Haas M95 Sleep Mode
Sleep mode is essentially a long dwell (pause). Sleep mode can be used when the user wants the machine to begin warming itself up so it can be ready for use upon the operators arrival.
The format of the M95 command is:
M95 (hh:mm)
The comment immediately following the M95 must contain the hours and minutes that the machine is to sleep for.
M95 Example
For example, if the current time were 6 p.m. and the user wanted the machine to sleep until 6:30 a.m. the next day, the following command would be used:
M95 (12:30)
The line(s) following the M95 should be axis moves and spindle warm-up commands.
