Each generation of FANUC computerized numerical control system has different levels of capabilities, and these are generally referred to by a model or series number.
Each Fanuc cnc controls model is typically available with several device control capabilities, depending on what software functions are licensed for use on that device. Some common fanuc cnc control capabilities are:
M – Milling
T – Turning (lathe)
TT – Twin Turret
P – Punch press
G – Grinding
Within each model name, there can also be generational updates for each model, usually indicated by a trailing letter.
Contents
Fanuc CNC Controls Model Names with Types
FANUC Milling CNC Controls
FANUC-0MA, FANUC 0-MA, FANUC 0M-A, FANUC 0M/A, FANUC 0-M-A, FANUC 0-M/A, FANUC 0 M-A, FANUC 0 M/A, FANUC-0M Model A, FANUC 0-M Model A, FANUC 0/M Model A
FANUC Punching CNC Controls
FANUC-OPA, FANUC O-PA, FANUC OP-A, FANUC OP/A, FANUC O-P-A, FANUC O-P/A, FANUC O P-A, FANUC O P/A, FANUC-OP Model A, FANUC O-P Model A, FANUC O/P Model A
FANUC Turning CNC Controls
FANUC-0TB, FANUC 0-TB, FANUC 0T-B, FANUC 0T/B, FANUC 0-T-B, FANUC 0-T/B, FANUC 0 T-B, FANUC 0 T/B, FANUC-0T Model B, FANUC 0-T Model B, FANUC 0/T Model B
Twin Turret FANUC CNC Controls
FANUC-0TTB, FANUC 0-TTB, FANUC 0TT-B, FANUC 0TT/B, FANUC 0-TT-B, FANUC 0-TT/B, FANUC 0 TT-B, FANUC 0 TT/B, FANUC-0TT Model B, FANUC 0-TT Model B, FANUC 0/TT Model B
FANUC Grinding CNC Controls
FANUC-0GC, FANUC 0-GC, FANUC 0G-C, FANUC 0G/C, FANUC 0-G-C, FANUC 0-G/C, FANUC 0 G-C, FANUC 0 G/C, FANUC-0G Model C, FANUC 0-G Model C, FANUC 0/G Model C
Source: Wikipedia
