Fanuc Alarm PS470 G40.1 to G42.1 PARAMETER MISS
Fanuc Alarm Description
Fanuc 15i
The normal line direction control axes parameter settings are erroneous.
· Set the normal line direction control axis setting in NDC parameter No. 1006#6. Only one axis can be set to “1”; this is not possible for multiple axes.
· Set the axis for which NDC parameter No. 1006#6 is set to “1” to axis of rotation (ROT parameter No. 1006#6=1, and parameter No. 1022=2).
· Set the feedrate when rotation of the normal line direction control axis is set to parameter No. 1472 within the range 1 to 5000 degrees/min.
