Following cnc programming code shows the use of G72 bolt hole along an angle.
As the names states G72 G-code makes it very easy to drill/bore/tap evenly spaced hole along a specified angle.
Canned cycles G73, G74, G76, G77, or G81-G89 can be used with G72 bolt hole along an angle command.
G72 Bolt Holes Along an Angle Format
G72 I J L
I – Distance between bolt holes along an angle
J – Angle of holes from three o’clock, 0 to 360.0 degrees CCW.
L – Number of evenly spaced holes along an angle
More info G72 Bolt Holes Along an Angle – CNC Milling Programming
CNC Program Example G72 Bolt Hole Along an Angle
O0009 N10 T3 M06 N20 G90 G54 G00 X0.65 Y-1.5 (Start position of bolt holes along an angle) N30 S1451 M03 N40 G43 H03 Z1. M08 N50 G81 G99 Z-0.45 R0.1 G72 I0.5 J20. L7 F8. N60 G80 G00 Z1. M09 N70 G53 G49 Z0. M05 N80 M30
