Fanuc G43 G44 G49 Tool Length Compensation
G43 Tool Length Compensation positive
With G43 a value from the offset register (OFFSET) can be called up and added to tool length.
To all following Z movements (with active XY plane – G17) in the program this value will be added.
N...  G43  H...
Example
N...   G43 H05
The value, which is written into the register under H05, will be added to all following Z movements as tool length.
G44 Tool Length Compensation negative
With G44 a value from the offset register (OFFSET) can be called up and subtracted from tool length.
To all following Z movements (with active XY plane – G17) in the program this value will be subtracted from.
N...  G44  H...
G49 Cancel Tool Length Compensation
The positive (G43) or negative (G44) shift will be cancelled.
N...  G49
