Haas
Haas Programming examples with brief tutorials, Haas lathe/mill set-up articles, G & M codes, Alarms/Errors
Haas Corner Rounding and Chamfering Program Example
O00025 T2 M06 (.5 END MILL) (D=.5) G00 G90 G54 X-1.5 Y0 S5000 M03 G43 H02 Z1. M08 G01 Z-0.5 F80. G01 G41 D02 Y-0.5 F80. G03 X-1. Y0 R0.5…
HAAS CNC Milling Machine Circular Interpolation Explanation with Example
Haas CNC Milling Circular Interpolation Programming explanation with cnc example programs, these examples shows how IJK or R can be given in cnc program while programming Circular Interpolation with G02 G03…
Haas CNC Alphabetical Address Codes
The following is a list of the Address Codes used in programming the Haas Mill. A Fourth Axis Rotary Motion (Setting 30, 34, 48, 108) The A address character is used…
Haas G150 Pocket Milling Program Example with a Square Island
(5.0 x 5.0 x 0.500 DP. Square Pocket with Square Island) Main Program % O02010 T1 M06 (Tool is a 0.500” diameter endmill) G90 G54 G00 X2. Y2. (XY Start…
(5.0 x 5.0 x 0.500 DP. Square Pocket) Main Program % O01001 T1 M06 (Tool #1 is a 0.500” diameter endmill) G90 G54 G00 X0. Y1.5 (XY Start Point) S2000…
Haas G150 Pocket milling Program Example with a Round island
Main Program % O03010 T1 M06 (Tool is a 0.500” diameter endmill) G90 G54 G00 X2. Y2. (XY Start Point) S2500 M03 G43 H01 Z0.1 M08 G01 Z0. F30. G150…
Haas Mill G107 Cylindrical Mapping Program Example
(G170 parameters) (X X-axis command) (Y Y-axis command) (Z Z-axis command) (A A-axis command) (Q Diameter of cylindrical surface) (R Radius of rotary axis) % O0079 (G107 TEST) T1 M06…
Haas Corner Rounding and Chamfering Example G01 C R
Haas Corner Rounding and Chamfering Haas CNC program example to show how Chamfer and Corner Radius can be programmed. Haas Chamfering To program Chamfer N10 G01 X20 Y30 ,C3 Haas…
Haas M01 Optional Program Stop
Haas M01 Optional Program Stop M01 works the same as M00, except the Optional Stop feature must be on. M-Code Data Modal/Non-Modal Mill/Lathe Modal Both Programming M00 Haas M00 Working…
Haas M00 Stop Program
Haas M00 Stop Program The M00 code is used to stop a program. Haas M00 stops the axes spindle turns off the coolant (including Through Spindle Coolant) The next block…
Haas G00 Rapid Motion Positioning – Haas Mill
Haas G00 Rapid Motion Positioning – Haas Mill G00 G code is used to move the machines axis at the maximum speed. G00 is primarily used to quickly position the…
Haas G00 Rapid Motion Positioning – Haas Lathe
Haas G00 Rapid Motion Positioning – Haas Lathe G00 G code is used to move the machines axis at the maximum speed. G00 is primarily used to quickly position the…
Haas Machine Not Running – Electrical Troubleshooting
If your Haas CNC has some problem such as cannot power on/ turns off by itself/ keyboard beeps then here are few troubleshooting steps that you can take. Before proceeding…
Haas Parameter List
Haas parameter list (mill/lathe) for cnc machinists who work on Haas cnc lathe/mill. Parameters are seldom-modified values that change the operation of the machine. These include servo motor types, gear ratios,…
Spindle Warm Up Program
All spindles, which have been idle for more than 4 days, must be thermally cycled prior to operation above 6,000 RPM. This will prevent possible overheating of the spindle due…
Haas CNC Mill Settings Quiz – Test Your Haas Settings Knowledge
How much do you know about your Haas Mill. Here are series of questions related to Haas mill settings, so you can test how much do you know your Haas…
Haas G72 Type I Rough and G70 Finish Facing Cycle Program Example – Fanuc Compatible
Haas lathe programming example to illustrate the use and programming of Haas G72 Type I Rough Facing Cycle/ G70 Finish Cycle. The above code will also work on cnc lathe…
What is Haas Programmable Coolant Nozzle
Haas Programmable Coolant Nozzle Haas CNC vertical and horizontal CNC machining centers (VMCs and HMCs) are available with a Programmable Coolant Nozzle (P-Cool) that automatically directs coolant precisely at the…
Haas M35 COOLANT SPIGOT POSITION UP – Haas Mill
Haas M35 COOLANT SPIGOT POSITION UP M35 COOLANT SPIGOT POSITION UP, DECREMENT (-1) M35 decrements the coolant spigot position up one place. Decrementing the spigot position causes the spigot to move…
Haas M34 COOLANT SPIGOT POSITION DOWN – Haas Mill
Haas M34 COOLANT SPIGOT POSITION DOWN M34 COOLANT SPIGOT POSITION DOWN, INCREMENT (+1) M34 Increments the current spigot position down one place. Incrementing the spigot position causes the spigot to move…
Haas M109 INTERACTIVE USER INPUT – Haas Mill
Haas M109 INTERACTIVE USER INPUT M109 M code allows a G-code program to place a short prompt (message) on the screen. A macro variable in the range 500 through 599 must be…
Haas M95 Sleep Mode Haas Mill
Haas M95 Sleep Mode Sleep mode is essentially a long dwell (pause). Sleep mode can be used when the user wants the machine to begin warming itself up so it can…
Haas M89 Through-Spindle Coolant Off – Haas Mill
Haas M89 Through-Spindle Coolant Off M89 is used to turn off the Through the Spindle Coolant (TSC) option. When M89 is called, the spindle will stop and the TSC pump will…
Haas M88 Through-Spindle Coolant On – Haas Mill
Haas M88 Through-Spindle Coolant On The M88 code is used to turn on the through-spindle coolant (TSC) option, an M89 turns the coolant off. Proper tooling, with a through-hole, must be in…
CNC Lathe Soft Jaws Cutting for ID Gripping – Video by Haas
A very brief and informative video by Haas Automation for CNC machinists which explains how to properly cut cnc lathe soft jaws for ID gripping. Note: It is highly recommended…
Haas Settings – CNC Lathe
Complete list of Haas settings for CNC machinists who work on Haas Lathe machines. Haas Settings Introduction Haas Settings are Haas machine conditions that have an affect on machine operation….
Haas Settings – CNC Mill
Haas Settings Introduction Haas Settings are Haas machine conditions that have an affect on machine operation. In general, settings allow the operator or setup person to lock out, turn on…
CNC Lathe Soft Jaws Proper Boring/Cutting Method – Video by Haas
CNC Lathe Soft Jaws Video Series by Haas Automation A very brief video which described the proper way to cut cnc lathe soft jaws. Every action which is used while…
Haas Alarm Codes
Haas Alarm Codes (Error Codes) for CNC Machinists. Haas Alarm Codes 101 – COMM. FAILURE WITH MOCON/MOCON MEMORY FAULT 102 – SERVOS OFF 103 – X SERVO ERROR TOO LARGE…
Clearing All Offsets with G10 G Code on Haas Machine Tool
Haas G10 G Code Programmable Offset Setting Haas G10 Programmable Offset Setting G-code allows the programmer to set offsets within the program. Using G10 replaces the manual entry of offsets…
Haas Mill Manual – Operators & Programming
Haas Mill Manual CNC machinists can freely download Haas Mill Manual from Haas website. Haas mill manual contains full cnc operating and programming details. CNC machinists can download Haas Lathe…
Haas Mill M Codes
A complete list of Haas M Codes. All M codes are activated or cause an action to occur after everything else on a block has been completed. Only one M…
Haas G04 Dwell Command – Dwell time in Seconds or Milliseconds
Haas G04 Dwell command is used to cause a delay or dwell in the program. The block containing G04 will delay for the time specified in the P code. During…
Haas G76 Threading Cycle Multiple Pass
Haas G76 threading cycle can be used for, external threads, Internal threads, straight threads, taper threads. With Haas G76 threading cycle, a programmer can easily command multiple cutting passes along…
Haas G73 Irregular Path Stock Removal Cycle CNC Lathe
Haas G73 Irregular Path Stock Removal Cycle G73 pattern repeating cycle is best used when you want to remove a consistent amount of material in both the X and Z…
