Haas M35 COOLANT SPIGOT POSITION UP – Haas Mill
M35 COOLANT SPIGOT POSITION UP, DECREMENT (-1)
M35 decrements the coolant spigot position up one place.
Decrementing the spigot position causes the spigot to move up toward the spigot home position. The home position is designated as zero.
M34 Coolant Increment - M35 Coolant Decrement
M35 Example
M35
If the current spigot position is 5 and M35 is executed, then the current spigot position will move up to 4. The spigot home position for a horizontal mill places the spigot at the most positive Z axis location. Decrementing the spigot will raise the coolant stream direction.
Haas Programmable Coolant Nozzle
Related
Haas Machining Centers: Using the Programmable Coolant Nozzle
Haas Alarm 196 COOLANT SPIGOT FAILURE – Haas Mill
