GTCNC-60TT G Codes M Codes
GREAT-60TT or GTCNC-60TT G Codes M Codes for CNC Lathe.
G Codes
G Code | Description |
G00 | Rapid motion |
G01 | Linear interpolation |
G02 | Circular interpolation CW |
G03 | Circular interpolation CCW |
G33 | Thread cutting |
G04 | Dwell |
G20 | Inch format input |
G21 | Metric format input |
G28 | X, Z axis return to the first reference point |
G281 | X axis return to the first reference point |
G283 | Z axis return to the first reference point |
G26 | ZX axis return to program original point |
G261 | X axis return to program original point |
G263 | Z axis return to program original point |
G40 | tool radius compensation cancel |
G41 | Cutter radius compensation, left |
G42 | Cutter radius compensation, right |
G60 | Accurate positioning |
G64 | Continual path processing |
G77 | Cylindrical/conical in/ex diameter cutting canned cycle |
G78 | Thread cutting canned cycle |
G79 | End face cutting canned cycle |
G70 | Finish turning cycle |
G71 | Cylindrical rough turning multi-cycle |
G72 | End face rough turning multi-cycle |
G173 | Multiple mode contour rough turning multi-cycle |
G174 | End face pick drilling multi-cycle |
G175 | Interior/exterior diameter drilling/grooving multi-cycle |
G176 | Thread cutting multi-cycle |
G90 | Absolute programming |
G91 | Incremental programming |
G52 | Set local coordinates |
G94 | Feed per minute mode |
G95 | Feed per revolution mode |
G96 | Constant surface speed control |
G97 | Constant surface speed control cancel |
G22 | Program recycle |
G800 | Program recycle cancel |
M Codes
M Code | Description |
M00 | Program pause. |
M02 | Program end. |
M30 | Program end. |
M20 | Program end, repeated executes program according to running times set in parameter, applied to test CNC |
M03 | Spindle CW |
M04 | Spindle CCW |
M05 | Spindle stop |
M08 | Cooling on |
M09 | Cooling off |
M10 | Chuck clamping |
M11 | Chuck unclamping |
M55 | Center tightening |
M54 | Center release |
M23 | Lubricate on |
M22 | Lubricate off |
M25 | Self-defined 1 on |
M24 | Self-defined 1 off |
M71 | Self-defined 2 on |
M70 | Self-defined 2 off |
M73 | Self-defined 3 on |
M72 | Self-defined 3 off |
M75 | Self-defined 4 on |
M74 | Self-defined 4 off |
M77 | Self-defined 5 on |
M76 | Self-defined 5 off |
M79 | Self-defined 6 on |
M78 | Self-defined 6 off |
M81 | Self-defined 7 on |
M80 | Self-defined 7 off |
M83 | Self-defined 8 on |
M82 | Self-defined 8 off |
M12 | Check 0V valid |
M13 | Check +24V valid |
M18 | Check 0V valid |
M19 | Check +24V valid |
M28 | Check 0V valid |
M29 | Check +24V valid |
M14 | Check 0V valid skip |
M15 | Check +24V valid skip |
M16 | Check 0V valid skip |
M17 | Check +24V valid skip |
M97 | Skip |
M98 | Calling |
M99 | Calling return |
M41 | 1st grade |
M42 | 2nd grade |
M43 | 3rd grade |
M44 | 4th grade |
M317 | Clear X-axis of Machine coordinates |
M319 | Clear Z-axis of Machine coordinates |
M320 | Clear both X and Z-axis of Machine coordinates |
