Hurco WinMax Free Download
CNC machinists can free download desktop version of WinMax 9 from Hurco CNC website
http://www.hurco.com/en-us/machine-tools/our-control/Pages/WinMax9.aspx
Hurco WinMax Control
Hurco WinMax Feature List
DXF Scaling: Lets you scale DXF drawings to actual size—you don’t have redraw them or go back to the CAD system.
FastDraw Graphics Engine: Due to technological advancements, the new engine we use to run the verification graphics is almost seven times faster than the previous version.
Font Magnification (NC only): Lets you increase the size of any installed font for easier reading.
Mill Frame with Enhanced Corner Geometry: Lets you define the type of corner, the angle, the length, and/or the radius.
Multiple Options to Store Tool Probing Results: Lets you store results in Conversational Field, G-Code Length/Radius Offset Tables or Both.
Program Edit Lockout: Gives you complete control: set the level of access for programs and parameters, including Full Lockout or Partial Lockout.
Roughing Stock Allowance: Lets you specify stock allowance with or without a finishing operation. If the Z finish allowance is zero, only the walls will be finished.
Stick Lettering: Mill letters and numbers in quick tool centerline toolpath. Lets you orient the letters at any angle and wrap about a cylinder.
Tool Life Management: Messages appear in real time to alert you that a tool has reached its maximum cutting time.
UltiMotion: Patented motion control system that simultaneously reduces cycle time by more than 30 percent and improves surface finish.
TrueType® Fonts Along a Contour: allows the operator to specify a contour that the lettering blocks will be swept along.
WinMax Desktop Complete: Has the ability to simulate both the single screen and the dual screen control. Simulates multiple machine modes, including Dry Run, Auto Run, Manual Mode, and Recovery Restart.
Z Offset Shift: Lets you shift the Z offset without modifying the original Part Z Work Coordinate setting.
