Sample G Code Program for Beginners
Sample G code program example for cnc programmers / cnc machinists who work or want to learn cnc mill programming.
A similar G code example can be found here
Simple G Code Example Mill – G code Programming for Beginners
If you are interested in G code subroutine example (sub program) read
CNC Mill Contour Pecking – Fanuc Subprogram Repeat Example
This is the same component but this time we are machining it in taper.
G Code Example
G Code Example Mill
O1000 T1 M6 G0 G90 G40 G21 G17 G94 G80 G54 X-75 Y-25 S500 M3 (Start Point) G43 Z100 H1 Z5 G1 Z-20 F100 X-50 M8 (Position 1) Y0 (Position 2) X0 Y50 (Position 3) X50 Y0 (Position 4) X0 Y-50 (Position 5) X-50 Y0 (Position 6) Y25 (Position 7) X-75 (Position 8) G0 Z100 M30
