This article explains the use of G02 G03 G code. The G code G02, G03 are used for Circular Interpolation in cnc programming.
Contents
G02 G03 G Code Circular Interpolation
G02 G Code Clock wise Circular Interpolation.
G03 G Code Counter Clock wise Circular Interpolation.
There are multiple articles/cnc program examples about G code circular interpolation, here is the list of few articles so that cnc machinists can easily navigate through different cnc programming articles.
G02 G03 G Code Example CNC Programs (G code Arc Examples)
- CNC Circular Interpolation Tutorial G02 G03
- Fanuc CNC Lathe Programming Example
- CNC Programming Example G Code G02 Circular Interpolation Clockwise
- Fanuc G20 Measuring in Inches with CNC Program Example
- CNC Arc Programming Exercise
- CNC Programming for Beginners a CNC Programming Example
- CNC Lathe Programming Example
Here is a new cnc programming examples which shows the use of G02 G03 G code circular interpolation.
G02 G03 G Code Example Program
G02 G03 G Code Circular Interpolation Example Program
N20 G50 S2000 T0300 G96 S200 M03 G42 G00 X35.0 Z5.0 T0303 M08 G01 Z-20.0 F0.2 G02 X67.0 Z-36.0 R16.0 G01 X68.0 : G03 X100.0 Z-52.0 R16.0 G01 Z-82.0 G40 G00 X200.0 Z200.0 M09 T0300 M30
G Code G02 G03 I & K Example Program
G02 G03 G Code Circular Interpolation can be programmed in two ways,
G02 X... Z... R... G02 X... Z... I... K...
The below is the same cnc program but this version uses I & K with G02 G03 G code.
N20 G50 S2000 T0300 G96 S200 M03 G42 G00 X35.0 Z5.0 T0303 M08 G01 Z-20.0 F0.2 G02 X67.0 Z-36.0 I16.0 K0 G01 X68.0 : G03 X100.0 Z-52.0 I0 K-16.0 G01 Z-82.0 G40 G00 X200.0 Z200.0 M09 T0300 M30
