Haas Settings Introduction
Haas Settings are Haas machine conditions that have an affect on machine operation. In general, settings allow the operator or setup person to lock out, turn on or specify functions.
Haas Settings
Haas Mill Settings
- 1 – Auto Power Off Timer
- 2 – Power Off At M30
- 3 – 3D Graphics
- 4 – Graphics Rapid Path
- 5 – Graphics Drill Point
- 6 – Front Panel Lock
- 7 – Parameter Lock
- 8 – Prog Memory Lock
- 9 – Dimensioning
- 10 – Limit Rapid At 50%
- 11 – Baud Rate Select
- 12 – Parity Select
- 13 – Stop Bit
- 14 – Synchronization
- 15 – H & T Code Agreement
- 16 – Dry Run Lock Out
- 17 – Opt Stop Lock Out
- 18 – Block Delete Lock Out
- 19 – Feedrate Override Lock
- 20 – Spindle Override Lock
- 21 – Rapid Override Lock
- 22 – Can Cycle Delta Z
- 23 – 9xxx Progs Edit Lock
- 24 – Leader To Punch
- 25 – EOB Pattern
- 26 – Serial Number
- 27 – G76/G77 Shift Dir.
- 28 – Can Cycle Act w/o X/Y
- 29 – G91 Non-modal
- 30 – 4th Axis Enable
- 31 – Reset Program Pointer
- 32 – Coolant Override
- 33 – Coordinate System
- 34 – 4th Axis Diameter
- 35 – G60 Offset
- 36 – Program Restart
- 37 – RS-232 Data Bits
- 38 – Aux Axis Number
- 39 – Beep at M00, M01, M02, M30
- 40 – Tool Offset Measure
- 41 – Add Spaces RS232 Out
- 42 – M00 After M06
- 43 – Cutter Comp Type
- 44 – Min F in Radius CC %
- 45 – Mirror Image X-axis
- 46 – Mirror Image Y-axis
- 47 – Mirror Image Z-axis
- 48 – Mirror Image A-axis
- 49 – Skip Same Tool Change
- 50 – Aux Axis Sync
- 51 – Door Hold Switch Override (Safety Switch Override)
- 52 – G83 Retract Above R
- 53 – Jog w/o Zero Return
- 54 – Aux Axis Baud Rate
- 55 – Enable DNC from MDI
- 56 – M30 Restore Default G
- 57 – Exact Stop Canned X-Y
- 58 – Cutter Compensation
- 59 – Probe Offset X+
- 60 – Probe Offset X-
- 61 – Probe Offset Y+
- 62 – Probe Offset Y-
- 63 – Tool Probe Width
- 64 – T. OFS Meas Uses Work
- 65 – Graph Scale (Height)
- 66 – Graphics X Offset
- 67 – Graphics Y Offset
- 69 – DPRNT Leading Spaces
- 70 – DPRNT Open/Clos DCode
- 71 – Default G51 Scaling
- 72 – Default G68 Rotation
- 73 – G68 Incremental Angle
- 74 – 9xxxx PROGS Trace
- 75 – 9xxx PROGS Single BLK
- 76 – Tool Release Lock Out
- 77 – Scale Integer F
- 78 – 5th axis Enable
- 79 – 5th-axis Diameter
- 80 – Mirror Image B-axis
- 81 – Tool At Power Up
- 82 – Language
- 83 – M30 Resets Override
- 84 – Tool Overload Action
- 85 – Max Corner Rounding
- 86 – M39 Lockout
- 87 – M06 Resets Override
- 88 – Reset Resets Overrides
- 90 – Max Tools To Display
- 91 – Advanced Jog
- 100 – Screen Saver Delay
- 101 – Feed Overide -> Rapid
- 103 – CYC Start/FH Same Key
- 104 – Jog Handl to SNGL BLK
- 108 – Quick Rotary G28
- 109 – Warmup Time in Min.
- 110 – Warmup X Distance
- 111 – Warmup Y Distance
- 112 – Warmup Z Distance
- 114 – Conveyor Cycle Time (Minutes)
- 115 – Conveyor On-time (Minutes)
- 116 – Pivot Length
- 117 – G143 Global Offset
- 118 – M99 Bumps M30 CNTRS
- 119 – Offset Lock
- 120 – Macro VAR Lock
- 121 – APC Pal. One Load X
- 122 – APC Pal. One Load Y
- 123 – APC Pal. One Unload X
- 124 – APC Pal. One Unload Y
- 125 – APC Pal. Two Load X
- 126 – APC Pal. Two Load Y
- 127 – APC Pal. Two Unload X
- 128 – APC Pal. Two Unload Y
- 129 – APC Pal. 1 and 2 Safe X Pos
- 130 – Tap Retract Speed
- 131 – Auto Door
- 133 – Repeat Rigid Tap
- 134 – Connection Type
- 135 – Network Type
- 136 – Server
- 137 – Username
- 138 – Password
- 139 – Path
- 140 – TCP/IP ADDR
- 141 – Subnet Mask
- 142 – Offset CHNG Tolerance
- 143 – Machine Data Collect
- 144 – Feed Overide->Spindle
- 146 APC Pallet 3 Load X
- 147 APC Pallet 3 Load Y
- 148 APC Pallet 3 Unload X
- 149 APC Pallet 3 Unload Y
- 150 APC Pallet 4 Load X
- 151 APC Pallet 4 Load Y
- 152 APC Pallet 4 Unload X
- 153 APC Pallet 4 Unload Y
- 154 APC Pallet 3 & 4 Safe X
- 155 Load Pocket Tables
- 156 Save Offset with PROG
- 157 Offset Format Type
- 158 159 160 – Screw Thermal COMP%
- 162 Default to Float
- 163 Disable .1 Jog Rate
- 164 Rotary Increment
- 167-186 Periodic Maintenance
- 187 Machine Data Echo
- 188/189/190 – G51 X/Y/Z SCALE
- 191 Default Smoothness
- 196 – Conveyor Shutdown
- 197 – Coolant Shutdown
- 198 – Background Color
- 199 – Backlight Timer
- 201 – Show Only Work and Tool Offsets In Use
- 216 – Servo and Hydraulic Shutoff
- 238 – High Intensity Light Timer (minutes)
- 239 – Worklight Off Timer (minutes)
- 242 – Air Water Purge Interval (minutes)
- 243 – Air Water Purge On-Time (seconds)
- 244 – Master Gage Tool Length (inches)
- 900 – CNC Network Name
- 901 Obtain Address Automatically
- 902 IP Address
- 903 – Subnet Mask
- 904 – Gateway
- 905 – DNS Server
- 906 – Domain/Workgroup Name
- 907 – Remote Server Name
- 908 Remote Share Path
- 909 – User Name
- 910 – Password
- 911 – Access to CNC Share (Off, Read, Full)
- 912 – Floppy Tab Enabled
- 913 – Hard Drive Tab Enabled
- 914 – USB Tab Enabled
- 915 – Net Share
- 916 – Second USB Tab Enabled
