Kennametal Master Catalog 2013
Kennametal Master Catalog 2013 is 2,100+ pages of the industry’s best tooling. For convenience, Kennametal have broken the tooling catalog into convenient pdf files to view and download.
The Kennametal tooling catalog is available in metric and inch versions.
You can download the entire catalog pdf, or an entire section pdf, or individual product pdf files.
Contents
Kennametal Master Catalog 2013 Overview
TURNING:
Beyond BLAST™ – inserts with advanced coolant-delivery design directly through the insert
Beyond™ PVD Grades – advanced coatings provide up to 40% longer tool life in high-temperature alloy machining
PCBN, PCD Superhard Materials – superior to all other materials for abrasion resistance and toughness
Grooving and Cut-Off – A2™ -CL geometry and A4™ -GUP geometry for better grooving and cut-off capabilities
Kennametal Select™ – gold inserts for easy wear detection to protect workpiece and maximize insert value
INDEXABLE MILLING:
Beyond BLAST™ KSSM45 and KSRM – featuring technology that puts coolant though the insert to the cutting edge
Dodeka™ Series – Dodeka Mini™ and Dodeka MAX™ are the best milling boosters on the market today with up to 35% better tool life and 30% higher metal removal rates
MEGA Cutters – heavy-duty milling workhorse cutters designed for steel and cast iron indexable milling
Mill 1™ – high-performance tool in all materials for shoulder, ramp, slot, plunge, and helical milling
