Complete M-Code list for CNC machinists who work on CNC Lathe machines with Hust H6C-T CNC Controller.
For Hust CNC G-Codes
Hust CNC Lathe Controller G Code List H4CL-T & H6C-T
Hust CNC G Code List – CNC Mill H4M & H4CL-M
Hust H6C-T Lathe CNC Controller
M-Codes for Hust H6C-T Lathe CNC Controller
M-CODE Function
M00 Program Suspension.
M01 Option Suspension.
M02 Program End.
M30 Program Finished.
M98 Subprogram Call
M99 Subprogram ends or main program repeats.
M03 Spindle rotates in normal direction
M04 Spindle rotates in reversed direction
M05 Spindle stops
M06 Work-piece counting+1
M08 Coolant ON.
M09 Coolant OFF.
M13 Spindle CW , coolant ON
M14 Spindle CCW , coolant ON
M15 Option skip(Block delete)
M21 Spindle chuck release
M22 Spindle chuck close
M24 Blow air – on
M25 Blow air – off
M26 Received material – on
M27 Received material – off
M28 SP2 push material
M34 Spindle chuck release (Used with Bar-feeder)
M35 Spindle chuck close (Used with Bar-feeder)
M38 SP2 manual jog ON
M39 SP2 manual jog OFF
M70 Blow air 2 ON
M71 Blow air 2 OFF
M90 Tool changer Home key-OK
M91 Tool changer push out key-OK
M203 Spindle 2 CW
M204 Spindle 2 CCW
M205 Spindle 2 STOP
M213 Spindle 2 CW , coolant ON
M214 Spindle 2 CCW , coolant ON
M221 Spindle 2 Chuck-open
M222 Spindle 2 Chuck-close
M229 Spindle synchronous ON
M230 Spindle synchronous OFF
