EMCO WinNC GE Series Fanuc 21 TB programming G codes / M codes / Cycles complete lists.
G Codes
G Code | Description |
G00 | Positioning (rapid traverse) |
G01 | Linear interpolation (feed) |
G02 | Circular interpolation clockwise |
G03 | Circular interpolation counterclockwise |
G04 | Dwell |
G7.1 | Cylindrical Interpolation |
G10 | Data setting |
G11 | Data setting Off |
G12.1 | Polar Coordinate Interpolation ON |
G13.1 | Polar Coordinate Interpolation OFF |
G17 | Plane selection XY |
G18 | Plane selection ZX |
G19 | Plane selection YZ |
G20 | Longitudinal turning cycle |
G21 | Thread cutting cycle |
G24 | Face turning cycle |
G28 | Return to reference point |
G33 | Thread cutting |
G40 | Cancel cutter radius compensation |
G41 | Cutter radius compensation left |
G42 | Cutter radius compensation right |
G70 | Inch data input |
G71 | Metric data input |
G72 | Finishing cycle |
G73 | Stock removal in turning |
G74 | Stock removal in facing |
G75 | Pattern repeating |
G76 | Deep hole drilling, cut-in cycle in Z |
G77 | Cut-in cycle in X |
G78 | Multiple threading cycle |
G80 | Cancel cycles (G83 up to G85) |
G83 | Drilling cycle |
G84 | Tapping cycle |
G85 | Reaming cycle |
G90 | Absolute programming |
G91 | Incremental programming |
G92 | Coordinate system setting, spindle speed limit |
G94 | Feed per minute |
G95 | Feed per revolution |
G96 | Constant cutting speed |
G97 | Direct spindle speed programming |
G98 | Return to initial plane |
G99 | Return to withdrawal plane |
M Codes
M Code | Description |
M0 | Programmed stop |
M1 | Programmed stop. conditional |
M2 | Program end |
M3 | Spindle ON clockwise |
M4 | Spindle ON counterclockwise |
M5 | Spindle OFF |
M8 | Coolant ON |
M9 | Coolant OFF |
M13 | Driven tools ON clockwise |
M14 | Driven tools ON counterclockwise |
M15 | DRIVEN TOOLS OFF |
M20 | Quill FORWARD |
M21 | Quill BACKWARD |
M23 | Collecting tray BACKWARD |
M24 | Collecting tray FORWARD |
M25 | Clamping device OPEN |
M26 | Clamping device CLOSE |
M30 | Main program end |
M32 | Program end for loading operation |
M52 | Round axis operation (C-axis ON) |
M53 | Spindle operation (C-axis OFF) |
M57 | Spindle oscillate ON |
M58 | Spindle oscillate OFF |
M67 | Bar feed / loading magazine feed ON |
M68 | Bar feed / loading magazine feed OFF |
M69 | Bar change |
M71 | Blow-out ON |
M72 | Blow-out OFF |
M90 | Manual clamping chuck |
M91 | Tensile clamping device |
M92 | Pressure clamping device |
M93 | Final position monitoring OFF |
M94 | Bar feed / loading magazine activate |
M95 | Bar feed / loading magazine deactivate |
M98 | Subroutine call |
M99 | Subroutine end. jump command |
Addresses
Address | Description |
O | program number 1 to 9499 for part programs and subroutines |
N | block number 1 to 9999 |
G | path function |
X, Z | position data in absolute values (X also dwell time) |
U, W | position data in incremental values (U also dwell time) |
R | radius, taper value, cycle parameter |
C | chamfer |
I, K | circle parameter |
F | feed rate, thread pitch |
S | spindle speed, cutting speed |
T | tool call (tool correction) |
M | miscellaneous function |
P | dwell, subprogram call, cycle parameter |
Q | cycle parameter |
; | block end |
