Haas CNC Mill G Codes (Preparatory Functions)
This is the cnc mill g-code list for the Haas cnc milling machines. Of course cnc mill programming g codes are the backbone when cnc programmers are on their task to cnc programming a cnc mill.
Related Articles:
- Haas CNC Lathe G-Codes
- Haas CNC Lathe M-Codes
- CNC Lathe Live Tooling Definition and Related Haas CNC M-Codes
Haas CNC Milling G code List
G Code | Function |
G00 | Rapid Motion |
G01 | Linear Interpolation Motion |
G02 | CW Interpolation Motion |
G03 | CCW Interpolation Motion |
G04 | Dwell |
G09 | Exact Stop |
G10 | Programmable Offset Setting |
G12 | CW Circular Pock Milling (Yasnac) |
G13 | CCW Circular Pock Milling (Yasnac) |
G17 | XY Plane Selection |
G18 | ZX Plane Selection |
G19 | YZ Plane Selection |
G20 | Inch Programming Selection |
G21 | Metric Programming Selection |
G28 | Return to Machine Zero |
G29 | Move to Location Through G29 Reference |
G31 | Skip Function |
G35 | Automatic Tool Diameter Measurement |
G36 | Automatic Work Offset Measurement |
G37 | Automatic Tool Length Measurement |
G40 | Cutter Comp Cancel |
G41 | Cutter Compensation Left |
G42 | Cutter Compensation Right |
G43 | Tool Length Compensation + |
G44 | Tool Length Compensation – |
G47 | Engraving |
G49 | G43/G44 Cancel |
G50 | G51 Cancel |
G51 | Scaling |
G52 | Select Work Coordinate System G52 (Yasnac) |
G52 | Set Local Coordinate System (Fanuc) |
G52 | Set Local Coordinate System (HAAS) |
G53 | Non-Modal Machine Coordinate Selection |
G54 | Select Work Coordinate System l |
G55 | Select Work Coordinate System 2 |
G56 | Select Work Coordinate System 3 |
G57 | Select Work Coordinate System 4 |
G58 | Select Work Coordinate System 5 |
G59 | Select Work Coordinate System 6 |
G60 | Unidirectional Positioning |
G61 | Exact Stop Modal |
G64 | G61 Cancel |
G65 | Macro Subroutine Call |
G68 | Rotation |
G69 | G68 Cancel |
G70 | Bolt Hole Circle (Yasnac) Example1 Example2 Example3 |
G71 | Bolt Hole Arc (Yasnac) Example |
G72 | Bolt Holes Along an Angle (Yasnac) Example |
G73 | High Speed Peck Drill Canned Cycle |
G74 | Reverse Tap Canned Cycle |
G76 | Fine Boring Canned Cycle |
G77 | Back Bore Canned Cycle |
G80 | Canned Cycle Cancel |
G81 | Drill Canned Cycle Example1 Example2 Ex3 Ex4 Ex5 |
G82 | Spot Drill Canned Cycle Ex1 |
G83 | Peck Drill Canned Cycle Ex1 Ex2 |
G84 | Tapping Canned Cycle Example1 Peck Tapping |
G85 | Boring Canned Cycle |
G86 | Bore/Stop Canned Cycle |
G87 | Bore/Manual Retract Canned Cycle |
G88 | Bore/Dwell Canned Cycle |
G89 | Bore Canned Cycle |
G90 | Absolute |
G91 | Incremental |
G92 | Set Work Coordinates – FANUC or HAAS |
G92 | Set Work Coordinates – YASNAC |
G93 | Inverse Time Feed Mode ON |
G94 | Inverse Time Feed Mode OFF/Feed Per Minute ON |
G98 | Initial Point Return |
G99 | R Plane Return |
G100 | Disable Mirror Image |
G101 | Enable Mirror Image |
G102 | Programmable Output To RS-232 |
G103 | Block Look ahead Limit |
G107 | Cylindrical Mapping |
G110 | Select Coordinate System 7 |
G111 | Select Coordinate System 8 |
G112 | Select Coordinate System 9 |
G113 | Select Coordinate System 10 |
G114 | Select Coordinate System 11 |
G115 | Select Coordinate System 12 |
G116 | Select Coordinate System 13 |
G117 | Select Coordinate System 14 |
G118 | Select Coordinate System 15 |
G119 | Select Coordinate System 16 |
G120 | Select Coordinate System 17 |
G121 | Select Coordinate System 18 |
G122 | Select Coordinate System 19 |
G123 | Select Coordinate System 20 |
G124 | Select Coordinate System 21 |
G125 | Select Coordinate System 22 |
G126 | Select Coordinate System 23 |
G127 | Select Coordinate System 24 |
G128 | Select Coordinate System 25 |
G129 | Select Coordinate System 26 |
G136 | Automatic Work Offset Center Measurement |
G141 | 3D+ Cutter Compensation |
G143 | 5 Axis Tool Length Compensation+ |
G150 | General Purpose Pocket Milling |
G153 | 5 Axis High Speed Peck Drill Canned Cycle |
G154 | P1-P99 Replaces G110-G129 on newer machines |
G155 | 5 Axis Reverse Tapping Canned Cycle |
G161 | 5 Axis Drill Canned Cycle |
G162 | 5 Axis Spot Drill/Counterbore Canned Cycle |
G163 | 5 Axis Peck Drill Canned Cycle (Setting 22) |
G164 | 5 Axis Tapping Canned Cycle |
G165 | 5 Axis Bore in, Bore out Canned Cycle |
G166 | 5 Axis Bore in, Stop, Rapid out Canned Cycle |
G169 | 5 Axis Bore, Dwell, Bore out Canned Cycle |
G174 | Special Purpose Non-Vertical Rigid Tapping CCW |
G184 | Special Purpose Non-Vertical Rigid Tapping CW |
G187 | Accuracy Control for High Speed Machining |
G188 | Get Program From PST (Program Schedule Table) |
