Kyocera Cutting Tools and Inserts Catalog can be freely downloaded from Kyocera website http://americas.kyocera.com/kicc/cuttingtools/catalog.html.
Following Kyocera catalogs are available,
2013 Milling Catalog
2012-2013 Turning Catalog
2013 Drilling Catalog
You might like 2011-2012 Kyocera Cutting Tools Catalog PDF Free Download
Contents
Kyocera Cutting Tools and Inserts Catalog 2013
You can download full Kyocera Catalogs or you can even download your required parts (split versions) from the catalog,
Kyocera 2013 Milling Catalog
2013 Milling Catalog (PDF/30Mb)
New easy-to-navigate index!
A – Insert Grades
B – Product Lineup & Inserts
C – 45° Lead Angle
D – 15° Lead Angle
E – 0° Lead Angle
F – Shouldering Endmills
G – Multi-Function Machining Endmills
H – Slot Mill
J – Ball-Nose Endmill Radius Series
K – Other Applications
L – Solid Endmill Carbide Material
R – Technical Information
S – Spare Parts
T – Index
Kyocera 2012-2013 Turning Catalog
2012-2013 Turning Catalog (PDF/115Mb)
A – Insert Grades
B – Turning Inserts
C – CBN & PCD Tools
D – Toolholders
E – Small Tools
F – Boring
T – Index
G – Grooving
H – Cut-Off
J – Threading
P – Spare Parts
R – Techical Info
Kyocera 2013 Drilling Catalog
2013 Drilling Catalog (PDF/9Mb) – Update
