Fanuc 31i G codes list for cnc machinists programmers who work on cnc machining centers with Fanuc 30i 31i 32i cnc controls.
Fanuc CNC Controls
Following list of g codes applies to following cnc controls as well.
- Fanuc Series 30i/300i/300is-MODEL A
- Fanuc Series 31i/310i/310is-MODEL A5
- Fanuc Series 32i/320i/320is-MODEL A
Fanuc 31i G Codes
G Code | Description |
G00 | Positioning (rapid traverse) |
G01 | Linear interpolation (cutting feed) |
G02 | Circular interpolation CW or helical interpolation CW |
G03 | Circular interpolation CCW or helical interpolation CCW |
G02.2, G03.2 | Involute interpolation CW/CCW |
G02.3, G03.3 | Exponential interpolation CW/CCW |
G02.4, G03.4 | Three-dimensional coordinate conversion CW/CCW |
G04 | Dwell |
G05 | AI contour control (high-precision contour control compatible command) |
G05.1 | AI contour control / Nano smoothing / Smooth interpolation |
G05.4 | HRV3,4 on/off |
G06.2 | NURBS interpolation |
G07 | Hypothetical axis interpolation |
G07.1 (G107) | Cylindrical interpolation |
G08 | AI contour control (advanced preview control compatible command) |
G09 | Exact stop |
G10 | Programmable data input |
G10.6 | Tool retract and recover |
G10.9 | Programmable switching of diameter/radius specification |
G11 | Programmable data input mode cancel |
G12.1 | Polar coordinate interpolation mode |
G13.1 | Polar coordinate interpolation cancel mode |
G15 | Polar coordinates command cancel |
G16 | Polar coordinates command |
G17 | XY plane selection |
G18 | ZX plane selection |
G19 | YZ plane selection |
G20 (G70) | Input in inch |
G21 (G71) | Input in mm |
G22 | Stored stroke check function on |
G23 | Stored stroke check function off |
G25 | Spindle speed fluctuation detection off |
G26 | Spindle speed fluctuation detection on |
G27 | Reference position return check |
G28 | Automatic return to reference position |
G29 | Movement from reference position |
G30 | 2nd, 3rd and 4th reference position return |
G30.1 | Floating reference position return |
G31 | Skip function |
G31.8 | EGB-axis skip |
G33 | Threading |
G34 | Variable lead threading |
G35 | Circular threading CW |
G36 | Circular threading CCW |
G37 | Automatic tool length measurement |
G38 | Cutter or tool nose radius compensation : preserve vector |
G39 | Cutter or tool nose radius compensation : corner circular interpolation |
G40 | Cutter or tool nose radius compensation : cancel Three-dimensional cutter compensation : cancel |
G41 | Cutter or tool nose radius compensation : left Three-dimensional cutter compensation : left |
G41.2 | Cutter compensation for 5-axis machining : left (type 1) |
G41.3 | Cutter compensation for 5-axis machining : (leading edge offset) |
G41.4 | Cutter compensation for 5-axis machining : left (type 1) (FS16i-compatible command) |
G41.5 | Cutter compensation for 5-axis machining : left (type 1) (FS16i-compatible command) |
G41.6 | Cutter compensation for 5-axis machining : left (type 2) |
G42 | Cutter or tool nose radius compensation : right Three-dimensional cutter compensation : right |
G42.2 | Cutter compensation for 5-axis machining : right (type 1) |
G42.4 | Cutter compensation for 5-axis machining : right (type 1) (FS16i-compatible command) |
G42.5 | Cutter compensation for 5-axis machining : right (type 1) (FS16i-compatible command) |
G42.6 | Cutter compensation for 5-axis machining : right (type 2) |
G40.1 | Normal direction control cancel mode |
G41.1 | Normal direction control on : right |
G42.1 | Normal direction control on : left |
G43 | Tool length compensation + |
G44 | Tool length compensation – |
G43.1 | Tool length compensation in tool axis direction |
G43.4 | Tool center point control (type 1) |
G43.5 | Tool center point control (type 2) |
G45 | Tool offset increase |
G46 | Tool offset decrease |
G47 | Tool offset double increase |
G48 | Tool offset double decrease |
G49 (G49.1) | Tool length compensation cancel |
G50 | Scaling cancel |
G51 | Scaling |
G50.1 | Programmable mirror image cancel |
G51.1 | Programmable mirror image |
G50.2 | Polygon turning cancel |
G51.2 | Polygon turning |
G52 | Local coordinate system setting |
G53 | Machine coordinate system setting |
G53.1 | Tool axis direction control |
G54 (G54.1) | Workpiece coordinate system 1 selection |
G55 | Workpiece coordinate system 2 selection |
G56 | Workpiece coordinate system 3 selection |
G57 | Workpiece coordinate system 4 selection |
G58 | Workpiece coordinate system 5 selection |
G59 | Workpiece coordinate system 6 selection |
G60 | Single direction positioning |
G61 | Exact stop mode |
G62 | Automatic corner override |
G63 | Tapping mode |
G64 | Cutting mode |
G65 | Macro call |
G66 | Macro modal call A |
G66.1 | Macro modal call B |
G67 | Macro modal call A/B cancel |
G68 | Coordinate system rotation start or 3-dimensional coordinate conversion mode on |
G69 | Coordinate system rotation cancel or 3-dimensional coordinate conversion mode off |
G68.2 | Feature coordinate system selection |
G72.1 | Figure copy (rotation copy) |
G72.2 | Figure copy (linear copy) |
G73 | Peck drilling cycle |
G74 | Left-handed tapping cycle |
G76 | Fine boring cycle |
G80 | Canned cycle cancel |
G80.5 | Electronic gear box 2 pair: synchronization cancellation |
G80.8 | Electronic gear box: synchronization cancellation |
G81 | Drilling cycle or spot boring cycle |
G81.1 | Chopping |
G81.5 | Electronic gear box 2 pair: synchronization start |
G81.8 | Electronic gear box: synchronization start |
G82 | Drilling cycle or counter boring cycle |
G83 | Peck drilling cycle |
G84 | Tapping cycle |
G84.2 | Rigid tapping cycle (FS15 format) |
G84.3 | Left-handed rigid tapping cycle (FS15 format) |
G85 | Boring cycle |
G86 | Boring cycle |
G87 | Back boring cycle |
G88 | Boring cycle |
G89 | Boring cycle |
G90 | Absolute programming |
G91 | Incremental programming |
G91.1 | Checking the maximum incremental amount specified |
G92 | Setting for workpiece coordinate system or clamp at maximum spindle speed |
G92.1 | Workpiece coordinate system preset |
G93 | Inverse time feed |
G94 | Feed per minute |
G95 | Feed per revolution |
G96 | Constant surface speed control |
G97 | Constant surface speed control cancel |
G98 | Canned cycle : return to initial level |
G99 | Canned cycle : return to R point level |
G107 | Cylindrical interpolation |
G112 | Polar coordinate interpolation mode |
G113 | Polar coordinate interpolation mode cancel |
