Haas Parameter 580 TS HYD RETRACT TIME – Haas Lathe
Added for the SL-10 hydraulic no-encoder tailstock. It specifies the amount of time (in ms) that the tailstock center will be commanded to retract as a result of commanding an M22 and only takes affect when Simple TS is set to 1.
