Fanuc Alarm PS593 EGB PARAMETER SETTING ERROR
Fanuc Alarm Description
Fanuc 15i
Erroneous EGB parameter setting
(1) The setting of SYN parameter No. 1955#0 is incorrect.
(2) The slave axes set by the G81 code are not set to rotary axes. (ROT and ROS parameter Nos. 1006#0, #1)
(3) The number of pulses (parameter Nos. 5596, 5597) per rotation is not set.
(4) Parameter No. 5995 is not set by the hobbing machine compatible instruction.
