Fanuc M Codes for Fadal Machining Centers with FANUC Series 18i–MB5 CNC Controls.
Fanuc M Codes
M00 | Program Stop |
M01 | Optional Program Stop |
M02 | End-of-Program |
M30 | End-of-Program |
M98 | Sub-Program Call |
M99 | Sub Program End |
M03 | Spindle Start Forward CW |
M04 | Spindle Start Reverse CCW |
M05 | Spindle Stop |
M06 | Tool Change |
M07 | Coolant ON – Mist Coolant/Coolant Thru Spindle |
M08 | Coolant ON – Flood Coolant |
M09 | Coolant OFF |
M11 | Set Tool Carousel position to 1 (ATC Tool Changer ONLY) |
M19 | FANUC canned cycle positioning,(Not for spindle orientation) |
M20 | Wash Down, Toggle ON/OFF |
M20 | MIDACO pallet change 1 |
M20 | Does nothing |
M22 | Chip Conveyor Toggle ON/OFF |
M29 | Rigid Tap |
M41 | Low Gear Select |
M42 | High Gear Select |
M48 | 100% Spindle Speed Override Forced |
M49 | 100% Spindle Speed Override Released |
M60 | A Axis Brake ON |
M61 | A Axis Brake OFF |
M62 | B Axis Brake ON |
M63 | B Axis Brake OFF |
M64 | M64/65 Output ON |
M65 | M64/65 Output OFF |
M66 | M66/67 Output ON, Chip Conveyor ON |
M67 | M66/67 Output OFF, Chip Conveyor OFF |
M68 | M68/69 Output ON, Wash Down ON |
M69 | M68/69 Output OFF, Wash Down OFF |
M78 | M78/79 Output ON, Cooled spindle ON |
M79 | M78/79 Output OFF, Cooled spindle OFF |
M80 | MIDACO Pallet Changer 2 |
M85 | A Axis Rotary Table Enable |
M86 | A Axis Rotary Table Disable |
M87 | B Axis Rotary Table Enable |
M88 | B Axis Rotary Table Disable |
M100 | Position Tool Drum to Pocket by T-Word Ex: “M100 T05” |
M150 | Return the current tool to ATC carousel(ATC ONLY) |
M151 | Transfer the tool from carousel into spindle.(ATC ONLY) |
M190 | Spindle Orient for tool changer |
