFLOW (G95)
- PS534 ADDRESS F OVERFLOW (G95)
- PS535 ADDRESS E UNDERFLOW (G95)
- PS536 ADDRESS E OVERFLOW (G95)
- PS537 ADDRESS F UNDERFLOW (OVERRIDE)
- PS538 ADDRESS F OVERFLOW (OVERRIDE)
- PS539 ADDRESS E UNDERFLOW (OVERRIDE)
- PS540 ADDRESS E OVERFLOW (OVERRIDE)
- PS541 S–CODE ZERO
- PS542 FEED ZERO (E–CODE)
- PS543 ILLEGAL GEAR SETTING
- PS548 ILLGAL AXIS MODE
- PS551 DUPLICATE SPOS AXIS COMMAND
- PS552 SPOS AXIS – OTHER AXIS SAME TIME
- PS553 SPOS AXIS ILLEGAL SEQUENCE NUMBER
- PS555 SPOS AXIS DUPLICATE AXIS COMMAND
- PS561 ILLEGAL INDEXING ANGLE
- PS562 INDEX TABLE AXIS COMMAND CAN NOT START
- PS563 EXCESS ERROR OF INDEXING ANGLE
- PS564 INDEX TABLE AXIS – OTHER AXIS SAME TIME
- PS566 INDEX TABLE AXIS DUPLICATE AXIS MODE
- PS567 INDEX TABLE AXIS DUPLICATE AXIS COMMAND
- PS571 CS AXIS DUPLICATE AXIS MODE
- PS572 CS AXIS DUPLICATE AXIS COMMAND
- PS580 ENCODE ALARM (PSWD&KEY)
- PS581 ENCODE ALARM (PARAMETER)
- PS590 TH ERROR
- PS591 TV ERROR
- PS592 END OF RECORD
- PS593 EGB PARAMETER SETTING ERROR
- PS594 EGB FORMAT ERROR
- PS595 ILL–COMMAND IN EGB MODE
- PS596 EGB OVERFLOW
- PS597 EGB AUTO PHASE FORMAT ERROR
- PS598 EGB AUTO PHASE PARAMETER SETTING ERROR
- PS610 ILLEGAL G07.1 AXIS
- PS611 ILLEGAL G–CODE USE (G07.1 MODE)
- PS618 ILLEGAL P–DATA (WHEEL WEAR COMPENSATION)
- PS619 ILLEGAL AXIS(WHEEL WEAR COMPENSATION)
- PS625 TOO MANY G68 NESTING
- PS626 G68 FORMAT ERROR
- PS645 TOO MANY G68.2 NESTING
- PS646 G68.2 FORMAT ERROR
- PS647 ILLEGAL USE OF G53.1
- PS710 ILLEGAL COMMAND IN 3–D CIR
- PS712 G02.4/G03.4 FORMAT ERROR
- PS713 MANUAL INTERVENTION IN G02.4/G03.4 (ABS ON)
- PS805 ILLEGAL COMMAND
- PS806 DEVICE TYPE MISS MATCH
- PS807 PARAMETER SETTING ERROR
- PS808 DEVICE DOUBLE OPENED
- PS809 ILLEGAL COMMAND IN G41/G42
- PS895 ILLEGAL PARAMETER IN G02.3/G03.3
- PS896 ILLEGAL FORMAT IN G02.3/G03.3
- PS897 ILLEGAL COMMAND IN G02.3/G03.3
- PS898 ILLEGAL PARAMETER IN G54.2
- PS899 ILLEGAL PARAMETER IN G43.2
- PS900 G72.1 NESTING ERROR G72.1
- PS901 G72.2 NESTING ERROR G72.2
- PS935 ILLEGAL FORMAT IN G02.2/G03.2
- PS936 ILLEGAL COMMAND IN G02.2/G03.2
- PS937 OVER TOLERANCE OF END POINT
- PS990 SPL: ILLEGAL AXIS COMMAND
- PS991 SPL: ILLEGAL COMMAND
- PS992 SPL: ILLEGAL AXIS MOVING
- PS993 SPL: CAN’T MAKE VECTOR
- PS995 ILLEGAL PARAMETER IN G41.2/G42.2
- PS996 G41.3/G40 FORMAT ERROR
- PS997 ILLEGAL COMMAND IN G41.3
- PS998 G41.3 ILLEGAL START_UP
- PS0999 ILLEGAL PARAMETER IN G41.3
- PS1001 ILLEGAL ORDER (NURBS)
- PS1002 NO KNOT COMMAND (NURBS)
- PS1003 ILLEGAL AXIS COMMAND (NURBS)
- PS1004 ILLEGAL KNOT
- PS1005 ILLEGAL CANCEL (NURBS)
- PS1006 ILLEGAL MODE (NURBS)
- PS1007 ILLEGAL MULTI–KNOT
- PS1008 ILLEGAL KNOT VALUE (NURBS)
- PS1009 ILLEGAL 1ST CONTROL POINT (NURBS)
- PS1010 ILLEGAL RESTART (NURBS)
- PS1070 ILLEGAL USE OF G41.5/G42.5
- PS1100 ILLEGAL PARAMETER OF MACHINE COMPONENT
Background Edit Alarms
- BG590 TH ERROR
- BG591 TV ERROR
- BG592 END OF RECORD
- BG805 ILLEGAL COMMAND
- BG806 DEVICE TYPE MISS MATCH
- BG807 PARAMETER SETTING ERROR
- BG808 DEVICE DOUBLE OPENED
- BG820 DR OFF (1)
- BG822 OVERRUN ERROR (1)
- BG823 FRAMING ERROR (1)
- BG824 BUFFER OVERFLOW (1)
- BG830 DR OFF (2)
- BG832 OVERRUN ERROR (2)
- BG833 FRAMING ERROR (2)
- BG834 BUFFER OVERFLOW (2)
- BG840 DR OFF (3)
- BG842 OVERRUN ERROR (3)
- BG843 FRAMING ERROR (3)
- BG844 BUFFER OVERFLOW (3)
- BG850 DR OFF (4)
- BG852 OVERRUN ERROR (4)
- BG853 FRAMING ERROR (4)
- BG854 BUFFER OVERFLOW (4)
- BG860 DR OFF (MODEM CARD)
- BG862 OVERRUN ERROR (MODEM CARD)
- BG863 FRAMING ERROR (MODEM CARD)
- BG864 BUFFER OVERFLOW (MODEM CARD)
- BG910 DEVICE DRIVER ERROR (UNDEFINED)
- BG911 V–DEVICE DRIVER ERROR (DEVICE)
- BG912 V–DEVICE DRIVER ERROR (OPEN)
- BG913 V–DEVICE DRIVER ERROR (COMMAND)
- BG914 V–DEVICE DRIVER ERROR (RANGE)
- BG915 V–DEVICE DRIVER ERROR (TEST)
- BG950 DRIVER ERROR (MEMORY CARD)
- BG960 ACCESS ERROR (MEMORY CARD)
- BG961 NOT READY (MEMORY CARD)
- BG962 CARD FULL (MEMORY CARD)
- BG963 CARD PROTECTED (MEMORY CARD)
- BG964 NOT MOUNTED (MEMORY CARD)
- BG965 DIRECTORY FULL (MEMORY CARD)
- BG966 FILE NOT FOUND (MEMORY CARD)
- BG967 FILE PROTECTED (MEMORY CARD)
- BG968 ILLEGAL FILE NAME (MEMORY CARD)
- BG969 ILLEGAL FORMAT (MEMORY CARD)
- BG970 ILLEGAL CARD (MEMORY CARD)
- BG971 ERASE ERROR (MEMORY CARD)
- BG972 BATTERY LOW (MEMORY CARD)
- BG973 FILE ALREADY EXIST
- BG1030 NOT READY (DATA SERVER)
- BG1032 BOARD ERROR (DATA SERVER)
- BG1033 TIME OVER (DATA SERVER)
- BG1034 CNC ERROR (DATA SERVER)
- BG1035 SEQUENCE ERROR (DATA SERVER)
- BG1036 MODE ERROR (DATA SERVER)
- BG1037 DOUBLE OPEN (DATA SERVER)
- BG1040 Device open error (Remote DGN.)
- BG1041 Illegal command (Remote DGN.)
- BG1042 Data input error (Remote DGN.)
- BG1043 Data output error (Remote DGN.)
SR Alarms
- SR125 ILLEGAL EXPRESSION FORMAT
- SR160 COMMAND DATA OVERFLOW
- SR421 SETTING COMMAND ERROR
- SR422 NOT FOUND TOOL DATA
- SR423 TOOL DATA WRITE ERROR
- SR424 OVER MAXIMUM TOOL DATA
- SR425 NOT DELETE TOOL DATA IN OPERATION
- SR580 ENCODE ALARM (PSWD&KEY)
- SR581 ENCODE ALARM (PARAMETER)
- SR590 TH ERROR
- SR591 TV ERROR
- SR592 END OF RECORD
- SR600 PARAMETER OF RESTART ERROR
- SR805 ILLEGAL COMMAND
- SR806 DEVICE TYPE MISS MATCH
- SR807 PARAMETER SETTING ERROR
- SR808 DEVICE DOUBLE OPENED
- SR820 DR OFF (1)
- SR822 OVERRUN ERROR (1)
- SR823 FRAMING ERROR (1)
- SR824 BUFFER OVERFLOW (1)
- SR830 DR OFF (2)
- SR832 OVERRUN ERROR (2)
- SR833 FRAMING ERROR (2)
- SR834 BUFFER OVERFLOW (2)
- SR840 DR OFF (3)
- SR842 OVERRUN ERROR (3)
- SR843 FRAMING ERROR (3)
- SR844 BUFFER OVERFLOW (3)
- SR850 DR OFF (4)
- SR852 OVERRUN ERROR (4)
- SR853 FRAMING ERROR (4)
- SR854 BUFFER OVERFLOW (4)
- SR855 DATA SET READY DOWN (RMT–BUF)
- SR856 BUFFER OVERFLOW (RMT–BUF)
- SR860 DR OFF (MODEM CARD)
- SR862 OVERRUN ERROR (MODEM CARD)
- SR863 FRAMING ERROR (MODEM CARD)
- SR864 BUFFER OVERFLOW (MODEM CARD)
- SR890 CHECK SUM ERROR (G05)
- SR891 ILLEGAL COMMAND G05
- SR910 DEVICE DRIVER ERROR (UNDEFINED)
- SR911 V–DEVICE DRIVER ERROR (DEVICE)
- SR912 V–DEVICE DRIVER ERROR (OPEN)
- SR913 V–DEVICE DRIVER ERROR (COMMAND)
- SR914 V–DEVICE DRIVER ERROR (RANGE)
- SR915 V–DEVICE DRIVER ERROR (TEST)
- SR940 COMMUNICATION ERROR (RMT_BUF)
- SR941 COMMUNICATION ERROR (RMT_BUF)
- SR944 COMMUNICATION ERROR (RMT_BUF)
- SR945 COMMUNICATION ERROR (RMT_BUF)
- SR946 COMMUNICATION ERROR (RMT_BUF)
- SR947 COMMUNICATION ERROR (RMT_BUF)
- SR948 COMMUNICATION ERROR (RMT_BUF)
- SR949 COMMUNICATION ERROR (RMT_BUF)
- SR950 DRIVER ERROR (MEMORY CARD)
- SR960 ACCESS ERROR (MEMORY CARD)
- SR961 NOT READY (MEMORY CARD)
- SR962 CARD FULL (MEMORY CARD)
- SR963 CARD PROTECTED (MEMORY CARD)
- SR964 NOT MOUNTED (MEMORY CARD)
- SR965 DIRECTORY FULL (MEMORY CARD)
- SR966 FILE NOT FOUND (MEMORY CARD)
- SR967 FILE PROTECTED (MEMORY CARD)
- SR968 ILLEGAL FILE NAME (MEMORY CARD)
- SR969 ILLEGAL FORMAT (MEMORY CARD)
- SR970 ILLEGAL CARD (MEMORY CARD)
- SR971 ERASE ERROR (MEMORY CARD)
- SR972 BATTERY LOW (MEMORY CARD)
- SR973 FILE ALREADY EXIST
- SR1030 NOT READY (DATA SERVER)
- SR1031 BUSY (DATA SERVER)
- SR1032 BOARD ERROR (DATA SERVER)
- SR1033 TIME OVER (DATA SERVER)
- SR1034 CNC ERROR (DATA SERVER)
- SR1035 SEQUENCE ERROR (DATA SERVER)
- SR1036 MODE ERROR (DATA SERVER)
- SR1037 DOUBLE OPEN (DATA SERVER)
- SR1040 Device open error (Remote DGN.)
- SR1041 Illegal command (Remote DGN.)
- SR1042 Data input error (Remote DGN.)
- SR1043 Data output error (Remote DGN.)
- SR1050 #200–#999ILLEGAL INPUT (UNMATCHED P–CODE MACRO COMMON)
- SR1051 #200–#499ILLEGAL P–CODE MACRO COMMON INPUT (NO OPTION)
- SR1052 #500–#549P–CODE MACRO COMMON SELECT (CANNOT USE SETVN)
- SR1053 THE NUMBER OF #30000 IS UNMATCH
- SR1054 THE NUMBER OF #40000 IS UNMATCH
Parameter Enable Switch Alarm (SW ALARM)
Servo Alarm (SV ALARM)
- SV008 EXCESS ERROR (STOP)
- SV009 EXCESS ERROR (MOVING)
- SV011 LSI OVERFLOW
- SV012 MOTION VALUE OVERFLOW
- SV013 IMPROPER V_READY OFF
- SV014 IMPROPER V_READY ON
- SV024 SYNC EXCESS ERROR ALARM 2
- SV025 V_READY ON (INITIALIZING)
- SV026 ILLEGAL AXIS ARRANGE
- SV027 ILL DGTL SERVO PARAMETER
- SV030 EMERGENCY STOP
- SV055 ILLEGAL TANDEM AXIS
- SV056 ILLEGAL TANDEM PAIR
- SV060 FSSB: OPEN READY TIME OUT
- SV061 FSSB: ERROR MODE
- SV062 FSSB: NUMBER OF AMP. IS INSUFFICIENT
- SV063 FSSB: CONFIGURATION ERROR
- SV064 FSSB: AXIS SETTING NOT COMPLETE
- SV065 FSSB: OPEN TIME OUT
- SV066 FSSB: ID DATA NOT READ
- SV067 FSSB: CONFIGURATION ERROR (SOFT)
- SV070 FSSB DISCONNECT
- SV071 ILLEGAL AMP. INTERFACE
- SV072 SEND CNC DATA FAILED
- SV073 SEND SLAVE DATA FAILED
- SV074 READ ID DATA FAILED
- SV075 MOTOR/AMP. COMBINATION
- SV076 ILLEGAL SETTING OF AXIS
- SV100 S–COMP. VALUE OVERFLOW
- SV101 DATA ERROR (ABS PCDR)
- SV109 EXCESS ERROR (G31)
- SV119 ABNORMAL TORQUE (1ST SPDL)
- SV120 ABNORMAL TORQUE (2ND SPDL)
- SV125 EXCESS VELOCITY IN TORQUE
- SV126 EXCESS ERROR IN TORQUE
- SV127 ABNORMAL TORQUE (3RD SPDL)
- SV128 ABNORMAL TORQUE (4TH SPDL)
- SV350 EXCESSIVE TORQUE DIFFERENCE
- SV360 ABNORMAL CHECKSUM (INT)
- SV361 ABNORMAL PHASE DATA (INT)
- SV363 ABNORMAL CLOCK (INT)
- SV364 SOFT PHASE ALARM (INT)
- SV365 BROKEN LED (INT)
- SV366 PULSE MISS (INT)
- SV367 COUNT MISS (INT)
- SV368 SERIAL DATA ERROR (INT)
- SV369 DATA TRANS. ERROR (INT)
- SV380 BROKEN LED (EXT)
- SV381 ABNORMAL PHASE (EXT LIN)
- SV382 COUNT MISS (EXT)
- SV383 PULSE MISS (EXT)
- SV384 SOFT PHASE ALARM (EXT)
- SV385 SERIAL DATA ERROR (EXT)
- SV386 DATA TRANS. ERROR (EXT)
- SV409 DETECT ABNORMAL TORQUE
- SV421 EXCESS ERROR (SEMI–FULL)
- SV430 SV MOTOR OVERHEAT
- SV431 CNV. OVERLOAD
- SV432 CNV. LOWVOLT CON./POWFAULT
- SV433 CNV. LOW VOLT DC LINK
- SV434 LOW VOLT CONTROL
- SV435 INV. LOW VOLT DC LINK
- SV436 SOFTTHERMAL (OVC)
- SV437 CNV. OVERCURRENT POWER
- SV438 INV. ABNORMAL CURRENT
- SV439 CNV. OVERVOLT POWER
- SV440 CNV. EX DECELERATION POW.
- SV441 ABNORMAL CURRENT OFFSET
- SV442 CNV. CHARGE FAULT/INV. DB
- SV443 CNV. COOLING FAN FAILURE
- SV444 INV. COOLING FAN FAILURE
- SV445 SOFT DISCONNECT ALARM
- SV446 HARD DISCONNECT ALARM
- SV447 HARD DISCONNECT (EXT)
- SV448 UNMATCHED FEEDBACK ALARM
- SV449 INV. IPM ALARM
- SV455 SERVO SOFTWARE NOT FOUND
- SV456 ILLEGAL CURRENT LOOP
- SV457 ILLEGAL HI HRV (250US)
- SV458 CURRENT LOOP ERROR
- SV459 HI HRV SETTING ERROR
- SV468 HI HRV SETTING ERROR(AMP)
- SV469 PARAMETER SETTING ERROR(2683–2826)
- SV600 INV. DC LINK OVER CURRENT
- SV601 INV. RADIATOR FAN FAILURE
- SV602 INV. OVERHEAT
- SV603 INV. IPM ALARM(OH)
- SV604 AMP. COMMUNICATION ERROR
- SV605 CNV. EX. DISCHARGE POW.
- SV606 CNV. RADIATOR FAN FAILURE
- SV607 CNV. SINGLE PHASE FAILURE
- SV5311 FSSB : ILLEGAL CONNECTION
Overtravel Alarm (OT ALARM)
- OT001 + OVERTRAVEL (SOFT 1)
- OT002 – OVERTRAVEL (SOFT 1)
- OT003 + OVERTRAVEL (SOFT 2)
- OT004 – OVERTRAVEL (SOFT 2)
- OT007 + OVERTRAVEL (HARD)
- OT008 – OVERTRAVEL (HARD)
- OT021 + OVERTRAVEL (PRE–CHECK)
- OT022 – OVERTRAVEL (PRE–CHECK)
- OT030 SYNC EXCESS ERROR ALARM 1
- OT031 SYNCHRONIZE ADJUST MODE
- OT032 NEED ZRN (ABS PCDR)
- OT034 BATTERY ZERO (ABS PCDR)
- OT035 IMPOSSIBLE ZRN (SERIAL)
- OT036 BATTERY DOWN (ABS PCDR)
- OT120 UNASSIGNED ADDRESS (HIGH)
- OT121 UNASSIGNED ADDRESS (LOW)
- OT122 TOO MANY MESSAGE
- OT123 MESSAGE NUMBER NOT FOUND
- OT124 OUTPUT REQUEST ERROR
- OT125 TOO LARGE NUMBER
- OT126 SPECIFIED NUMBER NOT FOUND
- OT127 DI. EIDHW OUT OF RANGE
- OT128 DI. EIDLL OUT OF RANGE
- OT129 NEGATE POS CODER 1 REV ON
- OT130 SEARCH REQUEST NOT ACCEPTED
- OT131 EXT–DATA ERROR (OTHER)
- OT132 NOT ON RETURN_POINT
- OT150 A/D CONVERT ALARM
- OT151 A/D CONVERT ALARM
- OT184 PARAMETER ERROR IN TORQUE
- OT449 ZERO RETURN NOT FINISHED
- OT450 ZERO RETURN NOT FINISHED
- OT451 IMPROPER PMC AXIS COMMAND
- OT512 EXCESS VELOCITY
- OT513 SYNC EXCESS ERROR
- OT553 EXCESS VELOCITY IN G43.4/G43.5
- OT710 ILLEGAL ACC. PARAMETER (OPTIMUM TORQUE ACC/DEC)
File Access Alarm (IO ALARM)
Power Mmust Be Turned Off Alarm (PW ALARM)
- PW000 POWER MUST BE OFF
- PW100 ILLEGAL PARAMETER (S–COMP.)
- PW102 ILLEGAL PARAMETER (I–COMP.)
- PW103 ILLEGAL PARAMETER (S–COMP.128)
Spindle Alarm (SP ALARM)
- SP001 SSPA: 01 MOTOR OVERHEAT
- SP002 SSPA: 02 EX DEVIATION SPEED
- SP003 SSPA: 03 DC–LINK FUSE IS BROKEN
- SP004 SSPA: 04 POWER SUPPLY ERROR
- SP005 SSPA: XX DECODED ALARM
- SP006 SSPA: XX DECODED ALARM
- SP007 SSPA: 07 OVER SPEED
- SP008 SSPA: XX DECODED ALARM
- SP009 SSPA: 09 OVERHEAT MAIN CIRCUIT
- SP010 SSPA: 10 LOW VOLT INPUT POWER
- SP011 SSPA: 11 OVERVOLT POWER CIRCUIT
- SP012 SSPA: 12 OVERCURRENT POWER CIRCUIT
- SP013 SSPA: 13 CPU DATA MEMORY FAULT
- SP014 SSPA: XX DECODED ALARM
- SP015 SSPA: 15 SPINDLE SWITCHING FAULT
- SP016 SSPA: 16 RAM ERROR
- SP017 SSPA: XX DECODED ALARM
- SP018 SSPA: 18 SUMCHECK ERROR PROGRAM ROM
- SP019 SSPA: 19 EXCESS OFFSET CURRENT U
- SP020 SSPA: 20 EXCESS OFFSET CURRENT V
- SP021 SSPA: XX DECODED ALARM
- SP022 SSPA: XX DECODED ALARM
- SP023 SSPA: XX DECODED ALARM
- SP024 SSPA: 24 SERIAL TRANSFER ERROR
- SP025 SSPA: 25 SERIAL TRANSFER STOP
- SP026 SSPA: 26 DISCONNECT CS VELOCITY DETECTOR
- SP027 SSPA: 27 DISCONNECT POSITION CODER
- SP028 SSPA: 28 DISCONNECT CS POSITION DETECTOR
- SP029 SSPA: 29 OVERLOAD
- SP030 SSPA: 30 OVERCURRENT INPUT CIRCUIT
- SP031 SSPA: 31 MOTOR LOCK OR DISCONNECT DETECTOR
- SP032 SSPA: 32 SIC–LSI RAM FAULT
- SP033 SSPA: 33 SHORTAGE POWER CHARGE
- SP034 SSPA: 34 ILLEGAL PARAMETER
- SP035 SSPA: 35 ILLEGAL GEAR RATIO PARAMETER
- SP036 SSPA: 36 OVERFLOW ERROR COUNTER
- SP037 SSPA: 37 ILLEGAL SETTING VELOCITY DETECTOR
- SP038 SSPA: XX DECODED ALARM
- SP039 SSPA: 39 ILLEGAL 1 REV SIGN OF CS DETECTOR
- SP040 SSPA: 40 NO 1 REV SIGN OF CS DETECTOR
- SP041 SSPA: 41 ILLEGAL 1 REV SIGN OF POSITION CODER
- SP042 SSPA: 42 NO 1 REV SIGN OF POSITION CODER
- SP043 SSPA: 43 DISCONNECT POSITION CODER DEF. SPEED
- SP044 SSPA: 44 ILLEGAL A/D CONVERT
- SP045 SSPA: XX DECODED ALARM
- SP046 SSPA: 46 ILLEGAL 1 REV SIGN OF SCREW CUT
- SP047 SSPA: 47 ILLEGAL SIGNAL OF POSITION CODER
- SP048 SSPA: XX DECODED ALARM
- SP049 SSPA: 49 DEF. SPEED IS OVER VALUE
- SP050 SSPA: 50 SYNCRONOUS VALUE IS OVER SPEED
- SP051 SSPA: 51 LOW VOLT POWER CIRCUIT
- SP052 SSPA: 52 ITP FAULT 1
- SP053 SSPA: 53 ITP FAULT 2
- SP054 SSPA: 54 OVERCURRENT
- SP055 SSPA: 55 ILLEGAL POWER LINE
- SP056 SSPA: 56 FAN FOR CONTROL CIRCUIT IS STOP
- SP057 SSPA: XX DECODED ALARM
- SP058 SSPA: 58 MAIN CIRCUIT OVERLOAD
- SP059 SSPA: 59 FAN STOP
- SP062 MOTOR VCMD OVERFLOWED
- SP066 COM. ERROR BETWEEN SP AMPS
- SP073 MOTOR SENSOR DISCONNECTED
- SP074 CPU TEST ERROR
- SP075 CRC ERROR
- SP079 INITIAL TEST ERROR
- SP080 ALARM AT THE OTHER SP AMP.
- SP081 1–ROT MOTOR SENSOR ERROR
- SP082 NO 1–ROT MOTOR SENSOR
- SP083 MOTOR SENSOR SIGNAL ERROR
- SP084 SPNDL SENSOR DISCONNECTED
- SP085 1–ROT SPNDL SENSOR ERROR
- SP086 NO 1–ROT SPNDL SENSOR
- SP087 SPNDL SENSOR SIGNAL ERROR
- SP088 COOLING RADI FAN FAILURE
- SP097 OTHER SPINDLE ALARM
- SP098 OTHER CONVERTER ALARM
- SP110 AMP COMMUNICATION ERROR
- SP111 CONV. LOW VOLT CONTROL
- SP112 CONV. EX. DISCHARGE POW.
- SP113 CONV. COOLING FAN FAILURE
- SP120 COMMUNICATION DATA ERROR
- SP121 COMMUNICATION DATA ERROR
- SP122 COMMUNICATION DATA ERROR
- SP201 MOTOR NUMBER DUPLICATE
- SP202 SPINDLE SELECT ERROR
- SP220 NO SPINDLE AMP.
- SP221 ILLEGAL MOTOR NUMBER
- SP222 CAN NOT USE ANALOG SPINDLE
- SP223 CAN NOT USE SERIAL SPINDLE
- SP224 ILLEGAL SPINDLE–POSITION CODER GEAR RATIO
- SP225 CRC ERROR (SERIAL SPINDLE)
- SP226 FRAMING ERROR (SERIAL SPINDLE)
- SP227 RECEIVING ERROR (SERIAL SPINDLE)
- SP228 COMMUNICATION ERROR (SERIAL SPINDLE)
- SP229 COMMUNICATION ERROR SERIAL SPINDLE AMP.
- SP230 MOTOR NUMBER OUT OF RANGE
- SP231 SPINDLE EXCESS ERROR (MOVING)
- SP232 SPINDLE EXCESS ERROR (STOP)
- SP233 POSITION CODER OVERFLOW
- SP234 GRID SHIFT OVERFLOW
- SP235 ORIENTATION COMMAND OVERFLOW
- SP236 DUPLICATE SPINDLE CONTROL MODE (CHANGING)
- SP237 DUPLICATE SPINDLE CONTROL MODE (SPOS)
- SP238 DUPLICATE SPINDLE CONTROL MODE (RIGID TAP)
- SP239 DUPLICATE SPINDLE CONTROL MODE (CS)
- SP240 DISCONNECT POSITION CODER
- SP241 D/A CONVERTER ERROR
- SP242 OVERHEAT
- SP245 COMMUNICATION DATA ERROR
- SP246 COMMUNICATION DATA ERROR
- SP247 COMMUNICATION DATA ERROR
- SP968 SSPA: XX DECODED ALARM
- SP969 SPINDLE CONTROL ERROR
- SP970 SPINDLE CONTROL ERROR
- SP971 SPINDLE CONTROL ERROR
- SP972 SPINDLE CONTROL ERROR
- SP973 SPINDLE CONTROL ERROR
- SP974 ANALOG SPINDLE CONTROL ERROR
- SP975 ANALOG SPINDLE CONTROL ERROR
- SP976 SERIAL SPINDLE COMMUNICATION ERROR
- SP977 SERIAL SPINDLE COMMUNICATION ERROR
- SP978 SERIAL SPINDLE COMMUNICATION ERROR
- SP979 SERIAL SPINDLE COMMUNICATION ERROR
- SP980 SERIAL SPINDLE AMP. ERROR
- SP981 SERIAL SPINDLE AMP. ERROR
- SP982 SERIAL SPINDLE AMP. ERROR
- SP983 SERIAL SPINDLE AMP. ERROR
- SP984 SERIAL SPINDLE AMP. ERROR
- SP985 SERIAL SPINDLE CONTROL ERROR
- SP986 SERIAL SPINDLE CONTROL ERROR
- SP987 SERIAL SPINDLE CONTROL ERROR
- SP988 SPINDLE CONTROL ERROR
- SP989 SPINDLE CONTROL ERROR
- SP996 ILLEGAL SPINDLE PARAMETER SETTING
- SP997 SPINDLE CONTROL ERROR
- SP998 SPINDLE CONTROL ERROR
- SP999 SPINDLE CONTROL ERROR
