G code list for Hurco Turning Centers (Dual-screen and Max Consoles). Hurco lathe G-code list also specifies which Hurco G-codes are Modal and which are non-modal.
Hurco Manuals Free Download
Hurco programming manuals are free to download from Hurco website
Hurco CNC Manuals Programming and Maintenance Free Download.
Hurco WinMax Software Free Download
CNC machinists can download Hurco WinMax software free from Hurco website
Hurco CNC Software WinMax Free Download.
Hurco Lathe G-Code List
Hurco lathe Modal G-codes have a ‘M’ written with them.
-------------------------------------------------- G-Code Modal Function -------------------------------------------------- G00 M Linear Motion at Rapid G01 M Linear Motion at Feed G02 M Clockwise Circular Motion at Feed G03 M Counterclockwise Circular Motion at Feed G04 Dwell G06 M Probe/Block Skip G07 M Radius Programming G08 M Diameter Programming G09 Exact Stop G20 M Inch Mode G21 M Millimeter Mode G33 Threading G40 M Cutter Radius Compensation Off G41 M Cutter Radius Compensation Left G42 M Cutter Radius Compensation Right G53 M Program Machine Coordinates G59 M Cancel Work Coordinate Offsets G73 M Peck Drill with Chip Break Drill Cycle G74 M Left Hand Tapping G78 Threading Cycle G80 M Cancel Drill Cycle G81 M Drill Cycle G82 M Drill Cycle with Dwell G83 M Peck Drill Cycle G84 M Right Hand Tapping G90 M Absolute Programming G91 M Incremental Programming G92 M Work Coordinate Offsets or Spindle Max Speed G94 M Feed per Minute G95 M Feed per Revolution G96 M Constant Surface Speed (CSS) G97 M Direct Spindle Speed G98 M Drill Cycle Initial Level Return G99 M Drill Cycle R Plane Return
