How to Import DXF file into a Haas CNC Mill
DXF Import is a component of the Haas CNC Intuitive Programming System (IPS). The IPS option must be enabled for DXF Import to work.
DXF Import feature allows a programmer to import an already existing 2D DXF file into the haas control and use the geometry to generate tool paths. The tool paths can then be used to generate G-code.
