AMADA AE NT Series CNC Turret Punch Press G-Codes and M-Codes for cnc machinists who work on Amada AE255NT / AE2510NT CNC turret punch presses.
G Codes AMADA CNC Turret Punch Press
G Code | Description |
G00 | Linear interpolation cancel |
G01 | Linear interpolation start |
G04 | Dwell |
G06 | Designation of worksheet thickness and material |
G20/G21 | Inch/metric select function |
G25 | Auto-repositioning |
G27 | Auto-repositioning |
G26 | Bolt hole circle [BHC] |
G28 | Line at angle [LAA] |
G29 | Arc [ARC] |
G36 | Grid-X [GRD-X] |
G37 | Grid-Y [GRD-Y] |
G50 | Home retract |
G66 | Shear proof [SHP] |
G67 | Square [SQR] |
G68 | Nibbling arc [NBL-A] |
G69 | Nibbling line [NBL-L] |
G70 | Punch off (No punching) |
G72 | Pattern origin |
G73 | Symmetry (option) |
G78 | Punching arc [PNC-A] |
G79 | Punching line [PNC-L] |
G90 | Absolute programming |
G91 | Incremental programming |
G92 | Establishing coordinate system |
G93 | Offset-1 [OFS-1] |
G94 | Offset-2 [OFS-2] |
M Codes AMADA CNC Turret Punch Press
M Code | Function |
M00 | Program stop |
M01 | Optional stop |
M02 | Program end |
M08 | Beginning of punching completion signal delay |
M09 | End of punching completion signal delay |
M10 | Work hold and unclamp |
M11 | Work hold and release |
M12 | Nibbling pattern |
M13 | Press mode cancel |
M30 | End of tape |
M31 | Rear workholder and cassette cylinder lower |
M32 | Side table bearings lower |
M33 | Loading command |
M34 | Unloading command |
M35 | Job search end |
M36 | Unloading preparation command |
M37 | Penultimate worksheet signal |
M38 | Job end signal |
M39 | Total job end signal |
M80 | Workchute open |
M81 | Workchute close |
M96 | Subprogram recall command |
M97 | Subprogram end command |
M120 | Mild mode on |
M121 | Mild mode cancel |
M500 | Punching pattern (punch without shear angle) |
M501 | Punching pattern (punch with shear angle) |
M502 to M505 M570 to M575 | Knockout pattern |
M506 to M509 | Slitting pattern |
M510 to M559 M800 to M999 | Forming pattern |
M560 to M569 | Marking pattern |
M681 to M683 | Punching speed |
M686 | Punching speed command cancel |
M687 | Standby position compensation cancel (for forming patterns) |
M690 | Press air blow |
M691 | Press air blow cancel |
M692 | Press raise |
M693 | Press raise cancel |
M696 | NEX tool punching mode on |
M697 | NEX tool punching mode cancel |
