M-code are cnc program instructions which help cnc machinist/programmer to control cnc machine hardware like chuck, tailstock, quill, coolant. Here are listed M-code which are mostly used on cnc lathe/mill with Fanuc cnc control.
Fanuc M-Code List (Lathe)
M code | Description |
M00 | Program stop |
M01 | Optional program stop |
M02 | End of program |
M03 | Spindle start forward CW |
M04 | Spindle start reverse CCW |
M05 | Spindle stop |
M08 | Coolant on |
M09 | Coolant off |
M29 | Rigid tap mode |
M30 | End of program reset |
M40 | Spindle gear at middle |
M41 | Low Gear Select |
M42 | High Gear Select |
M68 | Hydraulic chuck close |
M69 | Hydraulic chuck open |
M78 | Tailstock advancing |
M79 | Tailstock reversing |
M94 | Mirrorimage cancel |
M95 | Mirrorimage of X axis |
M98 | Subprogram call |
M99 | End of subprogram |
Fanuc M-Code List (Mill)
M06 | Tool change |
M07 | Coolant ON – Mist coolant/Coolant thru spindle |
M08 | Coolant ON – Flood coolant |
M09 | Coolant OFF |
M19 | Spindle orientation |
M28 | Return to origin |
M29 | Rigid tap |
M30 | End of program (Reset) |
M41 | Low gear select |
M42 | High gear select |
M94 | Cancel mirrorimage |
M96 | Mirrorimage of Y axis |
