A complete list of Haas M Codes.
All M codes are activated or cause an action to occur after everything else on a block has been completed.
Only one M code is allowed per block in a program.
If there is a (Setting number) listed next to an M code, that setting will in some way relate to that M code.
For Haas Mill G Codes read Haas CNC Mill G Codes.
Haas Mill M Codes
Haas Mill M Codes
M-Code | Description |
M00 | Program Stop |
M01 | Optional Program Stop |
M02 | Program End (Setting 39) |
M03 | Spindle On, Clockwise (S) (Setting 144) |
M04 | Spindle On, Counterclockwise (S) (Setting 144) |
M05 | Spindle Stop |
M06 | Tool Change (T) (Setting 42, 87, 155) |
M08 | Coolant On (Setting 32) |
M09 | Coolant Off |
M10 | 4th Axis Brake On |
M11 | 4th Axis Brake Release |
M12 | 5th Axis Brake On |
M13 | 5th Axis Brake Release |
M16 | Tool Change (T) (Same as M06) |
M17 | APC Pallet Unclamp and Open APC Door |
M18 | APC Pallet Clamp and Close APC Door |
M19 | Orient Spindle (P,R values optional) |
M21-M28 | Optional User M Code Interface with M-Fin Signals |
M30 | Program End and Reset (Setting 2, 39, 56, 83) |
M31 | Chip Auger Forward (Setting 114,115) |
M33 | Chip Auger Stop |
M34 | Coolant Spigot Position Down, Increment (+1) |
M35 | Coolant Spigot Position Up, Decrement (-1) |
M36 | Pallet Part Ready (P) |
M39 | Rotate Tool Turret (T#) (Setting 86) |
M41 | Spindle Low Gear Override |
M42 | Spindle High Gear Override |
M50 | Execute Pallet Change (P) (Setting 121 thru,129) |
M51-M58 | Optional User M Code Set |
M59 | Output Relay Set (N) |
M61-M68 | Optional User M Code Clear |
M69 | Output Relay Clear (N) |
M75 | Set G35 or G136 Reference Point |
M76 | Control Display Inactive |
M77 | Control Display Active |
M78 | Alarm if Skip Signal Found |
M79 | Alarm if Skip Signal Not Found |
M80 | Automatic Door Open (Setting 131) |
M81 | Automatic Door Close (Setting 131) |
M82 | Tool Unclamp |
M83 | Auto Air Jet On |
M84 | Auto Air Jet Off |
M86 | Tool Clamp |
M88 | Coolant Through the Spindle On |
M89 | Coolant Through the Spindle Off |
M93 | Axis POS Capture Start (P, Q) |
M94 | Axis POS Capture Stop |
M95 | Sleep Mode |
M96 | Jump if No Input (P, Q) |
M97 | Local Sub-Program Call (P, L) |
M98 | Sub Program Call (P, L) |
M99 | M97 Local Sub-Program or M98 Sub-Program Return or Loop Program (Setting 118) |
M101 | MOM (Minimum Oil Machining) CANNED CYCLE MODE (I) |
M102 | MOM (Minimum Oil Machining) MODE (I,J) |
M103 | MOM (Minimum Oil Machining) MODE CANEL |
M109 | Interactive User Input (P) |
