Hust CNC simple basic G-code program example, which shows the difference between G90 Absolute Coordinate & G91 Incremental Coordinate.
This tutorial also applies on most Fanuc cnc controls as well.
This is a good resource for beginner level cnc machinists and cnc programmers to understand the difference between G90 and G91.
On Hust CNC Mill Controls
G90 G Code is used for Absolute Coordinate
G91 G Code is used for Incremental Coordinate.
Contents
The origin (Workpiece Zero Point) is the reference. The coordinates of all points describing the shape of the work-piece (machine part) are calculated from the origin.
The coordinates of all points describing the shape of the work-piece (machine part) are calculated from the end point of the previous block.
Hust CNC Flexibility
In G90 Absolute Coordinate mode
X is used for X-axis Absolute movements.
Y is used for Y-axis Absolute movements.
Z is used for Z-axis Absolute movements.
But in G90 Absolute Coordinate mode U, V, W can be used for axis incremental movement commands
U is used for X-axis incremental movements.
V is used for Y-axis incremental movements.
W is used for Z-axis incremental movements.
So in short if you are working in G90 Absolute Coordinate mode then if you wish you can make Incremental movements by using U, V, W.
So there is no need to use G91 Incremental Coordinate command G-Code.
In G91 Incremental Coordinate mode
X is used for X-axis Incremental movements.
Y is used for Y-axis Incremental movements.
Z is used for Z-axis Incremental movements
In G91 Incremental Coordinate mode U, V, W cannot be used.
Example CNC Program
Hust CNC Mill G90 Absolute Coordinates G91 Incremental Coordinate Example
N10 G00 X0.000 Y0.000 Position to work origin N20 G90 Set program to absolute value N30 G1 X12.000 Y12.000 F300.00 P0 to P1 N40 X26.000 Y16.000 P0 to P2 N50 X38.000 Y32.000 P2 to P3 N60 M2
N10 G00 X0.000 Y0.000 Position to work origin N20 G91 Set program to increment value N30 G1 X12.000 Y12.000 F300.00 P0 to P1 N40 X14.000 Y4.000 P0 to P2 N50 X12.000 Y16.000 P2 to P3 N60 M2
N10 G00 X0.000 Y0.000 Position to work origin N20 G1 U12.000 V12.000 F300.00 P0 to P1 N30 U14.000 V4.000 P1 to P2 N40 U12.000 V16.000 P2 to P3 N60 M2
Mixed Usage
N10 G00 X0.000 Y0.000 Position to work origin N30 G1 U12.000 V12.000 F300.00 P0 to P1 N40 X26.000 V4.000 P1 to P2 N50 X38.000 V16.000 P2 to P3 N60 M2
Or
N10 G00 X0.000 Y0.000 Position to work origin N30 G1 U12.000 V12.000 F300.00 P0 to P1 N40 U14.000 Y16.000 P1 to P2 N50 U12.000 Y32.000 P2 to P3 N60 M2
